lumia 520 reppair boot xin giúp
Thảo luận trong 'SỬA CHỮA PHẦN CỨNG.' bắt đầu bởi Tuấn Bình Định, 26/2/15.
  1. 26/2/15 lúc 19:02
    Tuấn Bình Định
    Tuấn Bình Định
    e flash = atf nữa chừng báo lỗi mất boot.mất nguồn lun,.câu pin uot reppair ok.lên màn hình đỏ hiện nokia.flash lại = atf báo lỗi thế này,nokia tool củng lỗi ngay phần rely.
    Windows Phone 8/8.1 Lumia Flasher
    If the Phone is ALIVE
    1. Power On the Phone and Connect it to the USB Port
    If the Phone is DEAD
    1. Connect Phone to the USB Port
    2. Press and Hold the VOLUME DOWN and POWER Buttons
    3. Wait until the Phone Vibrates Shortly...
    4. Stop Pressing the Buttons...
    If the Phone is DEAD BOOT
    2. Install Correct Drivers:
    "Nokia Emergency Connectivity"
    Nokia Phone Info Mode Initiated...
    Please wait upto 15 Seconds for SW Reset
    Continuing Previous Boot...
    Please wait upto 30 Seconds for Boot Re-entry
    Boot Flash Mode Successful...
    Buffers Flushed OK...
    Phone Info Query Start...
    Blocks Returned: 0x07 Blocks
    Block ID 0x01 : 00241000
    Block ID 0x02 : 00240000
    Block ID 0x03 : 00E90000
    Block ID 0x05 : Nokia.MSM8227.P6036.1.2
    Block ID 0x0D : 0001
    Block ID 0x0F : 0301010100000101FF
    Block ID 0x10 : 0100030000
    Checking SD Card Size...
    Card Size: 0x00000000
    Checking Platform Security Status...
    Platform Secure Boot Status: Active
    Secure FFU EFUSE Status: Active
    Debug Status: Active
    RDC Status: Not Active
    Authentication Status: Not Active
    UEFI Secure Boot Status: Active
    Checking Secure FFU Mode...
    Secure FFU Mode : SYNC + ASYNC
    Query Flash App Information...
    Flash App Information: 02010C011700
    UEFI App: FLASH APP
    Flash App Protocol Version: 1.12
    Flash App Implementation Version: 1.23
    Query ROOT KEY HASH...
    ROOT_KEY_HASH: F771E62AF89994064F77CD3BC16829503BDF9A3D506D3FACEC AEF3F808C868FD
    Sending Image Signatures...
    ERROR: Flash Signature Block REJECTED! (0x11068000000E00000000)
    This Flash File is NOT COMPATIBLE with this Phone.
    ERROR: Flashing Failed!
    file này e flash máy khác ok.e sợ hàn xách tay wa ae,.tìm hỉu trên google thì nge ae nói nạp file big boot 520 = atf mà e ko bít làm thế nào,ae gặp xin giúp,. atf e chưa acti
  2. 27/2/15 lúc 08:38
    Tuấn Bình Định
    Tuấn Bình Định
    ae có cách nào nap file big boot ko ae.atf chưa acti
  3. 27/2/15 lúc 08:52
    Giết_mobile
    Giết_mobile
    có cách duy nhất là chi 850 cành ạch ty cho nó là nạp được :D
  4. 27/2/15 lúc 08:54
    Đỗ Đức Vũ ™
    Đỗ Đức Vũ ™
  5. 27/2/15 lúc 09:36
    Tuấn Bình Định
    Tuấn Bình Định
  6. 27/2/15 lúc 10:26
    phamthang86
    phamthang86
    giao dien ATF đã active [​IMG]
    ..Chon SELECT PHONE(chọn file Bing boot lumia 520)+ REST JTAG +RESTORE BOOT khoang hơn 10 phút là xong
  7. 27/2/15 lúc 11:08
    Tuấn Bình Định
    Tuấn Bình Định
    có cách nào dùng cho atf chưa acti ko ae
  8. 27/2/15 lúc 11:10
    Tuấn Bình Định
    Tuấn Bình Định
