Lumia 520 repair emmc
Thảo luận trong 'WINDOWS PHONES' bắt đầu bởi hongha2008, 18/12/16.
  1. 18/12/16 lúc 17:35
    hongha2008
    hongha2008
    ae xem hộ e cái log, e làm theo hướng dẫn như topic này http://vietfones.vn/forum/showthread.php?976473-Samsung-eMMC-Write-Protection-Removal-By-ATF nhưng nó cứ đứng im ko chay
    eMMC Test Point Connection Module
    1. DO NOT USE THE PHONE"S BATTERY
    2. Connect the Soldered TP Connections to ATF Box
    3. Disconnect the USB Cable and Wait until the
    the ATF Software will tell you to Connect the USB.
    Interface Reset OK!
    eMMC Access Type: SECTOR MODE
    eMMC Supported Voltage Range:
    3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V
    3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V
    CID : 1501004D38473259430074784AE4809F
    CSD : D02701320F5903FFF6DBFFEF96406007
    eMMC Boot Information
    Revision 1.5 (for MMC v4.41)
    BOOT PARTITION : USER AREA
    PARTITION ACCESS : R/W USER PARTITION
    PERM_BOOT_CFG_PROT : DISABLED
    PWR_BOOT_CFG_PROT : DISABLED
    BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED
    RESET BUS WIDTH : ENABLED
    eMMC FirmW UPDATE : DISABLED
    EMMC CACHE SIZE : 0 KB
    SUPER PAGE SIZE : 3584 KB
    HC ERASE GROUP SIZE: 512 KB
    USER AREA SIZE : 7818182656 BYTES
    BOOT PARTITION SIZE: 4096 KB
    RPMB PARTITION SIZE: 512 KB
    eMMC Device Information
    Manufacturer ID: SAMSUNG
    Device Type : Embedded BGA
    Application ID : 00
    Product Name : M8G2YC
    Product Rev : 0.0
    Product SN : 74784AE4
    Manufactured : August 1997
    Card Specific Data
    CSD_STRUCTURE : Extended
    SPEC_VERS : Version 4.1/4.2/4.3
    TAAC : 13 ns
    TRAN_SPEED : 4000000 KHz
    READ_BL_LEN : 512 Bytes
    C_SIZE : HIGH CAPACITY
    WP_GRP_ENABLE : YES
    WRITE_BL_LEN : 512 Bytes
    CONTENT_PROT_APP : NO
    PERM_WRITE_PROTECT: YES
    TMP_WRITE_PROTECT : NO
    Extended CSD Saved:
    1501004D38473259430074784AE4809F.ext_csd
    Backup Directory:
    C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\
  2. 18/12/16 lúc 18:19
    transy
    Super Moderator
    transy
    Hạ tốc độ xuống (speed) và làm lại. Mà mấy con khi lỗi "PERM_WRITE_PROTECT: YES" , có RP ok thì cũng hên xui, có con dùng lâu chút, có con vài bữa bị lại.:D
