lumia 520 flash lỗi cần ae giúp
Thảo luận trong 'WINDOWS PHONES' bắt đầu bởi tranquyetchien, 17/10/16.
  1. 17/10/16 lúc 14:00
    tranquyetchien
    tranquyetchien
    hiện e nó vẫn dùng bình thường chỉ mỗi tội hay bị reset,flash lại báo lỗi như hình,ae gặp wa xin giúp phát,thank
    Nokia Phone Info Mode Initiated...
    Please wait upto 15 Seconds for SW Reset
    IMEI: 359994050277780
    Version: 1.1.1.3
    Product Code: 059S357
    Module Code: 0205435
    Continuing Previous Boot...
    Please wait upto 30 Seconds for Boot Re-entry
    Boot Flash Mode Successful...
    Buffers Flushed OK...
    Phone Info Query Start...
    Blocks Returned: 0x07 Blocks
    Block ID 0x01 : 00241000
    Block ID 0x02 : 00240000
    Block ID 0x03 : 00E90000
    Block ID 0x05 : Nokia.MSM8227.P6036.1.2
    Block ID 0x0D : 0001
    Block ID 0x0F : 0301010100000101FF
    Block ID 0x10 : 0100130000
    Checking SD Card Size...
    Card Size: 0x00000000
    Checking Platform Security Status...
    Platform Secure Boot Status: Active
    Secure FFU EFUSE Status: Active
    Debug Status: Active
    RDC Status: Not Active
    Authentication Status: Not Active
    UEFI Secure Boot Status: Active
    Checking Secure FFU Mode...
    Secure FFU Mode :
    Query Flash App Information...
    Flash App Information: 02010F011C00
    UEFI App: FLASH APP
    Flash App Protocol Version: 1.15
    Flash App Implementation Version: 1.28
    Query ROOT KEY HASH...
    ROOT_KEY_HASH: F771E62AF89994064F77CD3BC16829503BDF9A3D506D3FACECAEF3F808C868FD
    Query PUBLIC ID...
    PUBLIC_ID: 1ECEFBAB5DEC99FC6108344D059DD0B1D4B805DE
    Query eMMC Info...
    EMMC Manufacture ID: SAMSUNG
    EMMC Product SN : C5C6C08B
    EMMC_SIZE: 8 Gigabytes
    Query Battery Charge Status...
    BATTERY CHARGE_STATUS: 21%
    Sending Image Signatures...
    Image Signatures Accepted!
    Erasing Data Partition...
    Data Partition Erased Successfully
    Fixing Partitions...
    Preparing Buffers for DATA LOOP...
    Allocating System RAM OK!
    Start Sending DATA BLOCKS...
    ERROR: DATA BLOCK REJECTED at 0x00300000
    Check your Flash File and Phone Connection
    ERROR: Flashing Failed!
  2. 17/10/16 lúc 14:14
    TrầnGia-NEEDCHANGE-7283
    rebot lạị đi a.khả năng chết boot.
    atf active full múc ok thôi
  3. 17/10/16 lúc 14:24
    tranquyetchien
    tranquyetchien
    máy đang dùng bình thường a,mà nạp LUMIA_520_RM-914_BIG_BOOT.afp hay LUMIA_520_520T_525_526_FFU_FLASHER.afp
  4. 17/10/16 lúc 14:50
    bữa có cây bật nguồn lên vào ứng dụng là tắt.làm theo ok. a cứ thử.
  5. 19/10/16 lúc 11:17
    tranquyetchien
    tranquyetchien
    mới nạp lại file big boot xong mà vẫn lỗi như củ,có cách nào ko ae,giờ e nó lên logo vodafone rồi tắt chứ ko thấy chử Nokia đâu hết:D
  6. 19/10/16 lúc 13:52
    khuonglc
    khuonglc
    nap big boot xong r nạp lại rom bạn ơi . block data máy vẫn dùng bt. reset xong dữ liệu vẫn nguyên .vào ứng dụng thoát ra vừa lam con 1320 xong
  7. 19/10/16 lúc 14:25
    tranquyetchien
    tranquyetchien
    e nạp lại vẫn báo lỗi như củ a ơi,nên mới lên nhờ ae giúp
  8. 19/10/16 lúc 14:28
    ladykillad89
    ladykillad89
    Đây là bênh chug của dòng lumia
    khóa phân vùng emmc nên không thể flash được
    dùng atf câu pinout emmc rồi Remove Write Protection emmc
    tiếp BACKUP 512MB of USER area ( imei + simlock+boot)
    rồi Format + Update Firmware emmc
    Xong rồi thì write file 512mb backup trước đó
    Xong thì chạy lại la ok
    Dòng này em làm rất nhiều rồi
    Nếu chỉ Remove Write Protection emmc mà không Format + Update Firmware emmc thì xài mấy hôm sẽ bị lại
  9. 18/12/16 lúc 19:06
    hongha2008
    hongha2008
    chọn format + update nó cần 1 file emmc , cho e xin file đó đi a
  10. 18/12/16 lúc 21:56
    ladykillad89
    ladykillad89
    [​IMG] Trả lời
    File nó có sẵn trong thu mục ATF rồi anh
