Lumia 520 flash bao lổi ae có gặp giúp mình với. Windows Phone 8/8.1 Flashing Started Loading Flash Files Please Wait... [DEAD BOOT REPAIR SUPPORTED] ====================================================== Windows Phone 8/8.1 Lumia Flasher ====================================================== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... If the Phone is DEAD BOOT 1. Connect Phone to the USB Port 2. Install Correct Drivers: "Nokia Emergency Connectivity" ====================================================== Recovery Handle Found! - (WinUSB) Sending Factory Loader... Loader Upload Done! Executing Loader... Start Loader Done! Waiting for USB Cycle... USB Cycle OK! Device Factory Mode OK! USB Reconfiguration Done... eMMC Detected OK... Extracting Partitions from FFU... Looking for SBL1... SBL1 OK Looking for SBL2... SBL2 OK Looking for SBL3... SBL3 OK Looking for UEFI... UEFI OK Looking for RPM... RPM OK Looking for TZ... TZ OK Looking for WINSECAPP... WINSECAPP OK Extracting Partitions Done! Start Writing eMMC Blocks at : 0x00000000 Start Writing eMMC Blocks at : 0x01000000 ERROR: eMMC WRITE Failed at 0x01000000 Skipping This Partition... Start Writing eMMC Blocks at : 0x01200000 ERROR: eMMC WRITE Failed at 0x01200000 7E0D07000000577269746520756E7375636365737366756CF05B7E ERROR: Flashing Failed!
giờ hiện trạng như thế nào,có tín hiệu rung ko...Nói rõ ràng tý chứ bồ.Nếu bật nguồn rung cái thì dow nokia care suite về múc cho chuẩn
Ban đầu thì có rung flash 1 hồi thì mất rung luôn.Đưa người bạn cứu boot thì nói là không thấy flash.
bạn dung riff cứu boot lên cái đả,rồi dùng nokia sofware update úp lại rom là lên,mình đả làm rất nhiều cây như vậy rồi
