nhờ ae xem dùm log này lỗi gì vậy? Windows Phone 8/8.1/10 Flashing Started Loading Flash Files Please Wait... [DEAD BOOT REPAIR via USB is SUPPORTED] ====================================================== Windows Phone 8/8.1/10 Lumia Flasher ====================================================== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... If the Phone is DEAD BOOT 1. Connect Phone to the USB Port 2. Install Correct Drivers: "Nokia Emergency Connectivity" Located at: C:\AdvanceBox Turbo Flasher\Driver\NOKIA_X2_USB_DRIVERS\ ====================================================== Recovery Handle Found! - (WinUSB) PBL Emergency Download Detected Start Sending Firehose Loader... Firehose Loader Sent! Executing Firehose Loader... Start Processing Firehose Payload... MSG_SIGNATURE Sent.... Validation is enabled. EMMC: size_in_sectors:15269888, mfr_id:21, oem_id:0, prod_rev:1, mfr_date:2/2015 ERROR: error code= 9 value= Reported SBL1 error code: 12340901 ERROR: Flashing Failed!
