Lỗi up rom vivo v7 plus
Thảo luận trong 'OPPO, VIVO, REALME ANDROID' bắt đầu bởi tonychu9999, 16/7/21.
  1. 16/7/21 lúc 17:42
    tonychu9999
    tonychu9999
    Nhận con máy này chỉ nhận cổng 9008. Down rom trên mạng về chạy mà bị lỗi này mãi. Ae giúp với. Log:
    2021-07-16 17:37:57.649 Start Download
    2021-07-16 17:37:57.665 Program Path:D:\ROM\[up_vnROM.net]_PD1708F_EX_A_1.8.26_vivo_v7-plus-qcom_LA.UM.5.6-01810-89xx.0_msm8953_split_2\prog_emmc_firehose_8953_ddr.mbn
    2021-07-16 17:37:57.665 ***** Working Folder:C:\Users\admin\AppData\Roaming\Qualcomm\QFIL\COMPORT_3
    2021-07-16 17:39:27.825 Binary build date: Jun 25 2019 @ 03:16:15
    2021-07-16 17:39:27.825 QSAHARASERVER CALLED LIKE THIS: 'C:\Program Files (x86)\Qualcomm\QPST\bin\QSaharaServer.ex'Current working dir: C:\Users\admin\AppData\Roaming\Qualcomm\QFIL\COMPORT_3
    2021-07-16 17:39:27.825 Sahara mappings:
    2021-07-16 17:39:27.825 2: amss.mbn
    2021-07-16 17:39:27.841 6: apps.mbn
    2021-07-16 17:39:27.841 8: dsp1.mbn
    2021-07-16 17:39:27.841 10: dbl.mbn
    2021-07-16 17:39:27.841 11: osbl.mbn
    2021-07-16 17:39:27.841 12: dsp2.mbn
    2021-07-16 17:39:27.841 16: efs1.mbn
    2021-07-16 17:39:27.857 17: efs2.mbn
    2021-07-16 17:39:27.857 20: efs3.mbn
    2021-07-16 17:39:27.857 21: sbl1.mbn
    2021-07-16 17:39:27.857 22: sbl2.mbn
    2021-07-16 17:39:27.857 23: rpm.mbn
    2021-07-16 17:39:27.857 25: tz.mbn
    2021-07-16 17:39:27.857 28: dsp3.mbn
    2021-07-16 17:39:27.872 29: acdb.mbn
    2021-07-16 17:39:27.876 30: wdt.mbn
    2021-07-16 17:39:27.876 31: mba.mbn
    2021-07-16 17:39:27.876 13: D:\ROM\[up_vnROM.net]_PD1708F_EX_A_1.8.26_vivo_v7-plus-qcom_LA.UM.5.6-01810-89xx.0_msm8953_split_2\prog_emmc_firehose_8953_ddr.mbn
    2021-07-16 17:39:27.876 17:39:27: ERROR: function: sahara_rx_data:276 Unable to read packet header. Only read 0 bytes.
    2021-07-16 17:39:27.876 17:39:27: ERROR: function: sahara_main:982 Sahara protocol error
    2021-07-16 17:39:27.876 17:39:27: ERROR: function: main:320 Uploading Image using Sahara protocol failed
    2021-07-16 17:39:27.891
    2021-07-16 17:39:27.891 Download Fail:Sahara Fail:QSaharaServer Fail:process fail
    2021-07-16 17:39:27.891 Finish Download
  2. 16/7/21 lúc 17:49
    Mobile_Software
    Mobile_Software
    lấy boxx chạy xem
  3. 16/7/21 lúc 20:03
    TrongNguyen132
    TrongNguyen132
    chạy bằng box xem loi cụ thể la gi
  4. 17/7/21 lúc 17:56
    tonychu9999
    tonychu9999
    lỗi này
    Screenshot_2.
    Screenshot_2.
