lỗi java cần ae giúp
Thảo luận trong 'MÁY TÍNH WINDOWS' bắt đầu bởi tranquyetchien, 30/9/18.
  1. 30/9/18 lúc 17:28
    tranquyetchien
    tranquyetchien
    ae giúp khắc phục lỗi java này giúp e phát,đã cài java jre-8u181-windows-x64 mới nhất cũng ko dx,e xài win7 64bit
    SSH ramdisk maker & loader, version 29-06-2013 git rev-04b
    Made possible thanks to Camilo Rodrigues (@Allpluscomputer)
    Including xpwn source code by the Dev Team and planetbeing
    Including syringe source code by Chronic-Dev and posixninja
    syringe exploits by pod2g, geohot & posixninja
    Special thanks to iH8sn0w
    device-infos source: iphone-dataprotection
    Report bugs to msft.guy<msft.guy@gmail.com> (@msft_guy)
    Extracted resource to C:\Users\DU-MOB~1\AppData\Local\Temp\ssh_rd\native\jsyringeapi.dll
    Extracted resource to C:\Users\DU-MOB~1\AppData\Local\Temp\ssh_rd\native\mux_redux.dll
    Error java.lang.UnsatisfiedLinkError: C:\Users\Du-mobile\AppData\Local\Temp\ssh_rd\native\jsyringeapi.dll: Can't load IA 32-bit .dll on a AMD 64-bit platform
    java.lang.ClassLoader$NativeLibrary.load(Native Method)
    java.lang.ClassLoader.loadLibrary0(Unknown Source)
    java.lang.ClassLoader.loadLibrary(Unknown Source)
    java.lang.Runtime.load0(Unknown Source)
    java.lang.System.load(Unknown Source)
    Jsyringe.init(Jsyringe.java:44)
    gui.guiInit(gui.java:207)
    gui$2.run(gui.java:186)
    java.awt.event.InvocationEvent.dispatch(Unknown Source)
    java.awt.EventQueue.dispatchEventImpl(Unknown Source)
    java.awt.EventQueue.access$500(Unknown Source)
    java.awt.EventQueue$3.run(Unknown Source)
    java.security.AccessController.doPrivileged(Native Method)
    java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
    java.awt.EventQueue.dispatchEvent(Unknown Source)
    java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
    java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
    java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
    java.awt.EventDispatchThread.pumpEvents(Unknown Source)
    java.awt.EventDispatchThread.run(Unknown Source)
    FATAL: Cannot load native libraries; make sure you're using 32-bit JRE if on Windows!
    INIT FAILED (Jsyringe)!
  2. 30/9/18 lúc 18:29
    hochoimobi
    hochoimobi
    tưởng lỗi jav ..........ch)
  3. 30/9/18 lúc 19:11
    trungvp
    trungvp
    ch) Chết cười với bác!!! Bác thớt tìm đúng bản jav 64 bit cài xem sao. Thấy nội dung báo lỗi ko tương thích giữa win 64 và jav 32.
  4. 30/9/18 lúc 19:43
    lehaiau2009
    lehaiau2009
    Cài 32bit chắc OK nhé.
  5. 30/9/18 lúc 20:02
    tu0977717405
    tu0977717405
    trước hết bạn xóa hết đi những gì đã cài . ( dùng ccleaner càng tốt, không cũng được )
    dọn gọn gàng sạch sẽ
    rồi sau đó tải cái này về : java chuẩn cho mọi win mọi ver
    nó se tự động nhận dạng và cài đặt giúp bạn
    ngồi chờ và hưởng thành quả không cần bận tâm về win gì phiên bản 32 hay 64bit
    mọi việc sẽ trở nên đơn giãn
  6. 1/10/18 lúc 11:04
    tranquyetchien
    tranquyetchien
    vẫn ko dx ae ơi,mặc dù đã cài java 32bit vs 64bit vẫn vậy
  7. 1/10/18 lúc 11:22
    lehaiau2009
    lehaiau2009
    gỡ sạch itunes cài bản 9. hay 10. gì đó bạn thử nhé
  8. 1/10/18 lúc 11:32
    tranquyetchien
    tranquyetchien
    chắc cài lại win 32bit quá chứ tự nhiên đang dùng ok cài qua win 64bit cái lỗi,bó tay
  9. 1/10/18 lúc 12:32
    trungvp
    trungvp
    Thử down bản ja cũ hơn cài
