LG unlock
Thảo luận trong 'LG ANDROID' bắt đầu bởi Vipca, 14/10/17.
  1. 14/10/17 lúc 17:41
    Vipca
    Vipca
    e dùng octopus unlock báo ok mà lắp sim nó cứ báo sim avalid , đã write QCN vẫn như thế ae gặp qua xin giúp e với ạ
  2. 14/10/17 lúc 18:21
    Vipca
    Vipca
    vẫn đang cần ae giúp
  3. 14/10/17 lúc 18:35
    Vipca
    Vipca
    Unlock done nhưng vẫn lock ae à
    Chỉnh sửa cuối: 15/10/17
  4. 14/10/17 lúc 22:00
    Vipca
    Vipca
    Vẫn đang cần ae giúp đỡ !!!
  5. 15/10/17 lúc 03:50
    menxac
    menxac
    load file về chaylai luôn thử anh
  6. 15/10/17 lúc 05:29
    Vipca
    Vipca
    Log trên e có flash lại file ver 10c luôn rồi đó a
  7. 15/10/17 lúc 09:08
    Vipca
    Vipca
    Ae kỹ thuật đâu hết rồi hic hic
  8. 15/10/17 lúc 11:11
    Chinh Mobile LN
    Chinh Mobile LN
    Mã:
    10/10/2017 4:17:33 PM > Checking data...10/10/2017 4:17:34 PM > OK
    10/10/2017 4:17:34 PM > Platform: LG Qualcomm
    10/10/2017 4:17:34 PM > Selected port: COM108
    10/10/2017 4:17:34 PM > Selected model: D415
    10/10/2017 4:17:34 PM > Reading info...
    10/10/2017 4:17:35 PM > Model ID: LG-D415
    10/10/2017 4:17:35 PM > IMEI: 014009-00-474860-9
    10/10/2017 4:17:35 PM > Android version: 5.0.2
    10/10/2017 4:17:35 PM > Battery level: 20%
    10/10/2017 4:17:36 PM > SW Version: 10/10/2017 4:17:36 PM > D41520b
    10/10/2017 4:17:45 PM > Trying to enable Diagnostics ports...
    10/10/2017 4:17:45 PM > Found model WX_PROJE: ÿd at port COM108
    10/10/2017 4:17:45 PM > Unlocking...
    10/10/2017 4:17:47 PM > Reading QCN...
    10/10/2017 4:17:47 PM > Send SPC...10/10/2017 4:17:47 PM > OK
    10/10/2017 4:17:47 PM > Reading Mobile Property...10/10/2017 4:17:47 PM > OK
    10/10/2017 4:17:47 PM > Reading Feature Mask...10/10/2017 4:17:47 PM > OK
    10/10/2017 4:17:47 PM > Reading Roaming List 0...10/10/2017 4:17:47 PM > OK
    10/10/2017 4:17:47 PM > Reading NV_Numbered Items...10/10/2017 4:21:32 PM > OK
    10/10/2017 4:21:32 PM > Reading NV_Numbered SIM1 Items...10/10/2017 4:25:01 PM > OK
    10/10/2017 4:25:01 PM > Reading NV_Numbered SIM2 Items...10/10/2017 4:28:30 PM > OK
    10/10/2017 4:28:30 PM > Reading NV Items...10/10/2017 4:28:32 PM > OK
    10/10/2017 4:28:32 PM > Reading EFS...10/10/2017 4:28:32 PM > OK
    10/10/2017 4:28:32 PM > Reading Provisioning Items...10/10/2017 4:28:39 PM > OK
    10/10/2017 4:28:39 PM > Reading QCN done!
    10/10/2017 4:28:39 PM > Backup saved to "D415_014009004748609_10-10-2017_16-17-47.qcn"
    10/10/2017 4:28:39 PM > Do you want to create security backup?
    10/10/2017 4:30:25 PM > Switching to Download mode...10/10/2017 4:30:51 PM > OK
    10/10/2017 4:30:51 PM > Initializing flash...10/10/2017 4:30:52 PM > OK
    10/10/2017 4:30:52 PM > Reading partitions...10/10/2017 4:30:53 PM > OK
    10/10/2017 4:30:53 PM > Reading security area...10/10/2017 4:30:56 PM > OK
    10/10/2017 4:30:56 PM > Backup saved to "D415_014009004748609_10-10-2017_16-30-25.SEC"
    10/10/2017 4:30:56 PM > Switching to Normal mode...
    10/10/2017 4:31:27 PM > Found model WX_PROJE: ÿd at port COM108
    10/10/2017 4:31:29 PM > Writing security area...10/10/2017 4:31:31 PM > OK
    10/10/2017 4:31:31 PM > Rebooting phone...
    10/10/2017 4:32:02 PM > Found model WX_PROJE: ÿd at port COM108
    10/10/2017 4:32:03 PM > Phone successfully unlocked!
    10/10/2017 4:32:03 PM > To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons).
    10/10/2017 4:32:03 PM > Performed by 2.7.5 Software version.
    nạp lên 5.0 luôn xem vừa mới unlock xong cách đây mấy bửa mà..
  9. 15/10/17 lúc 11:24
    goldenfish
    goldenfish
    Nạp bản 10C múc unlock done 1 nốt nhạc, ko done hạ tool về bản cũ múc lại
  10. 15/10/17 lúc 12:35
    Vipca
    Vipca
    Lên ver 5.0 20c e chưa test còn ver 10c e flash lại rồi đó a , log unlock octopus vẫn done nhưng lắp sim vẫn báo sim avalid !
  11. 18/10/17 lúc 13:49
    goldenfish
    goldenfish
    hạ bản cũ
