LG SU 640 về stock ok ! tiếng việt done !
Thảo luận trong 'LG ANDROID' bắt đầu bởi goldenfish, 12/8/14.
  1. 12/8/14 lúc 09:49
    goldenfish
    goldenfish
    Link rom tiếng việt http://www.4shared.com/zip/b63Mtpd1/Su640_SphinX_V4_port_full.htm
    Welcome to Octoplus/Octopus Box LG Software version 1.6.4
    Converting files...
    Unpacking "MODEM"...OK
    Unpacking "SBL1"...OK
    Unpacking "SBL2"...OK
    Unpacking "EXT"...OK
    Unpacking "RPM"...OK
    Unpacking "SBL3"...OK
    Unpacking "ABOOT"...OK
    Unpacking "BOOT"...OK
    Unpacking "TZ"...OK
    Unpacking "MODEM_ST1"...OK
    Unpacking "MODEM_ST2"...OK
    Unpacking "PERSIST"...OK
    Unpacking "RECOVERY"...OK
    Unpacking "MDM"...OK
    Unpacking "M9K_EFS1"...OK
    Unpacking "M9K_EFS2"...OK
    Unpacking "M9K_EFS3"...OK
    Unpacking "FSG"...OK
    Unpacking "SSD"...OK
    Unpacking "BSP"...OK
    Unpacking "BLB"...OK
    Unpacking "TOMBSTONES"...OK
    Unpacking "DRM"...OK
    Unpacking "FOTA"...OK
    Unpacking "MISC"...OK
    Unpacking "TZ_BKP"...OK
    Unpacking "SYSTEM"...OK
    Unpacking "CACHE"...OK
    Unpacking "WALLPAPER"...OK
    Unpacking "USERDATA"...OK
    Unpacking "MPT"...OK
    Unpacking "GROW"...OK
    Unpacking done. Processing files...
    Identifying sub-files...OK
    Creating destination file...OK
    Deleting temporary files...
    Deleting directory "C:\Users\090762~1.999\AppData\Local\Temp\LG_Su640\"...
    Deleting file "C:\Users\090762~1.999\AppData\Local\Temp\LG_Su640\ABOOT.bin"...OK
    Deleting file "C:\Users\090762~1.999\AppData\Local\Temp\LG_Su640\BLB.bin"...OK
    Deleting file "C:\Users\090762~1.999\AppData\Local\Temp\LG_Su640\BOOT.bin"...OK
    Deleting file "C:\Users\090762~1.999\AppData\Local\Temp\LG_Su640\BSP.bin"...OK
    Deleting file "C:\Users\090762~1.999\AppData\Local\Temp\LG_Su640\CACHE.bin"...OK
    Deleting file "C:\Users\090762~1.999\AppData\Local\Temp\LG_Su640\DRM.bin"...OK
    Deleting file "C:\Users\090762~1.999\AppData\Local\Temp\LG_Su640\EXT.bin"...OK
    Deleting file "C:\Users\090762~1.999\AppData\Local\Temp\LG_Su640\FOTA.bin"...OK
    Deleting file "C:\Users\090762~1.999\AppData\Local\Temp\LG_Su640\FSG.bin"...OK
    Deleting file "C:\Users\090762~1.999\AppData\Local\Temp\LG_Su640\GROW.bin"...OK
    Deleting file "C:\Users\090762~1.999\AppData\Local\Temp\LG_Su640\M9K_EFS1.bin"...OK
    Deleting file "C:\Users\090762~1.999\AppData\Local\Temp\LG_Su640\M9K_EFS2.bin"...OK
    Deleting file "C:\Users\090762~1.999\AppData\Local\Temp\LG_Su640\M9K_EFS3.bin"...OK
    Deleting file "C:\Users\090762~1.999\AppData\Local\Temp\LG_Su640\MDM.bin"...OK
    Deleting file "C:\Users\090762~1.999\AppData\Local\Temp\LG_Su640\MISC.bin"...OK
    Deleting file "C:\Users\090762~1.999\AppData\Local\Temp\LG_Su640\MODEM.bin"...OK
    Deleting file "C:\Users\090762~1.999\AppData\Local\Temp\LG_Su640\MODEM_ST1.bin"...OK
    Deleting file "C:\Users\090762~1.999\AppData\Local\Temp\LG_Su640\MODEM_ST2.bin"...OK
    Deleting file "C:\Users\090762~1.999\AppData\Local\Temp\LG_Su640\MPT.bin"...OK
    Deleting file "C:\Users\090762~1.999\AppData\Local\Temp\LG_Su640\parts.bin"...OK
    Deleting file "C:\Users\090762~1.999\AppData\Local\Temp\LG_Su640\PERSIST.bin"...OK
    Deleting file "C:\Users\090762~1.999\AppData\Local\Temp\LG_Su640\RECOVERY.bin"...OK
    Deleting file "C:\Users\090762~1.999\AppData\Local\Temp\LG_Su640\RPM.bin"...OK
    Deleting file "C:\Users\090762~1.999\AppData\Local\Temp\LG_Su640\SBL1.bin"...OK
    Deleting file "C:\Users\090762~1.999\AppData\Local\Temp\LG_Su640\SBL2.bin"...OK
    Deleting file "C:\Users\090762~1.999\AppData\Local\Temp\LG_Su640\SBL3.bin"...OK
    Deleting file "C:\Users\090762~1.999\AppData\Local\Temp\LG_Su640\SSD.bin"...OK
    Deleting file "C:\Users\090762~1.999\AppData\Local\Temp\LG_Su640\SYSTEM.bin"...OK
    Deleting file "C:\Users\090762~1.999\AppData\Local\Temp\LG_Su640\TOMBSTONES.bin"...OK
    Deleting file "C:\Users\090762~1.999\AppData\Local\Temp\LG_Su640\TZ.bin"...OK
    Deleting file "C:\Users\090762~1.999\AppData\Local\Temp\LG_Su640\TZ_BKP.bin"...OK
    Deleting file "C:\Users\090762~1.999\AppData\Local\Temp\LG_Su640\USERDATA.bin"...OK
    Deleting file "C:\Users\090762~1.999\AppData\Local\Temp\LG_Su640\WALLPAPER.bin"...OK
    Directory "C:\Users\090762~1.999\AppData\Local\Temp\LG_Su640\" succesfully deleted!
    Firmware convert done!
    Searching Diagnostic Ports...OK
    Platform: LG Qualcomm
    Selected port: COM48
    Selected model: SU640
    Reading info...OK
    Mode: Emergency
    Model ID: 8660-AAABQNBYA-34730
    SW version: SU640-MDM9200-V30d-JUN-12-2013-X
    Product ID: SM04S111026000481RRR00
    IMEI: 359255-04-126275-6
    Opening "LG_Su640.oct"...OK
    Initializing flash...OK
    Writing MODEM...OK
    Writing SBL1...OK
    Writing SBL2...OK
    Writing EXT...OK
    Writing RPM...OK
    Writing SBL3...OK
    Writing ABOOT...OK
    Writing BOOT...OK
    Writing TZ...OK
    Writing PERSIST...OK
    Writing RECOVERY...OK
    Writing MDM...OK
    Writing TOMBSTONES...OK
    Writing SYSTEM...OK
    Writing CACHE...OK
    Finalizing...OK
    Writing firmware done!
