LG Stylus 2 K520DY Unbrick - Remove FRP Done
Thảo luận trong 'LG ANDROID' bắt đầu bởi thanhnamPDAviet, 11/6/18.
Trạng thái chủ đề:
Không mở trả lời sau này.
  1. 11/6/18 lúc 09:31
    thanhnamPDAviet
    thanhnamPDAviet
    LG Stylus 2 K520DY Unbrick - Remove FRP By Octopus
    Mã:
    @thanhnamPDAviet
    Checking data...OK
    Platform: LG Qualcomm
    Selected port: COM113
    Selected model: K520DY
    Reading info...
    Mode: Emergency
    Initializing flash...OK
    SW version: LGK520DYAT-00-V10c-TWN-XX-OCT-14-2016+0
    Android version: 6.0.1
    LAF Version: 1.1
    Product ID: CT67S161108004747
    IMEI: 357952-@thanhnamPDAviet
    Target operator: GLOBAL
    Hardware: rev_10
    Opening "K520DY20b_00_0209.kdz"...OK
    Firmware version: K52020j
    Firmware model: LG-K520
    @thanhnamPDAviet
    Prepairing firmware...OK
    Setting options...OK
    Reading partitions...OK
    Formating USERDATA...OK
    Formating ENCRYPT...OK
    Sending signature...OK
    Writing 1/57 PrimaryGPT_0.bin...OK
    Writing 2/57 sbl1_1024.bin...OK
    Writing 3/57 tz_2048.bin...OK
    Writing 4/57 hyp_3072.bin...OK
    Writing 5/57 rpm_4096.bin...OK
    Writing 6/57 aboot_5120.bin...OK
    Writing 7/57 sbl1bak_12288.bin...OK
    Writing 8/57 tzbak_13312.bin...OK
    Writing 9/57 hypbak_14336.bin...OK
    Writing 10/57 rpmbak_15360.bin...OK
    Writing 11/57 abootbak_16384.bin...OK
    Writing 12/57 persist_53248.bin...OK
    Writing 13/57 laf_93184.bin...OK
    Writing 14/57 boot_142336.bin...OK
    Writing 15/57 recovery_191488.bin...OK
    Writing 16/57 recoverybak_240640.bin...OK
    Writing 17/57 sec_295936.bin...OK
    Writing 19/57 factory_316416.bin...OK
    Writing 20/57 modem_513024.bin...OK
    Writing 21/57 cust_688128.bin...OK
    Writing 22/57 system_892928.bin...OK
    Writing 23/57 system_1155072.bin...OK
    Writing 24/57 system_1156616.bin...OK
    Writing 25/57 system_1160632.bin...OK
    Writing 26/57 system_1421232.bin...OK
    Writing 27/57 system_1680904.bin...OK
    Writing 28/57 system_1684920.bin...OK
    Writing 29/57 system_1945520.bin...OK
    Writing 30/57 system_2203648.bin...OK
    Writing 31/57 system_2205192.bin...OK
    Writing 32/57 system_2209208.bin...OK
    Writing 33/57 system_2469808.bin...OK
    Writing 34/57 system_2729480.bin...OK
    Writing 35/57 system_2733496.bin...OK
    Writing 36/57 system_2994096.bin...OK
    Writing 37/57 system_3253768.bin...OK
    Writing 38/57 system_3257784.bin...OK
    Writing 39/57 system_3518384.bin...OK
    Writing 40/57 system_3780528.bin...OK
    Writing 41/57 system_4042672.bin...OK
    Writing 42/57 system_4304816.bin...OK
    Writing 43/57 system_4566960.bin...OK
    Writing 44/57 system_4829104.bin...OK
    Writing 45/57 system_5091248.bin...OK
    Writing 46/57 system_5353392.bin...OK
    Writing 47/57 system_5615536.bin...OK
    Writing 48/57 system_5877680.bin...OK
    Writing 49/57 system_6139824.bin...OK
    Writing 50/57 system_6401968.bin...OK
    Writing 51/57 system_6664112.bin...OK
    Writing 52/57 system_6925304.bin...OK
    Writing 53/57 OP_7651328.bin...OK
    Writing 54/57 OP_7913472.bin...OK
    Writing 55/57 OP_8175616.bin...OK
    Writing 56/57 OP_8178832.bin...OK
    Writing 57/57 BackupGPT_30534656.bin...OK
    Formating RCT...OK
    Formating MPT...OK
    Finalizing...OK
    Writing firmware done!
    @thanhnamPDAviet
    @thanhnamPDAviet
    Checking data...OK
    Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)).
    Reading info...
    Model ID: LG-K520DY
    IMEI: 357952-07-@thanhnamPDAviet
    Android version: 7.0
    Battery level: 7%
    SW Version: K52020j
    Mode: Emergency
    SW version: LGK520DYAT-00-V20j-GLOBAL-COM-FEB-09-2017+0
    LAF Version: 1.1
    Hardware: rev_10
    Reset FRP operation for K520DY will delete all user data on the phone (contacts, pictures and others)!
    Do You want to continue?
    Detecting writing method...OK
    Resetting FRP Lock...
    Writing loader...
    Step 1...
    Step 2...
    Step 3...
    Step 4...
    Step 5...
    Step 6...
    Step 7...
    Step 8...
    Step 9...
    Step 10...OK
    Writing userdata...OK
    Formating encrypt...OK
    Restoring loader...OK
    Resetting FRP lock successfully completed!
    Rebooting phone...
    To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons).
    @thanhnamPDAviet
Trạng thái chủ đề:
