LG Nexus 5X H791 Remove FRP Done
Thảo luận trong 'LG ANDROID' bắt đầu bởi thanhnamPDAviet, 9/1/18.
  1. 9/1/18 lúc 09:26
    thanhnamPDAviet
    thanhnamPDAviet
    LG Nexus 5X H791 Remove FRP Via Teamviewer
    Mã:
    @thanhnamPDAviet
    Checking data...OK
    Platform: LG Qualcomm
    Selected port: COM129
    Selected model: H791
    Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable).
    Reading info...
    IMEI: 355548-07
    Android version:
    Battery level: 97%
    SW Version: LGH791AT-00-V10f-NXS-XXX-OCT-0
    Mode: Emergency
    Initializing flash...OK
    SW version: LGH791AT-00-V10f-NXS-XXX-OCT-03-2015-32G-MDA89E-US
    Android version: 6.0
    LAF Version: 1.2
    Product ID: PT01S151016000312
    IMEI: 355548-07
    Target operator: GOOGLE
    Hardware:
    After performing Reset FRP operation the phone may stuck on logo. To fix this problem You shall reflash the phone with the latest firmare.
    Perform Reset FRP operation at your own risk. Continue?
    Reading partitions...OK
    Resetting FRP Lock...OK
    Resetting FRP lock successfully completed!
  2. 6/5/18 lúc 08:41
    thanhnamPDAviet
    thanhnamPDAviet
    LG Nexus 5X H791 7.1 Unlock Done
    Mã:
    Checking data...OK
    Selected port: COM40
    Reading info...
    IMEI: 353627-07-81895
    Android version:
    Battery level: 10%
    SW Version: LGH791AT-04-V10l-440-20-APR-12
    Mode: Emergency
    SW version: LGH791AT-04-V10l-440-20-APR-12-2016-16G-MTC19T-USER+0
    LAF Version: 1.2
    Product ID: BS05S160707000970
    Hardware:
    Unlocking...
    Skip Read/Write QCN
    Reading security area...OK
    Backup saved to "H791_353627078189506_05-05-2018_10-50-21.SEC"
    Writing security area...OK
