Flash tool flash lại báo nhầm model, ko flash dc, có cách fix bằng cách dùng Hexeditor rồi đồi tên để lừa flash tool flash nhưng mình thử rồi, nó vãn báo fail lôi octopus ra convert rồi flash lại luôn ko cần check model -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM41 Selected model: L-01F Reading info...OK Mode: Emergency Initializing flash...OK Model ID: LG-D801 SW version: LAF Version: 1.0 Product ID: IMEI: Target operator: TMO Hardware: rev_10 Battery level: 59% Opening "LGL01FAT-01-V11k-440-10-DEC-04-2013_0 - Copy.oct"...OK Setting options...OK Reading partition...OK Formating USERDATA...OK Writing PrimaryGPT...OK Writing modem...OK Writing sbl1...OK Writing dbi...OK Writing aboot...OK Writing rpm...OK Writing boot...OK Writing tz...OK Writing persist...OK Writing recovery...OK Writing laf...OK Writing system...OK Writing cache...OK Writing userdata...OK Writing BackupGPT...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Waiting for phone... Flash done. tool fix crossdl có nhưng rất nhì nhằng, lấy octopus ra convert FW rồi flash luôn là done [-([-([-(
