LG F160k flash ok by octopus
Thảo luận trong 'LG ANDROID' bắt đầu bởi goldenfish, 29/7/14.
  1. 29/7/14 lúc 23:11
    goldenfish
    goldenfish
    Flash tool bị gì á, báo mất kết nối hoài, lôi oct ra mà vẫn chưa sp LG F160k, kệ, extract file tot trong kdz ra, lấy oct convert fw rồi flash luôn trên model F160L, cùi không sợ ghẻ :'''
    Lưu ý là Select model F160L nhưng vẫn lấy file của F160k nha mấy thím :'''
    Welcome to Octoplus/Octopus Box LG Software version 1.6.4
    Converting files...
    Unpacking "PrimaryGPT"...OK
    Unpacking "modem"...OK
    Unpacking "sbl1"...OK
    Unpacking "sbl2"...OK
    Unpacking "sbl3"...OK
    Unpacking "aboot"...OK
    Unpacking "rpm"...OK
    Unpacking "boot"...OK
    Unpacking "tz"...OK
    Unpacking "misc"...OK
    Unpacking "system"...OK
    Unpacking "userdata"...OK
    Unpacking "persist"...OK
    Unpacking "cache"...OK
    Unpacking "recovery"...OK
    Unpacking "BackupGPT"...OK
    Unpacking done. Processing files...
    Identifying sub-files...OK
    Creating destination file...OK
    Deleting temporary files...
    Deleting directory "C:\Users\090762~1.999\AppData\Local\Temp\F160K20d\"...
    Deleting file "C:\Users\090762~1.999\AppData\Local\Temp\F160K20d\aboot.bin"...OK
    Deleting file "C:\Users\090762~1.999\AppData\Local\Temp\F160K20d\BackupGPT.bin"...OK
    Deleting file "C:\Users\090762~1.999\AppData\Local\Temp\F160K20d\boot.bin"...OK
    Deleting file "C:\Users\090762~1.999\AppData\Local\Temp\F160K20d\cache.bin"...OK
    Deleting file "C:\Users\090762~1.999\AppData\Local\Temp\F160K20d\misc.bin"...OK
    Deleting file "C:\Users\090762~1.999\AppData\Local\Temp\F160K20d\modem.bin"...OK
    Deleting file "C:\Users\090762~1.999\AppData\Local\Temp\F160K20d\parts.bin"...OK
    Deleting file "C:\Users\090762~1.999\AppData\Local\Temp\F160K20d\persist.bin"...OK
    Deleting file "C:\Users\090762~1.999\AppData\Local\Temp\F160K20d\PrimaryGPT.bin"...OK
    Deleting file "C:\Users\090762~1.999\AppData\Local\Temp\F160K20d\recovery.bin"...OK
    Deleting file "C:\Users\090762~1.999\AppData\Local\Temp\F160K20d\rpm.bin"...OK
    Deleting file "C:\Users\090762~1.999\AppData\Local\Temp\F160K20d\sbl1.bin"...OK
    Deleting file "C:\Users\090762~1.999\AppData\Local\Temp\F160K20d\sbl2.bin"...OK
    Deleting file "C:\Users\090762~1.999\AppData\Local\Temp\F160K20d\sbl3.bin"...OK
    Deleting file "C:\Users\090762~1.999\AppData\Local\Temp\F160K20d\system.bin"...OK
    Deleting file "C:\Users\090762~1.999\AppData\Local\Temp\F160K20d\tz.bin"...OK
    Deleting file "C:\Users\090762~1.999\AppData\Local\Temp\F160K20d\userdata.bin"...OK
    Directory "C:\Users\090762~1.999\AppData\Local\Temp\F160K20d\" succesfully deleted!
    Firmware convert done!
    Platform: LG Qualcomm
    Selected port: COM41
    Selected model: F160L
    Reading info...OK
    Mode: Emergency
    Model ID: BS/D1LKT/1 (F160K)
    SW version: LGP875AT-00-V10a-OPEN-VN-MAR-28-2013+0
    Product ID: PT01S120804001880
    IMEI: 352455-05-167762-3
    Opening "F160K20d.oct"...OK
    Initializing flash...OK
    Reading partition...OK
    Writing PrimaryGPT...OK
    Formating userdata...OK
    Writing modem...OK
    Writing sbl1...OK
    Writing sbl2...OK
    Writing sbl3...OK
    Writing aboot...OK
    Writing rpm...OK
    Writing boot...OK
    Writing tz...OK
    Writing system...OK
    Writing userdata...OK
    Writing persist...OK
    Writing cache...OK
    Writing recovery...OK
    Writing BackupGPT...OK
    Finalizing...OK
    Writing firmware done!
    Tested by Goldenfish
    Đây là hướng dẫn convert file
    http://vietfones.vn/forum/showthrea...i-LG-mới-nhất-(2014)-by-goldenfish&highlight=
    Chỉnh sửa cuối: 30/7/14
  2. 29/7/14 lúc 23:35
    My Computer
    My Computer
    Anh mực này hiệu quả ghê, mấy cái file KDZ chơi = Flash Tool toàn báo lỗi , lôi anh ý ra conver rùi chọn vô chạy phà phà.:D
  3. 30/7/14 lúc 06:59
    hoangthanhpro
    hoangthanhpro
    chia sẻ luôn cách conver file đi Mod ?ít làm nên gà :cry:
  4. 30/7/14 lúc 07:49
    Dzung_mobile
    Dzung_mobile
    Cái thông tin này có vẻ hay. Hôm trước cũng nghĩ vậy nhưng không dám phang vì máy khách còn sống sờ sờ. KDZ thì vẫn chạy vèo vèo nên từ bỏ ý định luôn.
    P/s: Bổ sung thêm thông tin cho mod là khoảng 1 tháng gần đây KDZ của mình vẫn quất em này cả 3 bản chạy vèo vèo. còn cái Flash kia nó cà tưng, chỉ được vài ngày đầu thôi chứ dạo này cũng không động đến nó nữa.
  5. 30/7/14 lúc 08:28
    Bình Nam Định
    Bình Nam Định
    trong octoplus có mục convert đó. tíck vào rồi phang thôi
