Lenovo Vibe P1 Pro P1c72 Unbrick Thành Công Seach Gu gồ có Rom hoặc tải ở đây Đưa về QHS 9008 (Vol + Ghim cáp ) Mở tool chọn như hình Flash Done.Mã:Validating Application Configuration Load APP Configuration COM:2 SAHARA:True SAHARA:C:\Users\thanhnamPDAviet\Desktop\1\prog_emmc_firehose_8936.mbn SEARCHPATH:C:\Users\thanhnamPDAviet\Desktop\1 RAWPROGRAM: rawprogram_unsparse.xml PATCH: patch0.xml ACKRAWDATAEVERYNUMPACKETS:False ACKRAWDATAEVERYNUMPACKETS:100 MAXPAYLOADSIZETOTARGETINBYTES:False MAXPAYLOADSIZETOTARGETINBYTES:49152 DEVICETYPE:eMMC PLATFORM:8x26 VALIDATIONMODE:0 RESETAFTERDOWNLOAD:False MAXDIGESTTABLESIZE:8192 SWITCHTOFIREHOSETIMEOUT:30 RESETTIMEOUT:200 RESETDELAYTIME:2 FLATBUILDPATH:C:\ FLATBUILDFORCEOVERRIDE:True QCNPATH:C:\Temp\00000000.qcn QCNAUTOBACKUPRESTORE:False SPCCODE:000000 ENABLEMULTISIM:False Load ARG Configuration Validating Download Configuration Image Search Path: C:\Users\thanhnamPDAviet\Desktop\1 RAWPROGRAM file path: C:\Users\thanhnamPDAviet\Desktop\1\rawprogram_unsparse.xml PATCH file path:C:\Users\thanhnamPDAviet\Desktop\1\patch0.xml Programmer Path:C:\Users\thanhnamPDAviet\Desktop\1\prog_emmc_firehose_8936.mbn Process Index:0 Start Download Program Path:C:\Users\thanhnamPDAviet\Desktop\1\prog_emmc_firehose_8936.mbn Binary build date: May 13 2015 @ 14:41:37 QSAHARASERVER CALLED LIKE THIS: 'C:\Program Files\Qualcomm\QPST\bin\QSaharaServer.exe -p \\.\COM2 -s 13:C:\Users\thanhnamPDAviet\Desktop\1\prog_emmc_firehose_8936.mbn 'Current working dir: C:\Users\thanhnamPDAviet\AppData\Roaming\Qualcomm\QFIL Sahara mappings: 2: amss.mbn 6: apps.mbn 8: dsp1.mbn 10: dbl.mbn 11: osbl.mbn 12: dsp2.mbn 16: efs1.mbn 17: efs2.mbn 20: efs3.mbn 21: sbl1.mbn 22: sbl2.mbn 23: rpm.mbn 25: tz.mbn 28: dsp3.mbn 29: acdb.mbn 30: wdt.mbn 31: mba.mbn 13: C:\Users\thanhnamPDAviet\Desktop\1\prog_emmc_firehose_8936.mbn 13:03:41: ERROR: function: port_connect:100 Failed to open com port handle 13:03:41: ERROR: function: port_connect:100 Failed to open com port handle 13:03:41: ERROR: function: port_connect:100 Failed to open com port handle 13:03:41: ERROR: function: port_connect:100 Failed to open com port handle 13:03:41: ERROR: function: port_connect:100 Failed to open com port handle 13:03:41: ERROR: function: port_connect:100 Failed to open com port handle 13:03:41: ERROR: function: port_connect:100 Failed to open com port handle 13:03:41: ERROR: function: port_connect:100 Failed to open com port handle 13:03:41: ERROR: function: port_connect:100 Failed to open com port handle 13:03:41: ERROR: function: port_connect:100 Failed to open com port handle 13:03:41: ERROR: function: main:259 Could not connect to \\.\COM2 Download Fail:Sahara Fail:QSaharaServer Fail:Process fail Finish Download Start Download Program Path:C:\Users\thanhnamPDAviet\Desktop\1\prog_emmc_firehose_8936.mbn Binary build date: May 13 2015 @ 14:41:37 QSAHARASERVER CALLED LIKE THIS: 'C:\Program Files\Qualcomm\QPST\bin\QSaharaServer.exe -p \\.\COM2 -s 13:C:\Users\thanhnamPDAviet\Desktop\1\prog_emmc_firehose_8936.mbn 'Current working dir: C:\Users\thanhnamPDAviet\AppData\Roaming\Qualcomm\QFIL Sahara mappings: 2: amss.mbn 6: apps.mbn 8: dsp1.mbn 10: dbl.mbn 11: osbl.mbn 12: dsp2.mbn 16: efs1.mbn 17: efs2.mbn 20: efs3.mbn 21: sbl1.mbn 22: sbl2.mbn 23: rpm.mbn 25: tz.mbn 28: dsp3.mbn 29: acdb.mbn 30: wdt.mbn 31: mba.mbn 13: C:\Users\thanhnamPDAviet\Desktop\1\prog_emmc_firehose_8936.mbn 13:03:42: ERROR: function: port_connect:100 Failed to open com port handle 13:03:42: ERROR: function: port_connect:100 Failed to open com port handle 13:03:42: ERROR: function: port_connect:100 Failed to open com port handle 13:03:42: ERROR: function: port_connect:100 Failed to open com port handle 13:03:42: ERROR: function: port_connect:100 Failed to open com port handle 13:03:42: ERROR: function: port_connect:100 Failed to open com port handle 13:03:42: ERROR: function: port_connect:100 Failed to open com port handle 13:03:42: ERROR: function: port_connect:100 Failed to open com port handle 13:03:42: ERROR: function: port_connect:100 Failed to open com port handle 13:03:42: ERROR: function: port_connect:100 Failed to open com port handle 13:03:42: ERROR: function: main:259 Could not connect to \\.\COM2 Download Fail:Sahara Fail:QSaharaServer Fail:Process fail Finish Download Start Download Program Path:C:\Users\thanhnamPDAviet\Desktop\1\prog_emmc_firehose_8936.mbn Binary build date: May 13 2015 @ 14:41:37 QSAHARASERVER CALLED LIKE THIS: 'C:\Program Files\Qualcomm\QPST\bin\QSaharaServer.exe -p \\.\COM2 -s 13:C:\Users\thanhnamPDAviet\Desktop\1\prog_emmc_firehose_8936.mbn 'Current working dir: C:\Users\thanhnamPDAviet\AppData\Roaming\Qualcomm\QFIL Sahara mappings: 2: amss.mbn 6: apps.mbn 8: dsp1.mbn 10: dbl.mbn 11: osbl.mbn 12: dsp2.mbn 16: efs1.mbn 17: efs2.mbn 20: efs3.mbn 21: sbl1.mbn 22: sbl2.mbn 23: rpm.mbn 25: tz.mbn 28: dsp3.mbn 29: acdb.mbn 30: wdt.mbn 31: mba.mbn 13: C:\Users\thanhnamPDAviet\Desktop\1\prog_emmc_firehose_8936.mbn 13:03:43: ERROR: function: port_connect:100 Failed to open com port handle 13:03:43: ERROR: function: port_connect:100 Failed to open com port handle 13:03:43: ERROR: function: port_connect:100 Failed to open com port handle 13:03:43: ERROR: function: port_connect:100 Failed to open com port handle 13:03:43: ERROR: function: port_connect:100 Failed to open com port handle 13:03:43: ERROR: function: port_connect:100 Failed to open com port handle 13:03:43: ERROR: function: port_connect:100 Failed to open com port handle 13:03:43: ERROR: function: port_connect:100 Failed to open com port handle 13:03:43: ERROR: function: port_connect:100 Failed to open com port handle 13:03:43: ERROR: function: port_connect:100 Failed to open com port handle 13:03:43: ERROR: function: main:259 Could not connect to \\.\COM2 Download Fail:Sahara Fail:QSaharaServer Fail:Process fail Finish Download Start Download Program Path:C:\Users\thanhnamPDAviet\Desktop\1\prog_emmc_firehose_8936.mbn Binary build date: May 13 2015 @ 14:41:37 QSAHARASERVER CALLED LIKE THIS: 'C:\Program Files\Qualcomm\QPST\bin\QSaharaServer.exe -p \\.\COM2 -s 13:C:\Users\thanhnamPDAviet\Desktop\1\prog_emmc_firehose_8936.mbn 'Current working dir: C:\Users\thanhnamPDAviet\AppData\Roaming\Qualcomm\QFIL Sahara mappings: 2: amss.mbn 6: apps.mbn 8: dsp1.mbn 10: dbl.mbn 11: osbl.mbn 12: dsp2.mbn 16: efs1.mbn 17: efs2.mbn 20: efs3.mbn 21: sbl1.mbn 22: sbl2.mbn 23: rpm.mbn 25: tz.mbn 28: dsp3.mbn 29: acdb.mbn 30: wdt.mbn 31: mba.mbn 13: C:\Users\thanhnamPDAviet\Desktop\1\prog_emmc_firehose_8936.mbn 13:04:16: Requested ID 13, file: "C:\Users\thanhnamPDAviet\Desktop\1\prog_emmc_firehose_8936.mbn" 13:04:16: 95292 bytes transferred in 0.078000 seconds (1.1651MBps) 13:04:16: File transferred successfully NOTE: Target requested image 13 which is DeviceProgrammer. Forcing QUIT. This is by design, ** All is well ** SUCCESS!! 13:04:16: Sahara protocol completed Sending Programmer Finished Switch To FireHose Wait for 3 seconds... Max Payload Size to Target:49152 Bytes Device Type:eMMC Platform:8x26 Disable Ack Raw Data Every N Packets Skip Write:False Always Validate:False Use Verbose:False Binary build date: Jun 3 2015 @ 17:12:06 Build version: 15.06. 3.17.12.06 13:04:20: INFO: FH_LOADER WAS CALLED EXACTLY LIKE THIS ************************************************ C:\Program Files\Qualcomm\QPST\bin\fh_loader.exe --port=\\.\COM2 --sendxml=rawprogram_unsparse.xml --search_path=C:\Users\thanhnamPDAviet\Desktop\1 --noprompt --showpercentagecomplete --zlpawarehost=1 --memoryname=eMMC ************************************************ 13:04:20: INFO: Current working dir (cwd): C:\Users\thanhnamPDAviet\AppData\Roaming\Qualcomm\QFIL\ 13:04:20: INFO: Showing network mappings to allow debugging 13:04:20: INFO: 13:04:20: INFO: Trying to store 'rawprogram_unsparse.xml' in string table 13:04:20: INFO: Looking for file 'rawprogram_unsparse.xml' 13:04:20: INFO: User wants to talk to port '\\.\COM2' 13:04:20: INFO: Took 0.00000000 seconds to open port 13:04:20: INFO: Sorting TAGS to ensure order is <configure>,<erase>, others, <patch>,<power> 13:04:20: INFO: If you don't want this, use --dontsorttags 13:04:20: INFO: Looking for file 'NON-HLOS.bin' 13:04:20: INFO: Looking for file 'sbl1.mbn' 13:04:20: INFO: Looking for file 'sbl1.mbn' 13:04:20: INFO: Looking for file 'rpm.mbn' 13:04:20: INFO: Looking for file 'rpm.mbn' 13:04:20: INFO: Looking for file 'tz.mbn' 13:04:20: INFO: Looking for file 'tz.mbn' 13:04:20: INFO: Looking for file 'hyp.mbn' 13:04:20: INFO: Looking for file 'hyp.mbn' 13:04:20: INFO: Looking for file 'sec.dat' 13:04:20: INFO: Looking for file 'emmc_appsboot.mbn' 13:04:20: INFO: Looking for file 'emmc_appsboot.mbn' 13:04:20: INFO: Looking for file 'splash.img' 13:04:20: INFO: Looking for file 'boot.img' 13:04:20: INFO: Looking for file 'recovery.img' 13:04:20: INFO: Looking for file 'system_1.unsparse' 13:04:20: INFO: Looking for file 'system_2.unsparse' 13:04:20: INFO: Looking for file 'system_3.unsparse' 13:04:20: INFO: Looking for file 'system_4.unsparse' 13:04:20: INFO: Looking for file 'system_5.unsparse' 13:04:20: INFO: Looking for file 'system_6.unsparse' 13:04:20: INFO: Looking for file 'system_7.unsparse' 13:04:20: INFO: Looking for file 'system_8.unsparse' 13:04:20: INFO: Looking for file 'system_9.unsparse' 13:04:20: INFO: Looking for file 'system_10.unsparse' 13:04:20: INFO: Looking for file 'system_11.unsparse' 13:04:20: INFO: Looking for file 'system_12.unsparse' 13:04:20: INFO: Looking for file 'system_13.unsparse' 13:04:20: INFO: Looking for file 'system_14.unsparse' 13:04:20: INFO: Looking for file 'system_15.unsparse' 13:04:20: INFO: Looking for file 'system_16.unsparse' 13:04:20: INFO: Looking for file 'system_17.unsparse' 13:04:20: INFO: Looking for file 'system_18.unsparse' 13:04:20: INFO: Looking for file 'system_19.unsparse' 13:04:20: INFO: Looking for file 'system_20.unsparse' 13:04:20: INFO: Looking for file 'cache_1.img' 13:04:20: INFO: Looking for file 'cache_2.img' 13:04:20: INFO: Looking for file 'cache_3.img' 13:04:20: INFO: Looking for file 'userdata_1.img' 13:04:20: INFO: Looking for file 'userdata_2.img' 13:04:20: INFO: Looking for file 'userdata_3.img' 13:04:20: INFO: Looking for file 'userdata_4.img' 13:04:20: INFO: Looking for file 'userdata_5.img' 13:04:20: INFO: Looking for file 'userdata_6.img' 13:04:20: INFO: Looking for file 'userdata_7.img' 13:04:20: INFO: Looking for file 'userdata_8.img' 13:04:20: INFO: Looking for file 'userdata_9.img' 13:04:20: INFO: Looking for file 'userdata_10.img' 13:04:20: INFO: Looking for file 'userdata_11.img' 13:04:20: INFO: Looking for file 'userdata_12.img' 13:04:20: INFO: Looking for file 'userdata_13.img' 13:04:20: INFO: Looking for file 'userdata_14.img' 13:04:20: INFO: Looking for file 'userdata_15.img' 13:04:20: INFO: Looking for file 'userdata_16.img' 13:04:20: INFO: Looking for file 'userdata_17.img' 13:04:20: INFO: Looking for file 'userdata_18.img' 13:04:20: INFO: Looking for file 'userdata_19.img' 13:04:20: INFO: Looking for file 'userdata_20.img' 13:04:20: INFO: Looking for file 'userdata_21.img' 13:04:20: INFO: Looking for file 'userdata_22.img' 13:04:20: INFO: Looking for file 'userdata_23.img' 13:04:20: INFO: Looking for file 'userdata_24.img' 13:04:20: INFO: Looking for file 'userdata_25.img' 13:04:20: INFO: Looking for file 'userdata_26.img' 13:04:20: INFO: Looking for file 'userdata_27.img' 13:04:20: INFO: Looking for file 'userdata_28.img' 13:04:20: INFO: Looking for file 'userdata_29.img' 13:04:20: INFO: Looking for file 'userdata_30.img' 13:04:20: INFO: Looking for file 'userdata_31.img' 13:04:20: INFO: Looking for file 'userdata_32.img' 13:04:20: INFO: Looking for file 'userdata_33.img' 13:04:20: INFO: Looking for file 'userdata_34.img' 13:04:20: INFO: Looking for file 'userdata_35.img' 13:04:20: INFO: Looking for file 'userdata_36.img' 13:04:20: INFO: Looking for file 'userdata_37.img' 13:04:20: INFO: Looking for file 'userdata_38.img' 13:04:20: INFO: Looking for file 'userdata_39.img' 13:04:20: INFO: Looking for file 'userdata_40.img' 13:04:20: INFO: Looking for file 'userdata_41.img' 13:04:20: INFO: Looking for file 'userdata_42.img' 13:04:20: INFO: Looking for file 'userdata_43.img' 13:04:20: INFO: Looking for file 'userdata_44.img' 13:04:20: INFO: Looking for file 'userdata_45.img' 13:04:20: INFO: Looking for file 'userdata_46.img' 13:04:20: INFO: Looking for file 'userdata_47.img' 13:04:20: INFO: Looking for file 'userdata_48.img' 13:04:20: INFO: Looking for file 'userdata_49.img' 13:04:20: INFO: Looking for file 'userdata_50.img' 13:04:20: INFO: Looking for file 'userdata_51.img' 13:04:20: INFO: Looking for file 'userdata_52.img' 13:04:20: INFO: Looking for file 'userdata_53.img' 13:04:20: INFO: Looking for file 'userdata_54.img' 13:04:20: INFO: Looking for file 'userdata_55.img' 13:04:20: INFO: Looking for file 'userdata_56.img' 13:04:20: INFO: Looking for file 'userdata_57.img' 13:04:20: INFO: Looking for file 'userdata_58.img' 13:04:20: INFO: Looking for file 'userdata_59.img' 13:04:20: INFO: Looking for file 'userdata_60.img' 13:04:20: INFO: Looking for file 'userdata_61.img' 13:04:20: INFO: Looking for file 'userdata_62.img' 13:04:20: INFO: Looking for file 'userdata_63.img' 13:04:20: INFO: Looking for file 'userdata_64.img' 13:04:20: INFO: Looking for file 'userdata_65.img' 13:04:20: INFO: Looking for file 'userdata_66.img' 13:04:20: INFO: Looking for file 'userdata_67.img' 13:04:20: INFO: Looking for file 'userdata_68.img' 13:04:20: INFO: Looking for file 'userdata_69.img' 13:04:20: INFO: Looking for file 'userdata_70.img' 13:04:20: INFO: Looking for file 'userdata_71.img' 13:04:20: INFO: Looking for file 'userdata_72.img' 13:04:20: INFO: Looking for file 'userdata_73.img' 13:04:20: INFO: Looking for file 'userdata_74.img' 13:04:20: INFO: Looking for file 'userdata_75.img' 13:04:20: INFO: Looking for file 'userdata_76.img' 13:04:20: INFO: Looking for file 'userdata_77.img' 13:04:20: INFO: Looking for file 'userdata_78.img' 13:04:20: INFO: Looking for file 'userdata_79.img' 13:04:20: INFO: Looking for file 'userdata_80.img' 13:04:20: INFO: Looking for file 'userdata_81.img' 13:04:20: INFO: Looking for file 'userdata_82.img' 13:04:20: INFO: Looking for file 'userdata_83.img' 13:04:20: INFO: Looking for file 'userdata_84.img' 13:04:20: INFO: Looking for file 'userdata_85.img' 13:04:20: INFO: Looking for file 'userdata_86.img' 13:04:20: INFO: Looking for file 'userdata_87.img' 13:04:20: INFO: Looking for file 'userdata_88.img' 13:04:20: INFO: Looking for file 'gpt_main0.bin' 13:04:20: INFO: Looking for file 'gpt_backup0.bin' 13:04:20: INFO: Total to be tansferd with <program> or <read> is 1.38 GB 13:04:20: INFO: Sending <configure> 13:04:20: INFO: TARGET SAID: 'Host's payload to target size is too large' 13:04:20: INFO: TARGET SAID: 'logbuf@0x0801DC08 fh@0x0801AA70' 13:04:20: INFO: fh.attrs.MaxPayloadSizeToTargetInBytes = 16384 13:04:20: INFO: fh.attrs.MaxPayloadSizeToTargetInBytesSupported = 16384 13:04:20: INFO: Target returned NAK for your <configure> but it does not seem to be an error. This is ok, fh_loader.exe attributes updated 13:04:20: INFO: In handleProgram('NON-HLOS.bin') 13:04:20: INFO: Looking for file 'NON-HLOS.bin' 13:04:20: INFO: ======================================================= 13:04:20: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\NON-HLOS.bin'} 13:04:20: INFO: {<program> (53.95 MB) 110499 sectors needed at location 131072 on LUN 0} 13:04:20: INFO: ======================================================= 13:04:20: INFO: TARGET SAID: 'logbuf@0x0801DC08 fh@0x0801AA70' 13:04:20: INFO: TARGET SAID: 'start 131072, num 110499' 13:04:22: INFO: Overall to target 2.012 seconds (12.41 MBps) 13:04:22: INFO: {percent files transferred 1.77%} 13:04:24: INFO: Overall to target 4.025 seconds (13.07 MBps) 13:04:24: INFO: {percent files transferred 3.73%} 13:04:24: INFO: Overall to target 4.118 seconds (13.10 MBps) 13:04:24: INFO: {percent files transferred 3.83%} 13:04:24: INFO: TARGET SAID: 'Finished sector address 241571' 13:04:24: INFO: 13:04:24: INFO: ======================================================= 13:04:24: INFO: ==================== {SUCCESS} ======================== 13:04:24: INFO: ======================================================= 13:04:24: INFO: {percent files transferred 3.83%} 13:04:24: INFO: In handleProgram('sbl1.mbn') 13:04:24: INFO: Looking for file 'sbl1.mbn' 13:04:24: INFO: ======================================================= 13:04:24: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\sbl1.mbn'} 13:04:24: INFO: {<program> (284.82 KB) 570 sectors needed at location 262162 on LUN 0} 13:04:24: INFO: ======================================================= 13:04:24: INFO: TARGET SAID: 'start 262162, num 570' 13:04:24: INFO: FILE ACCESS SLOW!! 285.00 KB in 0.015 seconds ( 18.55 MBps) --- Overall to target 0.047 seconds (5.92 MBps) 13:04:24: INFO: {percent files transferred 3.85%} 13:04:25: INFO: TARGET SAID: 'Finished sector address 262732' 13:04:25: INFO: 13:04:25: INFO: ======================================================= 13:04:25: INFO: ==================== {SUCCESS} ======================== 13:04:25: INFO: ======================================================= 13:04:25: INFO: {percent files transferred 3.85%} 13:04:25: INFO: In handleProgram('sbl1.mbn') 13:04:25: INFO: Looking for file 'sbl1.mbn' 13:04:25: INFO: ======================================================= 13:04:25: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\sbl1.mbn'} 13:04:25: INFO: {<program> (284.82 KB) 570 sectors needed at location 263186 on LUN 0} 13:04:25: INFO: ======================================================= 13:04:25: INFO: TARGET SAID: 'start 263186, num 570' 13:04:25: INFO: FILE ACCESS SLOW!! 285.00 KB in 0.015 seconds ( 18.55 MBps) --- Overall to target 0.047 seconds (5.92 MBps) 13:04:25: INFO: {percent files transferred 3.87%} 13:04:25: INFO: TARGET SAID: 'Finished sector address 263756' 13:04:25: INFO: 13:04:25: INFO: ======================================================= 13:04:25: INFO: ==================== {SUCCESS} ======================== 13:04:25: INFO: ======================================================= 13:04:25: INFO: {percent files transferred 3.87%} 13:04:25: INFO: In handleProgram('rpm.mbn') 13:04:25: INFO: Looking for file 'rpm.mbn' 13:04:25: INFO: ======================================================= 13:04:25: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\rpm.mbn'} 13:04:25: INFO: {<program> (156.60 KB) 314 sectors needed at location 264210 on LUN 0} 13:04:25: INFO: ======================================================= 13:04:25: INFO: TARGET SAID: 'start 264210, num 314' 13:04:25: INFO: FILE ACCESS SLOW!! 157.00 KB in 0.015 seconds ( 10.22 MBps) --- Overall to target 0.031 seconds (4.95 MBps) 13:04:25: INFO: {percent files transferred 3.88%} 13:04:25: INFO: TARGET SAID: 'Finished sector address 264524' 13:04:25: INFO: 13:04:25: INFO: ======================================================= 13:04:25: INFO: ==================== {SUCCESS} ======================== 13:04:25: INFO: ======================================================= 13:04:25: INFO: {percent files transferred 3.88%} 13:04:25: INFO: In handleProgram('rpm.mbn') 13:04:25: INFO: Looking for file 'rpm.mbn' 13:04:25: INFO: ======================================================= 13:04:25: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\rpm.mbn'} 13:04:25: INFO: {<program> (156.60 KB) 314 sectors needed at location 265234 on LUN 0} 13:04:25: INFO: ======================================================= 13:04:25: INFO: TARGET SAID: 'start 265234, num 314' 13:04:25: INFO: FILE ACCESS SLOW!! 157.00 KB in 0.015 seconds ( 10.22 MBps) --- Overall to target 0.031 seconds (4.95 MBps) 13:04:25: INFO: {percent files transferred 3.89%} 13:04:25: INFO: TARGET SAID: 'Finished sector address 265548' 13:04:25: INFO: 13:04:25: INFO: ======================================================= 13:04:25: INFO: ==================== {SUCCESS} ======================== 13:04:25: INFO: ======================================================= 13:04:25: INFO: {percent files transferred 3.89%} 13:04:25: INFO: In handleProgram('tz.mbn') 13:04:25: INFO: Looking for file 'tz.mbn' 13:04:25: INFO: ======================================================= 13:04:25: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\tz.mbn'} 13:04:25: INFO: {<program> (500.31 KB) 1001 sectors needed at location 266258 on LUN 0} 13:04:25: INFO: ======================================================= 13:04:25: INFO: TARGET SAID: 'start 266258, num 1001' 13:04:26: INFO: FILE ACCESS SLOW!! 500.50 KB in 0.015 seconds ( 32.58 MBps) --- Overall to target 0.094 seconds (5.20 MBps) 13:04:26: INFO: {percent files transferred 3.93%} 13:04:26: INFO: TARGET SAID: 'Finished sector address 267259' 13:04:26: INFO: 13:04:26: INFO: ======================================================= 13:04:26: INFO: ==================== {SUCCESS} ======================== 13:04:26: INFO: ======================================================= 13:04:26: INFO: {percent files transferred 3.93%} 13:04:26: INFO: In handleProgram('tz.mbn') 13:04:26: INFO: Looking for file 'tz.mbn' 13:04:26: INFO: ======================================================= 13:04:26: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\tz.mbn'} 13:04:26: INFO: {<program> (500.31 KB) 1001 sectors needed at location 267282 on LUN 0} 13:04:26: INFO: ======================================================= 13:04:26: INFO: TARGET SAID: 'start 267282, num 1001' 13:04:26: INFO: FILE ACCESS SLOW!! 500.50 KB in 0.015 seconds ( 32.58 MBps) --- Overall to target 0.062 seconds (7.88 MBps) 13:04:26: INFO: {percent files transferred 3.96%} 13:04:26: INFO: TARGET SAID: 'Finished sector address 268283' 13:04:26: INFO: 13:04:26: INFO: ======================================================= 13:04:26: INFO: ==================== {SUCCESS} ======================== 13:04:26: INFO: ======================================================= 13:04:26: INFO: {percent files transferred 3.96%} 13:04:26: INFO: In handleProgram('hyp.mbn') 13:04:26: INFO: Looking for file 'hyp.mbn' 13:04:26: INFO: ======================================================= 13:04:26: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\hyp.mbn'} 13:04:26: INFO: {<program> (72.00 KB) 144 sectors needed at location 268306 on LUN 0} 13:04:26: INFO: ======================================================= 13:04:26: INFO: TARGET SAID: 'start 268306, num 144' 13:04:26: INFO: FILE ACCESS SLOW!! 72.00 KB in 0.015 seconds ( 4.69 MBps) --- Overall to target 0.031 seconds (2.27 MBps) 13:04:26: INFO: {percent files transferred 3.97%} 13:04:26: INFO: TARGET SAID: 'Finished sector address 268450' 13:04:26: INFO: 13:04:26: INFO: ======================================================= 13:04:26: INFO: ==================== {SUCCESS} ======================== 13:04:26: INFO: ======================================================= 13:04:26: INFO: {percent files transferred 3.97%} 13:04:26: INFO: In handleProgram('hyp.mbn') 13:04:26: INFO: Looking for file 'hyp.mbn' 13:04:26: INFO: ======================================================= 13:04:26: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\hyp.mbn'} 13:04:26: INFO: {<program> (72.00 KB) 144 sectors needed at location 269330 on LUN 0} 13:04:26: INFO: ======================================================= 13:04:26: INFO: TARGET SAID: 'start 269330, num 144' 13:04:26: INFO: FILE ACCESS SLOW!! 72.00 KB in 0.015 seconds ( 4.69 MBps) --- Overall to target 0.032 seconds (2.20 MBps) 13:04:26: INFO: {percent files transferred 3.97%} 13:04:26: INFO: TARGET SAID: 'Finished sector address 269474' 13:04:26: INFO: 13:04:26: INFO: ======================================================= 13:04:26: INFO: ==================== {SUCCESS} ======================== 13:04:26: INFO: ======================================================= 13:04:26: INFO: {percent files transferred 3.97%} 13:04:26: INFO: In handleProgram('sec.dat') 13:04:26: INFO: Looking for file 'sec.dat' 13:04:26: INFO: ======================================================= 13:04:26: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\sec.dat'} 13:04:26: INFO: {<program> (428.00 B) 1 sectors needed at location 396352 on LUN 0} 13:04:26: INFO: ======================================================= 13:04:27: INFO: TARGET SAID: 'start 396352, num 1' 13:04:27: INFO: FILE ACCESS SLOW!! 512.00 B in 0.015 seconds ( 33.33 KBps) --- Overall to target 0.010 seconds (50.00 KBps) 13:04:27: INFO: {percent files transferred 3.97%} 13:04:27: INFO: TARGET SAID: 'Finished sector address 396353' 13:04:27: INFO: 13:04:27: INFO: ======================================================= 13:04:27: INFO: ==================== {SUCCESS} ======================== 13:04:27: INFO: ======================================================= 13:04:27: INFO: {percent files transferred 3.97%} 13:04:27: INFO: In handleProgram('emmc_appsboot.mbn') 13:04:27: INFO: Looking for file 'emmc_appsboot.mbn' 13:04:27: INFO: ======================================================= 13:04:27: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\emmc_appsboot.mbn'} 13:04:27: INFO: {<program> (589.30 KB) 1179 sectors needed at location 396384 on LUN 0} 13:04:27: INFO: ======================================================= 13:04:27: INFO: TARGET SAID: 'start 396384, num 1179' 13:04:27: INFO: FILE ACCESS SLOW!! 589.50 KB in 0.015 seconds ( 38.38 MBps) --- Overall to target 0.063 seconds (9.14 MBps) 13:04:27: INFO: {percent files transferred 4.01%} 13:04:27: INFO: TARGET SAID: 'Finished sector address 397563' 13:04:27: INFO: 13:04:27: INFO: ======================================================= 13:04:27: INFO: ==================== {SUCCESS} ======================== 13:04:27: INFO: ======================================================= 13:04:27: INFO: {percent files transferred 4.01%} 13:04:27: INFO: In handleProgram('emmc_appsboot.mbn') 13:04:27: INFO: Looking for file 'emmc_appsboot.mbn' 13:04:27: INFO: ======================================================= 13:04:27: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\emmc_appsboot.mbn'} 13:04:27: INFO: {<program> (589.30 KB) 1179 sectors needed at location 398432 on LUN 0} 13:04:27: INFO: ======================================================= 13:04:27: INFO: TARGET SAID: 'start 398432, num 1179' 13:04:27: INFO: FILE ACCESS SLOW!! 589.50 KB in 0.015 seconds ( 38.38 MBps) --- Overall to target 0.063 seconds (9.14 MBps) 13:04:27: INFO: {percent files transferred 4.05%} 13:04:27: INFO: TARGET SAID: 'Finished sector address 399611' 13:04:27: INFO: 13:04:27: INFO: ======================================================= 13:04:27: INFO: ==================== {SUCCESS} ======================== 13:04:27: INFO: ======================================================= 13:04:27: INFO: {percent files transferred 4.05%} 13:04:27: INFO: In handleProgram('splash.img') 13:04:27: INFO: Looking for file 'splash.img' 13:04:27: INFO: ======================================================= 13:04:27: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\splash.img'} 13:04:27: INFO: {<program> (5.93 MB) 12151 sectors needed at location 402528 on LUN 0} 13:04:27: INFO: ======================================================= 13:04:27: INFO: TARGET SAID: 'start 402528, num 12151' 13:04:28: INFO: Overall to target 0.468 seconds (12.68 MBps) 13:04:28: INFO: {percent files transferred 4.47%} 13:04:28: INFO: TARGET SAID: 'Finished sector address 414679' 13:04:28: INFO: 13:04:28: INFO: ======================================================= 13:04:28: INFO: ==================== {SUCCESS} ======================== 13:04:28: INFO: ======================================================= 13:04:28: INFO: {percent files transferred 4.47%} 13:04:28: INFO: In handleProgram('boot.img') 13:04:28: INFO: Looking for file 'boot.img' 13:04:28: INFO: ======================================================= 13:04:28: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\boot.img'} 13:04:28: INFO: {<program> (26.12 MB) 53488 sectors needed at location 443488 on LUN 0} 13:04:28: INFO: ======================================================= 13:04:28: INFO: TARGET SAID: 'start 443488, num 53488' 13:04:30: INFO: Overall to target 2.013 seconds (12.71 MBps) 13:04:30: INFO: {percent files transferred 6.29%} 13:04:30: INFO: Overall to target 2.044 seconds (12.78 MBps) 13:04:30: INFO: {percent files transferred 6.33%} 13:04:30: INFO: TARGET SAID: 'Finished sector address 496976' 13:04:30: INFO: 13:04:30: INFO: ======================================================= 13:04:30: INFO: ==================== {SUCCESS} ======================== 13:04:30: INFO: ======================================================= 13:04:30: INFO: {percent files transferred 6.33%} 13:04:30: INFO: In handleProgram('recovery.img') 13:04:30: INFO: Looking for file 'recovery.img' 13:04:30: INFO: ======================================================= 13:04:30: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\recovery.img'} 13:04:30: INFO: {<program> (29.51 MB) 60444 sectors needed at location 525408 on LUN 0} 13:04:30: INFO: ======================================================= 13:04:30: INFO: TARGET SAID: 'start 525408, num 60444' 13:04:32: INFO: Overall to target 2.013 seconds (12.63 MBps) 13:04:32: INFO: {percent files transferred 8.13%} 13:04:33: INFO: Overall to target 2.309 seconds (12.78 MBps) 13:04:33: INFO: {percent files transferred 8.42%} 13:04:33: INFO: TARGET SAID: 'Finished sector address 585852' 13:04:33: INFO: 13:04:33: INFO: ======================================================= 13:04:33: INFO: ==================== {SUCCESS} ======================== 13:04:33: INFO: ======================================================= 13:04:33: INFO: {percent files transferred 8.42%} 13:04:33: INFO: In handleProgram('system_1.unsparse') 13:04:33: INFO: Looking for file 'system_1.unsparse' 13:04:33: INFO: ======================================================= 13:04:33: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\system_1.unsparse'} 13:04:33: INFO: {<program> (128.00 MB) 262144 sectors needed at location 607328 on LUN 0} 13:04:33: INFO: ======================================================= 13:04:33: INFO: TARGET SAID: 'start 607328, num 262144' 13:04:35: INFO: Overall to target 2.012 seconds (13.44 MBps) 13:04:35: INFO: {percent files transferred 10.34%} 13:04:37: INFO: Overall to target 4.025 seconds (13.12 MBps) 13:04:37: INFO: {percent files transferred 12.17%} 13:04:39: INFO: Overall to target 6.037 seconds (13.34 MBps) 13:04:39: INFO: {percent files transferred 14.14%} 13:04:41: INFO: Overall to target 8.049 seconds (13.43 MBps) 13:04:41: INFO: {percent files transferred 16.10%} 13:04:42: INFO: Overall to target 9.578 seconds (13.36 MBps) 13:04:42: INFO: {percent files transferred 17.51%} 13:04:42: INFO: TARGET SAID: 'Finished sector address 869472' 13:04:42: INFO: 13:04:42: INFO: ======================================================= 13:04:42: INFO: ==================== {SUCCESS} ======================== 13:04:42: INFO: ======================================================= 13:04:42: INFO: {percent files transferred 17.51%} 13:04:42: INFO: In handleProgram('system_2.unsparse') 13:04:42: INFO: Looking for file 'system_2.unsparse' 13:04:42: INFO: ======================================================= 13:04:42: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\system_2.unsparse'} 13:04:42: INFO: {<program> (128.00 MB) 262136 sectors needed at location 869472 on LUN 0} 13:04:42: INFO: ======================================================= 13:04:43: INFO: TARGET SAID: 'start 869472, num 262136' 13:04:45: INFO: Overall to target 2.012 seconds (13.53 MBps) 13:04:45: INFO: {percent files transferred 19.44%} 13:04:47: INFO: Overall to target 4.024 seconds (13.38 MBps) 13:04:47: INFO: {percent files transferred 21.33%} 13:04:49: INFO: Overall to target 6.037 seconds (13.50 MBps) 13:04:49: INFO: {percent files transferred 23.30%} 13:04:51: INFO: Overall to target 8.049 seconds (13.57 MBps) 13:04:51: INFO: {percent files transferred 25.26%} 13:04:52: INFO: Overall to target 9.438 seconds (13.56 MBps) 13:04:52: INFO: {percent files transferred 26.60%} 13:04:52: INFO: TARGET SAID: 'Finished sector address 1131608' 13:04:52: INFO: 13:04:52: INFO: ======================================================= 13:04:52: INFO: ==================== {SUCCESS} ======================== 13:04:52: INFO: ======================================================= 13:04:52: INFO: {percent files transferred 26.60%} 13:04:52: INFO: In handleProgram('system_3.unsparse') 13:04:52: INFO: Looking for file 'system_3.unsparse' 13:04:52: INFO: ======================================================= 13:04:52: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\system_3.unsparse'} 13:04:52: INFO: {<program> (128.00 MB) 262136 sectors needed at location 1131616 on LUN 0} 13:04:52: INFO: ======================================================= 13:04:52: INFO: TARGET SAID: 'start 1131616, num 262136' 13:04:54: INFO: Overall to target 2.012 seconds (12.04 MBps) 13:04:54: INFO: {percent files transferred 28.32%} 13:04:56: INFO: Overall to target 4.025 seconds (12.88 MBps) 13:04:56: INFO: {percent files transferred 30.28%} 13:04:58: INFO: Overall to target 6.037 seconds (13.20 MBps) 13:04:58: INFO: {percent files transferred 32.25%} 13:05:00: INFO: Overall to target 8.050 seconds (13.34 MBps) 13:05:00: INFO: {percent files transferred 34.22%} 13:05:02: INFO: Overall to target 9.656 seconds (13.26 MBps) 13:05:02: INFO: {percent files transferred 35.69%} 13:05:02: INFO: TARGET SAID: 'Finished sector address 1393752' 13:05:02: INFO: 13:05:02: INFO: ======================================================= 13:05:02: INFO: ==================== {SUCCESS} ======================== 13:05:02: INFO: ======================================================= 13:05:02: INFO: {percent files transferred 35.69%} 13:05:02: INFO: In handleProgram('system_4.unsparse') 13:05:02: INFO: Looking for file 'system_4.unsparse' 13:05:02: INFO: ======================================================= 13:05:02: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\system_4.unsparse'} 13:05:02: INFO: {<program> (128.00 MB) 262136 sectors needed at location 1393760 on LUN 0} 13:05:02: INFO: ======================================================= 13:05:02: INFO: TARGET SAID: 'start 1393760, num 262136' 13:05:04: INFO: Overall to target 2.012 seconds (12.18 MBps) 13:05:04: INFO: {percent files transferred 37.42%} 13:05:06: INFO: Overall to target 4.025 seconds (12.97 MBps) 13:05:06: INFO: {percent files transferred 39.39%} 13:05:08: INFO: Overall to target 6.037 seconds (13.24 MBps) 13:05:08: INFO: {percent files transferred 41.36%} 13:05:10: INFO: Overall to target 8.050 seconds (13.35 MBps) 13:05:10: INFO: {percent files transferred 43.32%} 13:05:12: INFO: Overall to target 9.547 seconds (13.41 MBps) 13:05:12: INFO: {percent files transferred 44.77%} 13:05:12: INFO: TARGET SAID: 'Finished sector address 1655896' 13:05:12: INFO: 13:05:12: INFO: ======================================================= 13:05:12: INFO: ==================== {SUCCESS} ======================== 13:05:12: INFO: ======================================================= 13:05:12: INFO: {percent files transferred 44.77%} 13:05:12: INFO: In handleProgram('system_5.unsparse') 13:05:12: INFO: Looking for file 'system_5.unsparse' 13:05:12: INFO: ======================================================= 13:05:12: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\system_5.unsparse'} 13:05:12: INFO: {<program> (128.00 MB) 262136 sectors needed at location 1655904 on LUN 0} 13:05:12: INFO: ======================================================= 13:05:12: INFO: TARGET SAID: 'start 1655904, num 262136' 13:05:14: INFO: Overall to target 2.012 seconds (12.66 MBps) 13:05:14: INFO: {percent files transferred 46.58%} 13:05:16: INFO: Overall to target 4.024 seconds (13.22 MBps) 13:05:16: INFO: {percent files transferred 48.55%} 13:05:18: INFO: Overall to target 6.037 seconds (13.38 MBps) 13:05:18: INFO: {percent files transferred 50.51%} 13:05:20: INFO: Overall to target 8.049 seconds (13.48 MBps) 13:05:20: INFO: {percent files transferred 52.48%} 13:05:21: INFO: Overall to target 9.469 seconds (13.52 MBps) 13:05:21: INFO: {percent files transferred 53.86%} 13:05:21: INFO: TARGET SAID: 'Finished sector address 1918040' 13:05:21: INFO: 13:05:21: INFO: ======================================================= 13:05:21: INFO: ==================== {SUCCESS} ======================== 13:05:21: INFO: ======================================================= 13:05:21: INFO: {percent files transferred 53.86%} 13:05:21: INFO: In handleProgram('system_6.unsparse') 13:05:21: INFO: Looking for file 'system_6.unsparse' 13:05:21: INFO: ======================================================= 13:05:21: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\system_6.unsparse'} 13:05:21: INFO: {<program> (128.00 MB) 262136 sectors needed at location 1918048 on LUN 0} 13:05:21: INFO: ======================================================= 13:05:22: INFO: TARGET SAID: 'start 1918048, num 262136' 13:05:24: INFO: Overall to target 2.013 seconds (12.50 MBps) 13:05:24: INFO: {percent files transferred 55.65%} 13:05:26: INFO: Overall to target 4.025 seconds (12.72 MBps) 13:05:26: INFO: {percent files transferred 57.49%} 13:05:28: INFO: Overall to target 6.053 seconds (12.90 MBps) 13:05:28: INFO: {percent files transferred 59.40%} 13:05:30: INFO: Overall to target 8.065 seconds (13.10 MBps) 13:05:30: INFO: {percent files transferred 61.36%} 13:05:31: INFO: Overall to target 9.781 seconds (13.09 MBps) 13:05:31: INFO: {percent files transferred 62.95%} 13:05:31: INFO: TARGET SAID: 'Finished sector address 2180184' 13:05:31: INFO: 13:05:31: INFO: ======================================================= 13:05:31: INFO: ==================== {SUCCESS} ======================== 13:05:31: INFO: ======================================================= 13:05:31: INFO: {percent files transferred 62.95%} 13:05:31: INFO: In handleProgram('system_7.unsparse') 13:05:31: INFO: Looking for file 'system_7.unsparse' 13:05:31: INFO: ======================================================= 13:05:31: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\system_7.unsparse'} 13:05:31: INFO: {<program> (103.39 MB) 211736 sectors needed at location 2180192 on LUN 0} 13:05:31: INFO: ======================================================= 13:05:32: INFO: TARGET SAID: 'start 2180192, num 211736' 13:05:34: INFO: Overall to target 2.013 seconds (11.88 MBps) 13:05:34: INFO: {percent files transferred 64.64%} 13:05:36: INFO: Overall to target 4.025 seconds (11.45 MBps) 13:05:36: INFO: {percent files transferred 66.22%} 13:05:38: INFO: Overall to target 6.038 seconds (11.39 MBps) 13:05:38: INFO: {percent files transferred 67.83%} 13:05:40: INFO: FILE ACCESS SLOW!! 91.20 MB in 1.031 seconds ( 88.46 MBps) --- Overall to target 8.050 seconds (11.33 MBps) 13:05:40: INFO: {percent files transferred 69.42%} 13:05:41: INFO: Overall to target 9.033 seconds (11.45 MBps) 13:05:41: INFO: {percent files transferred 70.29%} 13:05:41: INFO: TARGET SAID: 'Finished sector address 2391928' 13:05:41: INFO: 13:05:41: INFO: ======================================================= 13:05:41: INFO: ==================== {SUCCESS} ======================== 13:05:41: INFO: ======================================================= 13:05:41: INFO: {percent files transferred 70.29%} 13:05:41: INFO: In handleProgram('system_8.unsparse') 13:05:41: INFO: Looking for file 'system_8.unsparse' 13:05:41: INFO: ======================================================= 13:05:41: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\system_8.unsparse'} 13:05:41: INFO: {<program> (128.00 MB) 262136 sectors needed at location 2442336 on LUN 0} 13:05:41: INFO: ======================================================= 13:05:41: INFO: TARGET SAID: 'start 2442336, num 262136' 13:05:43: INFO: Overall to target 2.012 seconds (8.37 MBps) 13:05:43: INFO: {percent files transferred 71.48%} 13:05:45: INFO: Overall to target 4.025 seconds (10.54 MBps) 13:05:45: INFO: {percent files transferred 73.30%} 13:05:47: INFO: Overall to target 6.037 seconds (11.38 MBps) 13:05:47: INFO: {percent files transferred 75.16%} 13:05:49: INFO: Overall to target 8.049 seconds (11.49 MBps) 13:05:49: INFO: {percent files transferred 76.85%} 13:05:51: INFO: Overall to target 10.062 seconds (11.73 MBps) 13:05:51: INFO: {percent files transferred 78.67%} 13:05:52: INFO: Overall to target 10.795 seconds (11.86 MBps) 13:05:52: INFO: {percent files transferred 79.37%} 13:05:52: INFO: TARGET SAID: 'Finished sector address 2704472' 13:05:52: INFO: 13:05:52: INFO: ======================================================= 13:05:52: INFO: ==================== {SUCCESS} ======================== 13:05:52: INFO: ======================================================= 13:05:52: INFO: {percent files transferred 79.37%} 13:05:52: INFO: In handleProgram('system_9.unsparse') 13:05:52: INFO: Looking for file 'system_9.unsparse' 13:05:52: INFO: ======================================================= 13:05:52: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\system_9.unsparse'} 13:05:52: INFO: {<program> (2.01 MB) 4112 sectors needed at location 2704480 on LUN 0} 13:05:52: INFO: ======================================================= 13:05:52: INFO: TARGET SAID: 'start 2704480, num 4112' 13:05:52: INFO: Overall to target 0.203 seconds (9.89 MBps) 13:05:52: INFO: {percent files transferred 79.52%} 13:05:52: INFO: TARGET SAID: 'Finished sector address 2708592' 13:05:52: INFO: 13:05:52: INFO: ======================================================= 13:05:52: INFO: ==================== {SUCCESS} ======================== 13:05:52: INFO: ======================================================= 13:05:52: INFO: {percent files transferred 79.52%} 13:05:52: INFO: In handleProgram('system_10.unsparse') 13:05:52: INFO: Looking for file 'system_10.unsparse' 13:05:52: INFO: ======================================================= 13:05:52: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\system_10.unsparse'} 13:05:52: INFO: {<program> (128.00 MB) 262136 sectors needed at location 2966624 on LUN 0} 13:05:52: INFO: ======================================================= 13:05:52: INFO: TARGET SAID: 'start 2966624, num 262136' 13:05:54: INFO: Overall to target 2.013 seconds (12.93 MBps) 13:05:54: INFO: {percent files transferred 81.36%} 13:05:56: INFO: FILE ACCESS SLOW!! 45.75 MB in 0.531 seconds ( 86.16 MBps) --- Overall to target 4.025 seconds (11.37 MBps) 13:05:56: INFO: {percent files transferred 82.76%} 13:05:58: INFO: FILE ACCESS SLOW!! 62.80 MB in 0.797 seconds ( 78.79 MBps) --- Overall to target 6.038 seconds (10.40 MBps) 13:05:58: INFO: {percent files transferred 83.97%} 13:06:00: INFO: Overall to target 8.050 seconds (11.08 MBps) 13:06:00: INFO: {percent files transferred 85.85%} 13:06:02: INFO: Overall to target 10.062 seconds (11.61 MBps) 13:06:02: INFO: {percent files transferred 87.81%} 13:06:03: INFO: Overall to target 10.920 seconds (11.72 MBps) 13:06:03: INFO: {percent files transferred 88.60%} 13:06:03: INFO: TARGET SAID: 'Finished sector address 3228760' 13:06:03: INFO: 13:06:03: INFO: ======================================================= 13:06:03: INFO: ==================== {SUCCESS} ======================== 13:06:03: INFO: ======================================================= 13:06:03: INFO: {percent files transferred 88.60%} 13:06:03: INFO: In handleProgram('system_11.unsparse') 13:06:03: INFO: Looking for file 'system_11.unsparse' 13:06:03: INFO: ======================================================= 13:06:03: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\system_11.unsparse'} 13:06:03: INFO: {<program> (2.01 MB) 4112 sectors needed at location 3228768 on LUN 0} 13:06:03: INFO: ======================================================= 13:06:03: INFO: TARGET SAID: 'start 3228768, num 4112' 13:06:04: INFO: Overall to target 0.219 seconds (9.17 MBps) 13:06:04: INFO: {percent files transferred 88.75%} 13:06:04: INFO: TARGET SAID: 'Finished sector address 3232880' 13:06:04: INFO: 13:06:04: INFO: ======================================================= 13:06:04: INFO: ==================== {SUCCESS} ======================== 13:06:04: INFO: ======================================================= 13:06:04: INFO: {percent files transferred 88.75%} 13:06:04: INFO: In handleProgram('system_12.unsparse') 13:06:04: INFO: Looking for file 'system_12.unsparse' 13:06:04: INFO: ======================================================= 13:06:04: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\system_12.unsparse'} 13:06:04: INFO: {<program> (2.01 MB) 4112 sectors needed at location 3490912 on LUN 0} 13:06:04: INFO: ======================================================= 13:06:04: INFO: TARGET SAID: 'start 3490912, num 4112' 13:06:04: INFO: Overall to target 0.219 seconds (9.17 MBps) 13:06:04: INFO: {percent files transferred 88.89%} 13:06:04: INFO: TARGET SAID: 'Finished sector address 3495024' 13:06:04: INFO: 13:06:04: INFO: ======================================================= 13:06:04: INFO: ==================== {SUCCESS} ======================== 13:06:04: INFO: ======================================================= 13:06:04: INFO: {percent files transferred 88.89%} 13:06:04: INFO: In handleProgram('system_13.unsparse') 13:06:04: INFO: Looking for file 'system_13.unsparse' 13:06:04: INFO: ======================================================= 13:06:04: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\system_13.unsparse'} 13:06:04: INFO: {<program> (2.01 MB) 4112 sectors needed at location 3753056 on LUN 0} 13:06:04: INFO: ======================================================= 13:06:04: INFO: TARGET SAID: 'start 3753056, num 4112' 13:06:04: INFO: Overall to target 0.202 seconds (9.94 MBps) 13:06:04: INFO: {percent files transferred 89.03%} 13:06:04: INFO: TARGET SAID: 'Finished sector address 3757168' 13:06:04: INFO: 13:06:04: INFO: ======================================================= 13:06:04: INFO: ==================== {SUCCESS} ======================== 13:06:04: INFO: ======================================================= 13:06:04: INFO: {percent files transferred 89.03%} 13:06:04: INFO: In handleProgram('system_14.unsparse') 13:06:04: INFO: Looking for file 'system_14.unsparse' 13:06:04: INFO: ======================================================= 13:06:04: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\system_14.unsparse'} 13:06:04: INFO: {<program> (2.01 MB) 4112 sectors needed at location 4015200 on LUN 0} 13:06:04: INFO: ======================================================= 13:06:05: INFO: TARGET SAID: 'start 4015200, num 4112' 13:06:05: INFO: Overall to target 0.187 seconds (10.74 MBps) 13:06:05: INFO: {percent files transferred 89.17%} 13:06:05: INFO: TARGET SAID: 'Finished sector address 4019312' 13:06:05: INFO: 13:06:05: INFO: ======================================================= 13:06:05: INFO: ==================== {SUCCESS} ======================== 13:06:05: INFO: ======================================================= 13:06:05: INFO: {percent files transferred 89.17%} 13:06:05: INFO: In handleProgram('system_15.unsparse') 13:06:05: INFO: Looking for file 'system_15.unsparse' 13:06:05: INFO: ======================================================= 13:06:05: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\system_15.unsparse'} 13:06:05: INFO: {<program> (2.01 MB) 4112 sectors needed at location 4277344 on LUN 0} 13:06:05: INFO: ======================================================= 13:06:05: INFO: TARGET SAID: 'start 4277344, num 4112' 13:06:05: INFO: Overall to target 0.203 seconds (9.89 MBps) 13:06:05: INFO: {percent files transferred 89.32%} 13:06:05: INFO: TARGET SAID: 'Finished sector address 4281456' 13:06:05: INFO: 13:06:05: INFO: ======================================================= 13:06:05: INFO: ==================== {SUCCESS} ======================== 13:06:05: INFO: ======================================================= 13:06:05: INFO: {percent files transferred 89.32%} 13:06:05: INFO: In handleProgram('system_16.unsparse') 13:06:05: INFO: Looking for file 'system_16.unsparse' 13:06:05: INFO: ======================================================= 13:06:05: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\system_16.unsparse'} 13:06:05: INFO: {<program> (2.01 MB) 4112 sectors needed at location 4539488 on LUN 0} 13:06:05: INFO: ======================================================= 13:06:05: INFO: TARGET SAID: 'start 4539488, num 4112' 13:06:06: INFO: Overall to target 0.187 seconds (10.74 MBps) 13:06:06: INFO: {percent files transferred 89.46%} 13:06:06: INFO: TARGET SAID: 'Finished sector address 4543600' 13:06:06: INFO: 13:06:06: INFO: ======================================================= 13:06:06: INFO: ==================== {SUCCESS} ======================== 13:06:06: INFO: ======================================================= 13:06:06: INFO: {percent files transferred 89.46%} 13:06:06: INFO: In handleProgram('system_17.unsparse') 13:06:06: INFO: Looking for file 'system_17.unsparse' 13:06:06: INFO: ======================================================= 13:06:06: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\system_17.unsparse'} 13:06:06: INFO: {<program> (2.01 MB) 4112 sectors needed at location 4801632 on LUN 0} 13:06:06: INFO: ======================================================= 13:06:06: INFO: TARGET SAID: 'start 4801632, num 4112' 13:06:06: INFO: Overall to target 0.187 seconds (10.74 MBps) 13:06:06: INFO: {percent files transferred 89.60%} 13:06:06: INFO: TARGET SAID: 'Finished sector address 4805744' 13:06:06: INFO: 13:06:06: INFO: ======================================================= 13:06:06: INFO: ==================== {SUCCESS} ======================== 13:06:06: INFO: ======================================================= 13:06:06: INFO: {percent files transferred 89.60%} 13:06:06: INFO: In handleProgram('system_18.unsparse') 13:06:06: INFO: Looking for file 'system_18.unsparse' 13:06:06: INFO: ======================================================= 13:06:06: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\system_18.unsparse'} 13:06:06: INFO: {<program> (2.01 MB) 4112 sectors needed at location 5063776 on LUN 0} 13:06:06: INFO: ======================================================= 13:06:06: INFO: TARGET SAID: 'start 5063776, num 4112' 13:06:06: INFO: Overall to target 0.187 seconds (10.74 MBps) 13:06:06: INFO: {percent files transferred 89.74%} 13:06:06: INFO: TARGET SAID: 'Finished sector address 5067888' 13:06:06: INFO: 13:06:06: INFO: ======================================================= 13:06:06: INFO: ==================== {SUCCESS} ======================== 13:06:06: INFO: ======================================================= 13:06:06: INFO: {percent files transferred 89.74%} 13:06:06: INFO: In handleProgram('system_19.unsparse') 13:06:06: INFO: Looking for file 'system_19.unsparse' 13:06:06: INFO: ======================================================= 13:06:06: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\system_19.unsparse'} 13:06:06: INFO: {<program> (2.01 MB) 4112 sectors needed at location 5325920 on LUN 0} 13:06:06: INFO: ======================================================= 13:06:07: INFO: TARGET SAID: 'start 5325920, num 4112' 13:06:07: INFO: Overall to target 0.187 seconds (10.74 MBps) 13:06:07: INFO: {percent files transferred 89.89%} 13:06:07: INFO: TARGET SAID: 'Finished sector address 5330032' 13:06:07: INFO: 13:06:07: INFO: ======================================================= 13:06:07: INFO: ==================== {SUCCESS} ======================== 13:06:07: INFO: ======================================================= 13:06:07: INFO: {percent files transferred 89.89%} 13:06:07: INFO: In handleProgram('system_20.unsparse') 13:06:07: INFO: Looking for file 'system_20.unsparse' 13:06:07: INFO: ======================================================= 13:06:07: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\system_20.unsparse'} 13:06:07: INFO: {<program> (2.01 MB) 4112 sectors needed at location 5588064 on LUN 0} 13:06:07: INFO: ======================================================= 13:06:07: INFO: TARGET SAID: 'start 5588064, num 4112' 13:06:07: INFO: Overall to target 0.187 seconds (10.74 MBps) 13:06:07: INFO: {percent files transferred 90.03%} 13:06:07: INFO: TARGET SAID: 'Finished sector address 5592176' 13:06:07: INFO: 13:06:07: INFO: ======================================================= 13:06:07: INFO: ==================== {SUCCESS} ======================== 13:06:07: INFO: ======================================================= 13:06:07: INFO: {percent files transferred 90.03%} 13:06:07: INFO: In handleProgram('cache_1.img') 13:06:07: INFO: Looking for file 'cache_1.img' 13:06:07: INFO: ======================================================= 13:06:07: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\cache_1.img'} 13:06:07: INFO: {<program> (6.09 MB) 12464 sectors needed at location 5898240 on LUN 0} 13:06:07: INFO: ======================================================= 13:06:07: INFO: TARGET SAID: 'start 5898240, num 12464' 13:06:08: INFO: Overall to target 0.546 seconds (11.15 MBps) 13:06:08: INFO: {percent files transferred 90.46%} 13:06:08: INFO: TARGET SAID: 'Finished sector address 5910704' 13:06:08: INFO: 13:06:08: INFO: ======================================================= 13:06:08: INFO: ==================== {SUCCESS} ======================== 13:06:08: INFO: ======================================================= 13:06:08: INFO: {percent files transferred 90.46%} 13:06:08: INFO: In handleProgram('cache_2.img') 13:06:08: INFO: Looking for file 'cache_2.img' 13:06:08: INFO: ======================================================= 13:06:08: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\cache_2.img'} 13:06:08: INFO: {<program> (8.00 KB) 16 sectors needed at location 6160384 on LUN 0} 13:06:08: INFO: ======================================================= 13:06:08: INFO: TARGET SAID: 'start 6160384, num 16' 13:06:08: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.015 seconds (533.33 KBps) 13:06:08: INFO: {percent files transferred 90.46%} 13:06:08: INFO: TARGET SAID: 'Finished sector address 6160400' 13:06:08: INFO: 13:06:08: INFO: ======================================================= 13:06:08: INFO: ==================== {SUCCESS} ======================== 13:06:08: INFO: ======================================================= 13:06:08: INFO: {percent files transferred 90.46%} 13:06:08: INFO: In handleProgram('cache_3.img') 13:06:08: INFO: Looking for file 'cache_3.img' 13:06:08: INFO: ======================================================= 13:06:08: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\cache_3.img'} 13:06:08: INFO: {<program> (8.00 KB) 16 sectors needed at location 6160520 on LUN 0} 13:06:08: INFO: ======================================================= 13:06:08: INFO: TARGET SAID: 'start 6160520, num 16' 13:06:08: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:08: INFO: {percent files transferred 90.46%} 13:06:08: INFO: TARGET SAID: 'Finished sector address 6160536' 13:06:08: INFO: 13:06:08: INFO: ======================================================= 13:06:08: INFO: ==================== {SUCCESS} ======================== 13:06:08: INFO: ======================================================= 13:06:08: INFO: {percent files transferred 90.46%} 13:06:08: INFO: In handleProgram('userdata_1.img') 13:06:08: INFO: Looking for file 'userdata_1.img' 13:06:08: INFO: ======================================================= 13:06:08: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_1.img'} 13:06:08: INFO: {<program> (7.65 MB) 15664 sectors needed at location 6623232 on LUN 0} 13:06:08: INFO: ======================================================= 13:06:09: INFO: TARGET SAID: 'start 6623232, num 15664' 13:06:09: INFO: Overall to target 0.609 seconds (12.56 MBps) 13:06:09: INFO: {percent files transferred 91.00%} 13:06:09: INFO: TARGET SAID: 'Finished sector address 6638896' 13:06:09: INFO: 13:06:09: INFO: ======================================================= 13:06:09: INFO: ==================== {SUCCESS} ======================== 13:06:09: INFO: ======================================================= 13:06:09: INFO: {percent files transferred 91.00%} 13:06:09: INFO: In handleProgram('userdata_2.img') 13:06:09: INFO: Looking for file 'userdata_2.img' 13:06:09: INFO: ======================================================= 13:06:09: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_2.img'} 13:06:09: INFO: {<program> (8.00 KB) 16 sectors needed at location 6885376 on LUN 0} 13:06:09: INFO: ======================================================= 13:06:09: INFO: TARGET SAID: 'start 6885376, num 16' 13:06:09: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.015 seconds (533.33 KBps) 13:06:09: INFO: {percent files transferred 91.01%} 13:06:10: INFO: TARGET SAID: 'Finished sector address 6885392' 13:06:10: INFO: 13:06:10: INFO: ======================================================= 13:06:10: INFO: ==================== {SUCCESS} ======================== 13:06:10: INFO: ======================================================= 13:06:10: INFO: {percent files transferred 91.01%} 13:06:10: INFO: In handleProgram('userdata_3.img') 13:06:10: INFO: Looking for file 'userdata_3.img' 13:06:10: INFO: ======================================================= 13:06:10: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_3.img'} 13:06:10: INFO: {<program> (8.00 KB) 16 sectors needed at location 6890504 on LUN 0} 13:06:10: INFO: ======================================================= 13:06:10: INFO: TARGET SAID: 'start 6890504, num 16' 13:06:10: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.016 seconds (500.00 KBps) 13:06:10: INFO: {percent files transferred 91.01%} 13:06:10: INFO: TARGET SAID: 'Finished sector address 6890520' 13:06:10: INFO: 13:06:10: INFO: ======================================================= 13:06:10: INFO: ==================== {SUCCESS} ======================== 13:06:10: INFO: ======================================================= 13:06:10: INFO: {percent files transferred 91.01%} 13:06:10: INFO: In handleProgram('userdata_4.img') 13:06:10: INFO: Looking for file 'userdata_4.img' 13:06:10: INFO: ======================================================= 13:06:10: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_4.img'} 13:06:10: INFO: {<program> (8.00 KB) 16 sectors needed at location 7147520 on LUN 0} 13:06:10: INFO: ======================================================= 13:06:10: INFO: TARGET SAID: 'start 7147520, num 16' 13:06:10: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.016 seconds (500.00 KBps) 13:06:10: INFO: {percent files transferred 91.01%} 13:06:10: INFO: TARGET SAID: 'Finished sector address 7147536' 13:06:10: INFO: 13:06:10: INFO: ======================================================= 13:06:10: INFO: ==================== {SUCCESS} ======================== 13:06:10: INFO: ======================================================= 13:06:10: INFO: {percent files transferred 91.01%} 13:06:10: INFO: In handleProgram('userdata_5.img') 13:06:10: INFO: Looking for file 'userdata_5.img' 13:06:10: INFO: ======================================================= 13:06:10: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_5.img'} 13:06:10: INFO: {<program> (126.00 MB) 258048 sectors needed at location 7151632 on LUN 0} 13:06:10: INFO: ======================================================= 13:06:10: INFO: TARGET SAID: 'start 7151632, num 258048' 13:06:12: INFO: Overall to target 2.012 seconds (9.79 MBps) 13:06:12: INFO: {percent files transferred 92.40%} 13:06:14: INFO: Overall to target 4.025 seconds (10.93 MBps) 13:06:14: INFO: {percent files transferred 94.13%} 13:06:16: INFO: Overall to target 6.037 seconds (11.76 MBps) 13:06:16: INFO: {percent files transferred 96.05%} 13:06:18: INFO: Overall to target 8.049 seconds (12.10 MBps) 13:06:18: INFO: {percent files transferred 97.92%} 13:06:20: INFO: Overall to target 10.062 seconds (11.80 MBps) 13:06:20: INFO: {percent files transferred 99.44%} 13:06:21: INFO: Overall to target 10.592 seconds (11.90 MBps) 13:06:21: INFO: {percent files transferred 99.95%} 13:06:21: INFO: TARGET SAID: 'Finished sector address 7409680' 13:06:21: INFO: 13:06:21: INFO: ======================================================= 13:06:21: INFO: ==================== {SUCCESS} ======================== 13:06:21: INFO: ======================================================= 13:06:21: INFO: {percent files transferred 99.95%} 13:06:21: INFO: In handleProgram('userdata_6.img') 13:06:21: INFO: Looking for file 'userdata_6.img' 13:06:21: INFO: ======================================================= 13:06:21: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_6.img'} 13:06:21: INFO: {<program> (8.00 KB) 16 sectors needed at location 7414792 on LUN 0} 13:06:21: INFO: ======================================================= 13:06:21: INFO: TARGET SAID: 'start 7414792, num 16' 13:06:21: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.016 seconds (500.00 KBps) 13:06:21: INFO: {percent files transferred 99.95%} 13:06:21: INFO: TARGET SAID: 'Finished sector address 7414808' 13:06:21: INFO: 13:06:21: INFO: ======================================================= 13:06:21: INFO: ==================== {SUCCESS} ======================== 13:06:21: INFO: ======================================================= 13:06:21: INFO: {percent files transferred 99.95%} 13:06:21: INFO: In handleProgram('userdata_7.img') 13:06:21: INFO: Looking for file 'userdata_7.img' 13:06:21: INFO: ======================================================= 13:06:21: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_7.img'} 13:06:21: INFO: {<program> (8.00 KB) 16 sectors needed at location 7671808 on LUN 0} 13:06:21: INFO: ======================================================= 13:06:21: INFO: TARGET SAID: 'start 7671808, num 16' 13:06:21: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:21: INFO: {percent files transferred 99.95%} 13:06:21: INFO: TARGET SAID: 'Finished sector address 7671824' 13:06:21: INFO: 13:06:21: INFO: ======================================================= 13:06:21: INFO: ==================== {SUCCESS} ======================== 13:06:21: INFO: ======================================================= 13:06:21: INFO: {percent files transferred 99.95%} 13:06:21: INFO: In handleProgram('userdata_8.img') 13:06:21: INFO: Looking for file 'userdata_8.img' 13:06:21: INFO: ======================================================= 13:06:21: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_8.img'} 13:06:21: INFO: {<program> (8.00 KB) 16 sectors needed at location 7933952 on LUN 0} 13:06:21: INFO: ======================================================= 13:06:21: INFO: TARGET SAID: 'start 7933952, num 16' 13:06:21: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.031 seconds (258.06 KBps) 13:06:21: INFO: {percent files transferred 99.95%} 13:06:22: INFO: TARGET SAID: 'Finished sector address 7933968' 13:06:22: INFO: 13:06:22: INFO: ======================================================= 13:06:22: INFO: ==================== {SUCCESS} ======================== 13:06:22: INFO: ======================================================= 13:06:22: INFO: {percent files transferred 99.95%} 13:06:22: INFO: In handleProgram('userdata_9.img') 13:06:22: INFO: Looking for file 'userdata_9.img' 13:06:22: INFO: ======================================================= 13:06:22: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_9.img'} 13:06:22: INFO: {<program> (8.00 KB) 16 sectors needed at location 7939080 on LUN 0} 13:06:22: INFO: ======================================================= 13:06:22: INFO: TARGET SAID: 'start 7939080, num 16' 13:06:22: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.016 seconds (500.00 KBps) 13:06:22: INFO: {percent files transferred 99.95%} 13:06:22: INFO: TARGET SAID: 'Finished sector address 7939096' 13:06:22: INFO: 13:06:22: INFO: ======================================================= 13:06:22: INFO: ==================== {SUCCESS} ======================== 13:06:22: INFO: ======================================================= 13:06:22: INFO: {percent files transferred 99.95%} 13:06:22: INFO: In handleProgram('userdata_10.img') 13:06:22: INFO: Looking for file 'userdata_10.img' 13:06:22: INFO: ======================================================= 13:06:22: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_10.img'} 13:06:22: INFO: {<program> (8.00 KB) 16 sectors needed at location 8196096 on LUN 0} 13:06:22: INFO: ======================================================= 13:06:22: INFO: TARGET SAID: 'start 8196096, num 16' 13:06:22: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.016 seconds (500.00 KBps) 13:06:22: INFO: {percent files transferred 99.95%} 13:06:22: INFO: TARGET SAID: 'Finished sector address 8196112' 13:06:22: INFO: 13:06:22: INFO: ======================================================= 13:06:22: INFO: ==================== {SUCCESS} ======================== 13:06:22: INFO: ======================================================= 13:06:22: INFO: {percent files transferred 99.95%} 13:06:22: INFO: In handleProgram('userdata_11.img') 13:06:22: INFO: Looking for file 'userdata_11.img' 13:06:22: INFO: ======================================================= 13:06:22: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_11.img'} 13:06:22: INFO: {<program> (8.00 KB) 16 sectors needed at location 8458240 on LUN 0} 13:06:22: INFO: ======================================================= 13:06:22: INFO: TARGET SAID: 'start 8458240, num 16' 13:06:22: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:22: INFO: {percent files transferred 99.95%} 13:06:22: INFO: TARGET SAID: 'Finished sector address 8458256' 13:06:22: INFO: 13:06:22: INFO: ======================================================= 13:06:22: INFO: ==================== {SUCCESS} ======================== 13:06:22: INFO: ======================================================= 13:06:22: INFO: {percent files transferred 99.95%} 13:06:22: INFO: In handleProgram('userdata_12.img') 13:06:22: INFO: Looking for file 'userdata_12.img' 13:06:22: INFO: ======================================================= 13:06:22: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_12.img'} 13:06:22: INFO: {<program> (8.00 KB) 16 sectors needed at location 8463368 on LUN 0} 13:06:22: INFO: ======================================================= 13:06:22: INFO: TARGET SAID: 'start 8463368, num 16' 13:06:22: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:22: INFO: {percent files transferred 99.96%} 13:06:22: INFO: TARGET SAID: 'Finished sector address 8463384' 13:06:22: INFO: 13:06:22: INFO: ======================================================= 13:06:22: INFO: ==================== {SUCCESS} ======================== 13:06:22: INFO: ======================================================= 13:06:22: INFO: {percent files transferred 99.96%} 13:06:22: INFO: In handleProgram('userdata_13.img') 13:06:22: INFO: Looking for file 'userdata_13.img' 13:06:22: INFO: ======================================================= 13:06:22: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_13.img'} 13:06:22: INFO: {<program> (8.00 KB) 16 sectors needed at location 8720384 on LUN 0} 13:06:22: INFO: ======================================================= 13:06:22: INFO: TARGET SAID: 'start 8720384, num 16' 13:06:22: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:22: INFO: {percent files transferred 99.96%} 13:06:23: INFO: TARGET SAID: 'Finished sector address 8720400' 13:06:23: INFO: 13:06:23: INFO: ======================================================= 13:06:23: INFO: ==================== {SUCCESS} ======================== 13:06:23: INFO: ======================================================= 13:06:23: INFO: {percent files transferred 99.96%} 13:06:23: INFO: In handleProgram('userdata_14.img') 13:06:23: INFO: Looking for file 'userdata_14.img' 13:06:23: INFO: ======================================================= 13:06:23: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_14.img'} 13:06:23: INFO: {<program> (8.00 KB) 16 sectors needed at location 8982528 on LUN 0} 13:06:23: INFO: ======================================================= 13:06:23: INFO: TARGET SAID: 'start 8982528, num 16' 13:06:23: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:23: INFO: {percent files transferred 99.96%} 13:06:23: INFO: TARGET SAID: 'Finished sector address 8982544' 13:06:23: INFO: 13:06:23: INFO: ======================================================= 13:06:23: INFO: ==================== {SUCCESS} ======================== 13:06:23: INFO: ======================================================= 13:06:23: INFO: {percent files transferred 99.96%} 13:06:23: INFO: In handleProgram('userdata_15.img') 13:06:23: INFO: Looking for file 'userdata_15.img' 13:06:23: INFO: ======================================================= 13:06:23: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_15.img'} 13:06:23: INFO: {<program> (8.00 KB) 16 sectors needed at location 8987656 on LUN 0} 13:06:23: INFO: ======================================================= 13:06:23: INFO: TARGET SAID: 'start 8987656, num 16' 13:06:23: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:23: INFO: {percent files transferred 99.96%} 13:06:23: INFO: TARGET SAID: 'Finished sector address 8987672' 13:06:23: INFO: 13:06:23: INFO: ======================================================= 13:06:23: INFO: ==================== {SUCCESS} ======================== 13:06:23: INFO: ======================================================= 13:06:23: INFO: {percent files transferred 99.96%} 13:06:23: INFO: In handleProgram('userdata_16.img') 13:06:23: INFO: Looking for file 'userdata_16.img' 13:06:23: INFO: ======================================================= 13:06:23: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_16.img'} 13:06:23: INFO: {<program> (8.00 KB) 16 sectors needed at location 9244672 on LUN 0} 13:06:23: INFO: ======================================================= 13:06:23: INFO: TARGET SAID: 'start 9244672, num 16' 13:06:23: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:23: INFO: {percent files transferred 99.96%} 13:06:23: INFO: TARGET SAID: 'Finished sector address 9244688' 13:06:23: INFO: 13:06:23: INFO: ======================================================= 13:06:23: INFO: ==================== {SUCCESS} ======================== 13:06:23: INFO: ======================================================= 13:06:23: INFO: {percent files transferred 99.96%} 13:06:23: INFO: In handleProgram('userdata_17.img') 13:06:23: INFO: Looking for file 'userdata_17.img' 13:06:23: INFO: ======================================================= 13:06:23: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_17.img'} 13:06:23: INFO: {<program> (8.00 KB) 16 sectors needed at location 9506816 on LUN 0} 13:06:23: INFO: ======================================================= 13:06:23: INFO: TARGET SAID: 'start 9506816, num 16' 13:06:23: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:23: INFO: {percent files transferred 99.96%} 13:06:23: INFO: TARGET SAID: 'Finished sector address 9506832' 13:06:23: INFO: 13:06:23: INFO: ======================================================= 13:06:23: INFO: ==================== {SUCCESS} ======================== 13:06:23: INFO: ======================================================= 13:06:23: INFO: {percent files transferred 99.96%} 13:06:23: INFO: In handleProgram('userdata_18.img') 13:06:23: INFO: Looking for file 'userdata_18.img' 13:06:23: INFO: ======================================================= 13:06:23: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_18.img'} 13:06:23: INFO: {<program> (8.00 KB) 16 sectors needed at location 9768960 on LUN 0} 13:06:23: INFO: ======================================================= 13:06:24: INFO: TARGET SAID: 'start 9768960, num 16' 13:06:24: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.015 seconds (533.33 KBps) 13:06:24: INFO: {percent files transferred 99.96%} 13:06:24: INFO: TARGET SAID: 'Finished sector address 9768976' 13:06:24: INFO: 13:06:24: INFO: ======================================================= 13:06:24: INFO: ==================== {SUCCESS} ======================== 13:06:24: INFO: ======================================================= 13:06:24: INFO: {percent files transferred 99.96%} 13:06:24: INFO: In handleProgram('userdata_19.img') 13:06:24: INFO: Looking for file 'userdata_19.img' 13:06:24: INFO: ======================================================= 13:06:24: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_19.img'} 13:06:24: INFO: {<program> (8.00 KB) 16 sectors needed at location 10031104 on LUN 0} 13:06:24: INFO: ======================================================= 13:06:24: INFO: TARGET SAID: 'start 10031104, num 16' 13:06:24: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:24: INFO: {percent files transferred 99.96%} 13:06:24: INFO: TARGET SAID: 'Finished sector address 10031120' 13:06:24: INFO: 13:06:24: INFO: ======================================================= 13:06:24: INFO: ==================== {SUCCESS} ======================== 13:06:24: INFO: ======================================================= 13:06:24: INFO: {percent files transferred 99.96%} 13:06:24: INFO: In handleProgram('userdata_20.img') 13:06:24: INFO: Looking for file 'userdata_20.img' 13:06:24: INFO: ======================================================= 13:06:24: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_20.img'} 13:06:24: INFO: {<program> (8.00 KB) 16 sectors needed at location 10293248 on LUN 0} 13:06:24: INFO: ======================================================= 13:06:24: INFO: TARGET SAID: 'start 10293248, num 16' 13:06:24: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:24: INFO: {percent files transferred 99.96%} 13:06:24: INFO: TARGET SAID: 'Finished sector address 10293264' 13:06:24: INFO: 13:06:24: INFO: ======================================================= 13:06:24: INFO: ==================== {SUCCESS} ======================== 13:06:24: INFO: ======================================================= 13:06:24: INFO: {percent files transferred 99.96%} 13:06:24: INFO: In handleProgram('userdata_21.img') 13:06:24: INFO: Looking for file 'userdata_21.img' 13:06:24: INFO: ======================================================= 13:06:24: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_21.img'} 13:06:24: INFO: {<program> (8.00 KB) 16 sectors needed at location 10555392 on LUN 0} 13:06:24: INFO: ======================================================= 13:06:24: INFO: TARGET SAID: 'start 10555392, num 16' 13:06:24: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:24: INFO: {percent files transferred 99.96%} 13:06:24: INFO: TARGET SAID: 'Finished sector address 10555408' 13:06:24: INFO: 13:06:24: INFO: ======================================================= 13:06:24: INFO: ==================== {SUCCESS} ======================== 13:06:24: INFO: ======================================================= 13:06:24: INFO: {percent files transferred 99.96%} 13:06:24: INFO: In handleProgram('userdata_22.img') 13:06:24: INFO: Looking for file 'userdata_22.img' 13:06:24: INFO: ======================================================= 13:06:24: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_22.img'} 13:06:24: INFO: {<program> (8.00 KB) 16 sectors needed at location 10817536 on LUN 0} 13:06:24: INFO: ======================================================= 13:06:24: INFO: TARGET SAID: 'start 10817536, num 16' 13:06:24: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:24: INFO: {percent files transferred 99.96%} 13:06:25: INFO: TARGET SAID: 'Finished sector address 10817552' 13:06:25: INFO: 13:06:25: INFO: ======================================================= 13:06:25: INFO: ==================== {SUCCESS} ======================== 13:06:25: INFO: ======================================================= 13:06:25: INFO: {percent files transferred 99.96%} 13:06:25: INFO: In handleProgram('userdata_23.img') 13:06:25: INFO: Looking for file 'userdata_23.img' 13:06:25: INFO: ======================================================= 13:06:25: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_23.img'} 13:06:25: INFO: {<program> (8.00 KB) 16 sectors needed at location 11079680 on LUN 0} 13:06:25: INFO: ======================================================= 13:06:25: INFO: TARGET SAID: 'start 11079680, num 16' 13:06:25: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:25: INFO: {percent files transferred 99.96%} 13:06:25: INFO: TARGET SAID: 'Finished sector address 11079696' 13:06:25: INFO: 13:06:25: INFO: ======================================================= 13:06:25: INFO: ==================== {SUCCESS} ======================== 13:06:25: INFO: ======================================================= 13:06:25: INFO: {percent files transferred 99.96%} 13:06:25: INFO: In handleProgram('userdata_24.img') 13:06:25: INFO: Looking for file 'userdata_24.img' 13:06:25: INFO: ======================================================= 13:06:25: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_24.img'} 13:06:25: INFO: {<program> (8.00 KB) 16 sectors needed at location 11341824 on LUN 0} 13:06:25: INFO: ======================================================= 13:06:25: INFO: TARGET SAID: 'start 11341824, num 16' 13:06:25: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:25: INFO: {percent files transferred 99.96%} 13:06:25: INFO: TARGET SAID: 'Finished sector address 11341840' 13:06:25: INFO: 13:06:25: INFO: ======================================================= 13:06:25: INFO: ==================== {SUCCESS} ======================== 13:06:25: INFO: ======================================================= 13:06:25: INFO: {percent files transferred 99.96%} 13:06:25: INFO: In handleProgram('userdata_25.img') 13:06:25: INFO: Looking for file 'userdata_25.img' 13:06:25: INFO: ======================================================= 13:06:25: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_25.img'} 13:06:25: INFO: {<program> (8.00 KB) 16 sectors needed at location 11603968 on LUN 0} 13:06:25: INFO: ======================================================= 13:06:25: INFO: TARGET SAID: 'start 11603968, num 16' 13:06:25: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:25: INFO: {percent files transferred 99.96%} 13:06:25: INFO: TARGET SAID: 'Finished sector address 11603984' 13:06:25: INFO: 13:06:25: INFO: ======================================================= 13:06:25: INFO: ==================== {SUCCESS} ======================== 13:06:25: INFO: ======================================================= 13:06:25: INFO: {percent files transferred 99.96%} 13:06:25: INFO: In handleProgram('userdata_26.img') 13:06:25: INFO: Looking for file 'userdata_26.img' 13:06:25: INFO: ======================================================= 13:06:25: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_26.img'} 13:06:25: INFO: {<program> (8.00 KB) 16 sectors needed at location 11866112 on LUN 0} 13:06:25: INFO: ======================================================= 13:06:25: INFO: TARGET SAID: 'start 11866112, num 16' 13:06:25: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:25: INFO: {percent files transferred 99.96%} 13:06:25: INFO: TARGET SAID: 'Finished sector address 11866128' 13:06:25: INFO: 13:06:25: INFO: ======================================================= 13:06:25: INFO: ==================== {SUCCESS} ======================== 13:06:25: INFO: ======================================================= 13:06:25: INFO: {percent files transferred 99.96%} 13:06:25: INFO: In handleProgram('userdata_27.img') 13:06:25: INFO: Looking for file 'userdata_27.img' 13:06:25: INFO: ======================================================= 13:06:25: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_27.img'} 13:06:25: INFO: {<program> (8.00 KB) 16 sectors needed at location 12128256 on LUN 0} 13:06:25: INFO: ======================================================= 13:06:26: INFO: TARGET SAID: 'start 12128256, num 16' 13:06:26: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.047 seconds (170.21 KBps) 13:06:26: INFO: {percent files transferred 99.96%} 13:06:26: INFO: TARGET SAID: 'Finished sector address 12128272' 13:06:26: INFO: 13:06:26: INFO: ======================================================= 13:06:26: INFO: ==================== {SUCCESS} ======================== 13:06:26: INFO: ======================================================= 13:06:26: INFO: {percent files transferred 99.96%} 13:06:26: INFO: In handleProgram('userdata_28.img') 13:06:26: INFO: Looking for file 'userdata_28.img' 13:06:26: INFO: ======================================================= 13:06:26: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_28.img'} 13:06:26: INFO: {<program> (8.00 KB) 16 sectors needed at location 12390400 on LUN 0} 13:06:26: INFO: ======================================================= 13:06:26: INFO: TARGET SAID: 'start 12390400, num 16' 13:06:26: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.015 seconds (533.33 KBps) 13:06:26: INFO: {percent files transferred 99.96%} 13:06:26: INFO: TARGET SAID: 'Finished sector address 12390416' 13:06:26: INFO: 13:06:26: INFO: ======================================================= 13:06:26: INFO: ==================== {SUCCESS} ======================== 13:06:26: INFO: ======================================================= 13:06:26: INFO: {percent files transferred 99.96%} 13:06:26: INFO: In handleProgram('userdata_29.img') 13:06:26: INFO: Looking for file 'userdata_29.img' 13:06:26: INFO: ======================================================= 13:06:26: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_29.img'} 13:06:26: INFO: {<program> (8.00 KB) 16 sectors needed at location 12652544 on LUN 0} 13:06:26: INFO: ======================================================= 13:06:26: INFO: TARGET SAID: 'start 12652544, num 16' 13:06:26: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:26: INFO: {percent files transferred 99.96%} 13:06:26: INFO: TARGET SAID: 'Finished sector address 12652560' 13:06:26: INFO: 13:06:26: INFO: ======================================================= 13:06:26: INFO: ==================== {SUCCESS} ======================== 13:06:26: INFO: ======================================================= 13:06:26: INFO: {percent files transferred 99.96%} 13:06:26: INFO: In handleProgram('userdata_30.img') 13:06:26: INFO: Looking for file 'userdata_30.img' 13:06:26: INFO: ======================================================= 13:06:26: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_30.img'} 13:06:26: INFO: {<program> (8.00 KB) 16 sectors needed at location 12914688 on LUN 0} 13:06:26: INFO: ======================================================= 13:06:26: INFO: TARGET SAID: 'start 12914688, num 16' 13:06:26: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:26: INFO: {percent files transferred 99.97%} 13:06:27: INFO: TARGET SAID: 'Finished sector address 12914704' 13:06:27: INFO: 13:06:27: INFO: ======================================================= 13:06:27: INFO: ==================== {SUCCESS} ======================== 13:06:27: INFO: ======================================================= 13:06:27: INFO: {percent files transferred 99.97%} 13:06:27: INFO: In handleProgram('userdata_31.img') 13:06:27: INFO: Looking for file 'userdata_31.img' 13:06:27: INFO: ======================================================= 13:06:27: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_31.img'} 13:06:27: INFO: {<program> (8.00 KB) 16 sectors needed at location 13176832 on LUN 0} 13:06:27: INFO: ======================================================= 13:06:27: INFO: TARGET SAID: 'start 13176832, num 16' 13:06:27: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:27: INFO: {percent files transferred 99.97%} 13:06:27: INFO: TARGET SAID: 'Finished sector address 13176848' 13:06:27: INFO: 13:06:27: INFO: ======================================================= 13:06:27: INFO: ==================== {SUCCESS} ======================== 13:06:27: INFO: ======================================================= 13:06:27: INFO: {percent files transferred 99.97%} 13:06:27: INFO: In handleProgram('userdata_32.img') 13:06:27: INFO: Looking for file 'userdata_32.img' 13:06:27: INFO: ======================================================= 13:06:27: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_32.img'} 13:06:27: INFO: {<program> (8.00 KB) 16 sectors needed at location 13181960 on LUN 0} 13:06:27: INFO: ======================================================= 13:06:27: INFO: TARGET SAID: 'start 13181960, num 16' 13:06:27: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:27: INFO: {percent files transferred 99.97%} 13:06:27: INFO: TARGET SAID: 'Finished sector address 13181976' 13:06:27: INFO: 13:06:27: INFO: ======================================================= 13:06:27: INFO: ==================== {SUCCESS} ======================== 13:06:27: INFO: ======================================================= 13:06:27: INFO: {percent files transferred 99.97%} 13:06:27: INFO: In handleProgram('userdata_33.img') 13:06:27: INFO: Looking for file 'userdata_33.img' 13:06:27: INFO: ======================================================= 13:06:27: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_33.img'} 13:06:27: INFO: {<program> (8.00 KB) 16 sectors needed at location 13438976 on LUN 0} 13:06:27: INFO: ======================================================= 13:06:27: INFO: TARGET SAID: 'start 13438976, num 16' 13:06:27: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:27: INFO: {percent files transferred 99.97%} 13:06:27: INFO: TARGET SAID: 'Finished sector address 13438992' 13:06:27: INFO: 13:06:27: INFO: ======================================================= 13:06:27: INFO: ==================== {SUCCESS} ======================== 13:06:27: INFO: ======================================================= 13:06:27: INFO: {percent files transferred 99.97%} 13:06:27: INFO: In handleProgram('userdata_34.img') 13:06:27: INFO: Looking for file 'userdata_34.img' 13:06:27: INFO: ======================================================= 13:06:27: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_34.img'} 13:06:27: INFO: {<program> (8.00 KB) 16 sectors needed at location 13701120 on LUN 0} 13:06:27: INFO: ======================================================= 13:06:27: INFO: TARGET SAID: 'start 13701120, num 16' 13:06:27: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.015 seconds (533.33 KBps) 13:06:27: INFO: {percent files transferred 99.97%} 13:06:27: INFO: TARGET SAID: 'Finished sector address 13701136' 13:06:27: INFO: 13:06:27: INFO: ======================================================= 13:06:27: INFO: ==================== {SUCCESS} ======================== 13:06:27: INFO: ======================================================= 13:06:27: INFO: {percent files transferred 99.97%} 13:06:27: INFO: In handleProgram('userdata_35.img') 13:06:27: INFO: Looking for file 'userdata_35.img' 13:06:27: INFO: ======================================================= 13:06:27: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_35.img'} 13:06:27: INFO: {<program> (8.00 KB) 16 sectors needed at location 13706248 on LUN 0} 13:06:27: INFO: ======================================================= 13:06:28: INFO: TARGET SAID: 'start 13706248, num 16' 13:06:28: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:28: INFO: {percent files transferred 99.97%} 13:06:28: INFO: TARGET SAID: 'Finished sector address 13706264' 13:06:28: INFO: 13:06:28: INFO: ======================================================= 13:06:28: INFO: ==================== {SUCCESS} ======================== 13:06:28: INFO: ======================================================= 13:06:28: INFO: {percent files transferred 99.97%} 13:06:28: INFO: In handleProgram('userdata_36.img') 13:06:28: INFO: Looking for file 'userdata_36.img' 13:06:28: INFO: ======================================================= 13:06:28: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_36.img'} 13:06:28: INFO: {<program> (8.00 KB) 16 sectors needed at location 13963264 on LUN 0} 13:06:28: INFO: ======================================================= 13:06:28: INFO: TARGET SAID: 'start 13963264, num 16' 13:06:28: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:28: INFO: {percent files transferred 99.97%} 13:06:28: INFO: TARGET SAID: 'Finished sector address 13963280' 13:06:28: INFO: 13:06:28: INFO: ======================================================= 13:06:28: INFO: ==================== {SUCCESS} ======================== 13:06:28: INFO: ======================================================= 13:06:28: INFO: {percent files transferred 99.97%} 13:06:28: INFO: In handleProgram('userdata_37.img') 13:06:28: INFO: Looking for file 'userdata_37.img' 13:06:28: INFO: ======================================================= 13:06:28: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_37.img'} 13:06:28: INFO: {<program> (8.00 KB) 16 sectors needed at location 14225408 on LUN 0} 13:06:28: INFO: ======================================================= 13:06:28: INFO: TARGET SAID: 'start 14225408, num 16' 13:06:28: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:28: INFO: {percent files transferred 99.97%} 13:06:28: INFO: TARGET SAID: 'Finished sector address 14225424' 13:06:28: INFO: 13:06:28: INFO: ======================================================= 13:06:28: INFO: ==================== {SUCCESS} ======================== 13:06:28: INFO: ======================================================= 13:06:28: INFO: {percent files transferred 99.97%} 13:06:28: INFO: In handleProgram('userdata_38.img') 13:06:28: INFO: Looking for file 'userdata_38.img' 13:06:28: INFO: ======================================================= 13:06:28: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_38.img'} 13:06:28: INFO: {<program> (8.00 KB) 16 sectors needed at location 14487552 on LUN 0} 13:06:28: INFO: ======================================================= 13:06:28: INFO: TARGET SAID: 'start 14487552, num 16' 13:06:28: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:28: INFO: {percent files transferred 99.97%} 13:06:28: INFO: TARGET SAID: 'Finished sector address 14487568' 13:06:28: INFO: 13:06:28: INFO: ======================================================= 13:06:28: INFO: ==================== {SUCCESS} ======================== 13:06:28: INFO: ======================================================= 13:06:28: INFO: {percent files transferred 99.97%} 13:06:28: INFO: In handleProgram('userdata_39.img') 13:06:28: INFO: Looking for file 'userdata_39.img' 13:06:28: INFO: ======================================================= 13:06:28: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_39.img'} 13:06:28: INFO: {<program> (8.00 KB) 16 sectors needed at location 14749696 on LUN 0} 13:06:28: INFO: ======================================================= 13:06:28: INFO: TARGET SAID: 'start 14749696, num 16' 13:06:28: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.016 seconds (500.00 KBps) 13:06:28: INFO: {percent files transferred 99.97%} 13:06:29: INFO: TARGET SAID: 'Finished sector address 14749712' 13:06:29: INFO: 13:06:29: INFO: ======================================================= 13:06:29: INFO: ==================== {SUCCESS} ======================== 13:06:29: INFO: ======================================================= 13:06:29: INFO: {percent files transferred 99.97%} 13:06:29: INFO: In handleProgram('userdata_40.img') 13:06:29: INFO: Looking for file 'userdata_40.img' 13:06:29: INFO: ======================================================= 13:06:29: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_40.img'} 13:06:29: INFO: {<program> (8.00 KB) 16 sectors needed at location 15011840 on LUN 0} 13:06:29: INFO: ======================================================= 13:06:29: INFO: TARGET SAID: 'start 15011840, num 16' 13:06:29: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:29: INFO: {percent files transferred 99.97%} 13:06:29: INFO: TARGET SAID: 'Finished sector address 15011856' 13:06:29: INFO: 13:06:29: INFO: ======================================================= 13:06:29: INFO: ==================== {SUCCESS} ======================== 13:06:29: INFO: ======================================================= 13:06:29: INFO: {percent files transferred 99.97%} 13:06:29: INFO: In handleProgram('userdata_41.img') 13:06:29: INFO: Looking for file 'userdata_41.img' 13:06:29: INFO: ======================================================= 13:06:29: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_41.img'} 13:06:29: INFO: {<program> (8.00 KB) 16 sectors needed at location 15273984 on LUN 0} 13:06:29: INFO: ======================================================= 13:06:29: INFO: TARGET SAID: 'start 15273984, num 16' 13:06:29: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:29: INFO: {percent files transferred 99.97%} 13:06:29: INFO: TARGET SAID: 'Finished sector address 15274000' 13:06:29: INFO: 13:06:29: INFO: ======================================================= 13:06:29: INFO: ==================== {SUCCESS} ======================== 13:06:29: INFO: ======================================================= 13:06:29: INFO: {percent files transferred 99.97%} 13:06:29: INFO: In handleProgram('userdata_42.img') 13:06:29: INFO: Looking for file 'userdata_42.img' 13:06:29: INFO: ======================================================= 13:06:29: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_42.img'} 13:06:29: INFO: {<program> (8.00 KB) 16 sectors needed at location 15536128 on LUN 0} 13:06:29: INFO: ======================================================= 13:06:29: INFO: TARGET SAID: 'start 15536128, num 16' 13:06:29: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:29: INFO: {percent files transferred 99.97%} 13:06:29: INFO: TARGET SAID: 'Finished sector address 15536144' 13:06:29: INFO: 13:06:29: INFO: ======================================================= 13:06:29: INFO: ==================== {SUCCESS} ======================== 13:06:29: INFO: ======================================================= 13:06:29: INFO: {percent files transferred 99.97%} 13:06:29: INFO: In handleProgram('userdata_43.img') 13:06:29: INFO: Looking for file 'userdata_43.img' 13:06:29: INFO: ======================================================= 13:06:29: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_43.img'} 13:06:29: INFO: {<program> (8.00 KB) 16 sectors needed at location 15798272 on LUN 0} 13:06:29: INFO: ======================================================= 13:06:29: INFO: TARGET SAID: 'start 15798272, num 16' 13:06:29: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:29: INFO: {percent files transferred 99.97%} 13:06:29: INFO: TARGET SAID: 'Finished sector address 15798288' 13:06:29: INFO: 13:06:29: INFO: ======================================================= 13:06:29: INFO: ==================== {SUCCESS} ======================== 13:06:29: INFO: ======================================================= 13:06:29: INFO: {percent files transferred 99.97%} 13:06:29: INFO: In handleProgram('userdata_44.img') 13:06:29: INFO: Looking for file 'userdata_44.img' 13:06:29: INFO: ======================================================= 13:06:29: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_44.img'} 13:06:29: INFO: {<program> (8.00 KB) 16 sectors needed at location 16060416 on LUN 0} 13:06:29: INFO: ======================================================= 13:06:29: INFO: TARGET SAID: 'start 16060416, num 16' 13:06:29: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:29: INFO: {percent files transferred 99.97%} 13:06:30: INFO: TARGET SAID: 'Finished sector address 16060432' 13:06:30: INFO: 13:06:30: INFO: ======================================================= 13:06:30: INFO: ==================== {SUCCESS} ======================== 13:06:30: INFO: ======================================================= 13:06:30: INFO: {percent files transferred 99.97%} 13:06:30: INFO: In handleProgram('userdata_45.img') 13:06:30: INFO: Looking for file 'userdata_45.img' 13:06:30: INFO: ======================================================= 13:06:30: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_45.img'} 13:06:30: INFO: {<program> (8.00 KB) 16 sectors needed at location 16322560 on LUN 0} 13:06:30: INFO: ======================================================= 13:06:30: INFO: TARGET SAID: 'start 16322560, num 16' 13:06:30: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:30: INFO: {percent files transferred 99.97%} 13:06:30: INFO: TARGET SAID: 'Finished sector address 16322576' 13:06:30: INFO: 13:06:30: INFO: ======================================================= 13:06:30: INFO: ==================== {SUCCESS} ======================== 13:06:30: INFO: ======================================================= 13:06:30: INFO: {percent files transferred 99.97%} 13:06:30: INFO: In handleProgram('userdata_46.img') 13:06:30: INFO: Looking for file 'userdata_46.img' 13:06:30: INFO: ======================================================= 13:06:30: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_46.img'} 13:06:30: INFO: {<program> (8.00 KB) 16 sectors needed at location 16584704 on LUN 0} 13:06:30: INFO: ======================================================= 13:06:30: INFO: TARGET SAID: 'start 16584704, num 16' 13:06:30: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:30: INFO: {percent files transferred 99.97%} 13:06:30: INFO: TARGET SAID: 'Finished sector address 16584720' 13:06:30: INFO: 13:06:30: INFO: ======================================================= 13:06:30: INFO: ==================== {SUCCESS} ======================== 13:06:30: INFO: ======================================================= 13:06:30: INFO: {percent files transferred 99.97%} 13:06:30: INFO: In handleProgram('userdata_47.img') 13:06:30: INFO: Looking for file 'userdata_47.img' 13:06:30: INFO: ======================================================= 13:06:30: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_47.img'} 13:06:30: INFO: {<program> (8.00 KB) 16 sectors needed at location 16846848 on LUN 0} 13:06:30: INFO: ======================================================= 13:06:30: INFO: TARGET SAID: 'start 16846848, num 16' 13:06:30: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:30: INFO: {percent files transferred 99.97%} 13:06:30: INFO: TARGET SAID: 'Finished sector address 16846864' 13:06:30: INFO: 13:06:30: INFO: ======================================================= 13:06:30: INFO: ==================== {SUCCESS} ======================== 13:06:30: INFO: ======================================================= 13:06:30: INFO: {percent files transferred 99.97%} 13:06:30: INFO: In handleProgram('userdata_48.img') 13:06:30: INFO: Looking for file 'userdata_48.img' 13:06:30: INFO: ======================================================= 13:06:30: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_48.img'} 13:06:30: INFO: {<program> (8.00 KB) 16 sectors needed at location 17108992 on LUN 0} 13:06:30: INFO: ======================================================= 13:06:30: INFO: TARGET SAID: 'start 17108992, num 16' 13:06:30: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:30: INFO: {percent files transferred 99.98%} 13:06:30: INFO: TARGET SAID: 'Finished sector address 17109008' 13:06:30: INFO: 13:06:30: INFO: ======================================================= 13:06:30: INFO: ==================== {SUCCESS} ======================== 13:06:30: INFO: ======================================================= 13:06:30: INFO: {percent files transferred 99.98%} 13:06:30: INFO: In handleProgram('userdata_49.img') 13:06:30: INFO: Looking for file 'userdata_49.img' 13:06:30: INFO: ======================================================= 13:06:30: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_49.img'} 13:06:30: INFO: {<program> (8.00 KB) 16 sectors needed at location 17371136 on LUN 0} 13:06:30: INFO: ======================================================= 13:06:31: INFO: TARGET SAID: 'start 17371136, num 16' 13:06:31: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:31: INFO: {percent files transferred 99.98%} 13:06:31: INFO: TARGET SAID: 'Finished sector address 17371152' 13:06:31: INFO: 13:06:31: INFO: ======================================================= 13:06:31: INFO: ==================== {SUCCESS} ======================== 13:06:31: INFO: ======================================================= 13:06:31: INFO: {percent files transferred 99.98%} 13:06:31: INFO: In handleProgram('userdata_50.img') 13:06:31: INFO: Looking for file 'userdata_50.img' 13:06:31: INFO: ======================================================= 13:06:31: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_50.img'} 13:06:31: INFO: {<program> (8.00 KB) 16 sectors needed at location 17633280 on LUN 0} 13:06:31: INFO: ======================================================= 13:06:31: INFO: TARGET SAID: 'start 17633280, num 16' 13:06:31: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:31: INFO: {percent files transferred 99.98%} 13:06:31: INFO: TARGET SAID: 'Finished sector address 17633296' 13:06:31: INFO: 13:06:31: INFO: ======================================================= 13:06:31: INFO: ==================== {SUCCESS} ======================== 13:06:31: INFO: ======================================================= 13:06:31: INFO: {percent files transferred 99.98%} 13:06:31: INFO: In handleProgram('userdata_51.img') 13:06:31: INFO: Looking for file 'userdata_51.img' 13:06:31: INFO: ======================================================= 13:06:31: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_51.img'} 13:06:31: INFO: {<program> (8.00 KB) 16 sectors needed at location 17895424 on LUN 0} 13:06:31: INFO: ======================================================= 13:06:31: INFO: TARGET SAID: 'start 17895424, num 16' 13:06:31: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:31: INFO: {percent files transferred 99.98%} 13:06:31: INFO: TARGET SAID: 'Finished sector address 17895440' 13:06:31: INFO: 13:06:31: INFO: ======================================================= 13:06:31: INFO: ==================== {SUCCESS} ======================== 13:06:31: INFO: ======================================================= 13:06:31: INFO: {percent files transferred 99.98%} 13:06:31: INFO: In handleProgram('userdata_52.img') 13:06:31: INFO: Looking for file 'userdata_52.img' 13:06:31: INFO: ======================================================= 13:06:31: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_52.img'} 13:06:31: INFO: {<program> (8.00 KB) 16 sectors needed at location 18157568 on LUN 0} 13:06:31: INFO: ======================================================= 13:06:31: INFO: TARGET SAID: 'start 18157568, num 16' 13:06:31: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:31: INFO: {percent files transferred 99.98%} 13:06:31: INFO: TARGET SAID: 'Finished sector address 18157584' 13:06:31: INFO: 13:06:31: INFO: ======================================================= 13:06:31: INFO: ==================== {SUCCESS} ======================== 13:06:31: INFO: ======================================================= 13:06:31: INFO: {percent files transferred 99.98%} 13:06:31: INFO: In handleProgram('userdata_53.img') 13:06:31: INFO: Looking for file 'userdata_53.img' 13:06:31: INFO: ======================================================= 13:06:31: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_53.img'} 13:06:31: INFO: {<program> (8.00 KB) 16 sectors needed at location 18419712 on LUN 0} 13:06:31: INFO: ======================================================= 13:06:31: INFO: TARGET SAID: 'start 18419712, num 16' 13:06:31: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:31: INFO: {percent files transferred 99.98%} 13:06:32: INFO: TARGET SAID: 'Finished sector address 18419728' 13:06:32: INFO: 13:06:32: INFO: ======================================================= 13:06:32: INFO: ==================== {SUCCESS} ======================== 13:06:32: INFO: ======================================================= 13:06:32: INFO: {percent files transferred 99.98%} 13:06:32: INFO: In handleProgram('userdata_54.img') 13:06:32: INFO: Looking for file 'userdata_54.img' 13:06:32: INFO: ======================================================= 13:06:32: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_54.img'} 13:06:32: INFO: {<program> (8.00 KB) 16 sectors needed at location 18681856 on LUN 0} 13:06:32: INFO: ======================================================= 13:06:32: INFO: TARGET SAID: 'start 18681856, num 16' 13:06:32: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:32: INFO: {percent files transferred 99.98%} 13:06:32: INFO: TARGET SAID: 'Finished sector address 18681872' 13:06:32: INFO: 13:06:32: INFO: ======================================================= 13:06:32: INFO: ==================== {SUCCESS} ======================== 13:06:32: INFO: ======================================================= 13:06:32: INFO: {percent files transferred 99.98%} 13:06:32: INFO: In handleProgram('userdata_55.img') 13:06:32: INFO: Looking for file 'userdata_55.img' 13:06:32: INFO: ======================================================= 13:06:32: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_55.img'} 13:06:32: INFO: {<program> (8.00 KB) 16 sectors needed at location 18944000 on LUN 0} 13:06:32: INFO: ======================================================= 13:06:32: INFO: TARGET SAID: 'start 18944000, num 16' 13:06:32: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.015 seconds (533.33 KBps) 13:06:32: INFO: {percent files transferred 99.98%} 13:06:32: INFO: TARGET SAID: 'Finished sector address 18944016' 13:06:32: INFO: 13:06:32: INFO: ======================================================= 13:06:32: INFO: ==================== {SUCCESS} ======================== 13:06:32: INFO: ======================================================= 13:06:32: INFO: {percent files transferred 99.98%} 13:06:32: INFO: In handleProgram('userdata_56.img') 13:06:32: INFO: Looking for file 'userdata_56.img' 13:06:32: INFO: ======================================================= 13:06:32: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_56.img'} 13:06:32: INFO: {<program> (8.00 KB) 16 sectors needed at location 19206144 on LUN 0} 13:06:32: INFO: ======================================================= 13:06:32: INFO: TARGET SAID: 'start 19206144, num 16' 13:06:32: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:32: INFO: {percent files transferred 99.98%} 13:06:32: INFO: TARGET SAID: 'Finished sector address 19206160' 13:06:32: INFO: 13:06:32: INFO: ======================================================= 13:06:32: INFO: ==================== {SUCCESS} ======================== 13:06:32: INFO: ======================================================= 13:06:32: INFO: {percent files transferred 99.98%} 13:06:32: INFO: In handleProgram('userdata_57.img') 13:06:32: INFO: Looking for file 'userdata_57.img' 13:06:32: INFO: ======================================================= 13:06:32: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_57.img'} 13:06:32: INFO: {<program> (8.00 KB) 16 sectors needed at location 19468288 on LUN 0} 13:06:32: INFO: ======================================================= 13:06:32: INFO: TARGET SAID: 'start 19468288, num 16' 13:06:32: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:32: INFO: {percent files transferred 99.98%} 13:06:32: INFO: TARGET SAID: 'Finished sector address 19468304' 13:06:32: INFO: 13:06:32: INFO: ======================================================= 13:06:32: INFO: ==================== {SUCCESS} ======================== 13:06:32: INFO: ======================================================= 13:06:32: INFO: {percent files transferred 99.98%} 13:06:32: INFO: In handleProgram('userdata_58.img') 13:06:32: INFO: Looking for file 'userdata_58.img' 13:06:32: INFO: ======================================================= 13:06:32: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_58.img'} 13:06:32: INFO: {<program> (8.00 KB) 16 sectors needed at location 19473416 on LUN 0} 13:06:32: INFO: ======================================================= 13:06:33: INFO: TARGET SAID: 'start 19473416, num 16' 13:06:33: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:33: INFO: {percent files transferred 99.98%} 13:06:33: INFO: TARGET SAID: 'Finished sector address 19473432' 13:06:33: INFO: 13:06:33: INFO: ======================================================= 13:06:33: INFO: ==================== {SUCCESS} ======================== 13:06:33: INFO: ======================================================= 13:06:33: INFO: {percent files transferred 99.98%} 13:06:33: INFO: In handleProgram('userdata_59.img') 13:06:33: INFO: Looking for file 'userdata_59.img' 13:06:33: INFO: ======================================================= 13:06:33: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_59.img'} 13:06:33: INFO: {<program> (8.00 KB) 16 sectors needed at location 19730432 on LUN 0} 13:06:33: INFO: ======================================================= 13:06:33: INFO: TARGET SAID: 'start 19730432, num 16' 13:06:33: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:33: INFO: {percent files transferred 99.98%} 13:06:33: INFO: TARGET SAID: 'Finished sector address 19730448' 13:06:33: INFO: 13:06:33: INFO: ======================================================= 13:06:33: INFO: ==================== {SUCCESS} ======================== 13:06:33: INFO: ======================================================= 13:06:33: INFO: {percent files transferred 99.98%} 13:06:33: INFO: In handleProgram('userdata_60.img') 13:06:33: INFO: Looking for file 'userdata_60.img' 13:06:33: INFO: ======================================================= 13:06:33: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_60.img'} 13:06:33: INFO: {<program> (8.00 KB) 16 sectors needed at location 19992576 on LUN 0} 13:06:33: INFO: ======================================================= 13:06:33: INFO: TARGET SAID: 'start 19992576, num 16' 13:06:33: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:33: INFO: {percent files transferred 99.98%} 13:06:33: INFO: TARGET SAID: 'Finished sector address 19992592' 13:06:33: INFO: 13:06:33: INFO: ======================================================= 13:06:33: INFO: ==================== {SUCCESS} ======================== 13:06:33: INFO: ======================================================= 13:06:33: INFO: {percent files transferred 99.98%} 13:06:33: INFO: In handleProgram('userdata_61.img') 13:06:33: INFO: Looking for file 'userdata_61.img' 13:06:33: INFO: ======================================================= 13:06:33: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_61.img'} 13:06:33: INFO: {<program> (8.00 KB) 16 sectors needed at location 20254720 on LUN 0} 13:06:33: INFO: ======================================================= 13:06:33: INFO: TARGET SAID: 'start 20254720, num 16' 13:06:33: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:33: INFO: {percent files transferred 99.98%} 13:06:33: INFO: TARGET SAID: 'Finished sector address 20254736' 13:06:33: INFO: 13:06:33: INFO: ======================================================= 13:06:33: INFO: ==================== {SUCCESS} ======================== 13:06:33: INFO: ======================================================= 13:06:33: INFO: {percent files transferred 99.98%} 13:06:33: INFO: In handleProgram('userdata_62.img') 13:06:33: INFO: Looking for file 'userdata_62.img' 13:06:33: INFO: ======================================================= 13:06:33: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_62.img'} 13:06:33: INFO: {<program> (8.00 KB) 16 sectors needed at location 20516864 on LUN 0} 13:06:33: INFO: ======================================================= 13:06:33: INFO: TARGET SAID: 'start 20516864, num 16' 13:06:33: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:33: INFO: {percent files transferred 99.98%} 13:06:34: INFO: TARGET SAID: 'Finished sector address 20516880' 13:06:34: INFO: 13:06:34: INFO: ======================================================= 13:06:34: INFO: ==================== {SUCCESS} ======================== 13:06:34: INFO: ======================================================= 13:06:34: INFO: {percent files transferred 99.98%} 13:06:34: INFO: In handleProgram('userdata_63.img') 13:06:34: INFO: Looking for file 'userdata_63.img' 13:06:34: INFO: ======================================================= 13:06:34: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_63.img'} 13:06:34: INFO: {<program> (8.00 KB) 16 sectors needed at location 20779008 on LUN 0} 13:06:34: INFO: ======================================================= 13:06:34: INFO: TARGET SAID: 'start 20779008, num 16' 13:06:34: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:34: INFO: {percent files transferred 99.98%} 13:06:34: INFO: TARGET SAID: 'Finished sector address 20779024' 13:06:34: INFO: 13:06:34: INFO: ======================================================= 13:06:34: INFO: ==================== {SUCCESS} ======================== 13:06:34: INFO: ======================================================= 13:06:34: INFO: {percent files transferred 99.98%} 13:06:34: INFO: In handleProgram('userdata_64.img') 13:06:34: INFO: Looking for file 'userdata_64.img' 13:06:34: INFO: ======================================================= 13:06:34: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_64.img'} 13:06:34: INFO: {<program> (8.00 KB) 16 sectors needed at location 21041152 on LUN 0} 13:06:34: INFO: ======================================================= 13:06:34: INFO: TARGET SAID: 'start 21041152, num 16' 13:06:34: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:34: INFO: {percent files transferred 99.98%} 13:06:34: INFO: TARGET SAID: 'Finished sector address 21041168' 13:06:34: INFO: 13:06:34: INFO: ======================================================= 13:06:34: INFO: ==================== {SUCCESS} ======================== 13:06:34: INFO: ======================================================= 13:06:34: INFO: {percent files transferred 99.98%} 13:06:34: INFO: In handleProgram('userdata_65.img') 13:06:34: INFO: Looking for file 'userdata_65.img' 13:06:34: INFO: ======================================================= 13:06:34: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_65.img'} 13:06:34: INFO: {<program> (8.00 KB) 16 sectors needed at location 21303296 on LUN 0} 13:06:34: INFO: ======================================================= 13:06:34: INFO: TARGET SAID: 'start 21303296, num 16' 13:06:34: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:34: INFO: {percent files transferred 99.98%} 13:06:34: INFO: TARGET SAID: 'Finished sector address 21303312' 13:06:34: INFO: 13:06:34: INFO: ======================================================= 13:06:34: INFO: ==================== {SUCCESS} ======================== 13:06:34: INFO: ======================================================= 13:06:34: INFO: {percent files transferred 99.98%} 13:06:34: INFO: In handleProgram('userdata_66.img') 13:06:34: INFO: Looking for file 'userdata_66.img' 13:06:34: INFO: ======================================================= 13:06:34: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_66.img'} 13:06:34: INFO: {<program> (8.00 KB) 16 sectors needed at location 21565440 on LUN 0} 13:06:34: INFO: ======================================================= 13:06:34: INFO: TARGET SAID: 'start 21565440, num 16' 13:06:34: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:34: INFO: {percent files transferred 99.99%} 13:06:34: INFO: TARGET SAID: 'Finished sector address 21565456' 13:06:34: INFO: 13:06:34: INFO: ======================================================= 13:06:34: INFO: ==================== {SUCCESS} ======================== 13:06:34: INFO: ======================================================= 13:06:34: INFO: {percent files transferred 99.99%} 13:06:34: INFO: In handleProgram('userdata_67.img') 13:06:34: INFO: Looking for file 'userdata_67.img' 13:06:34: INFO: ======================================================= 13:06:34: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_67.img'} 13:06:34: INFO: {<program> (8.00 KB) 16 sectors needed at location 21827584 on LUN 0} 13:06:34: INFO: ======================================================= 13:06:35: INFO: TARGET SAID: 'start 21827584, num 16' 13:06:35: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:35: INFO: {percent files transferred 99.99%} 13:06:35: INFO: TARGET SAID: 'Finished sector address 21827600' 13:06:35: INFO: 13:06:35: INFO: ======================================================= 13:06:35: INFO: ==================== {SUCCESS} ======================== 13:06:35: INFO: ======================================================= 13:06:35: INFO: {percent files transferred 99.99%} 13:06:35: INFO: In handleProgram('userdata_68.img') 13:06:35: INFO: Looking for file 'userdata_68.img' 13:06:35: INFO: ======================================================= 13:06:35: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_68.img'} 13:06:35: INFO: {<program> (8.00 KB) 16 sectors needed at location 22089728 on LUN 0} 13:06:35: INFO: ======================================================= 13:06:35: INFO: TARGET SAID: 'start 22089728, num 16' 13:06:35: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:35: INFO: {percent files transferred 99.99%} 13:06:35: INFO: TARGET SAID: 'Finished sector address 22089744' 13:06:35: INFO: 13:06:35: INFO: ======================================================= 13:06:35: INFO: ==================== {SUCCESS} ======================== 13:06:35: INFO: ======================================================= 13:06:35: INFO: {percent files transferred 99.99%} 13:06:35: INFO: In handleProgram('userdata_69.img') 13:06:35: INFO: Looking for file 'userdata_69.img' 13:06:35: INFO: ======================================================= 13:06:35: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_69.img'} 13:06:35: INFO: {<program> (8.00 KB) 16 sectors needed at location 22351872 on LUN 0} 13:06:35: INFO: ======================================================= 13:06:35: INFO: TARGET SAID: 'start 22351872, num 16' 13:06:35: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:35: INFO: {percent files transferred 99.99%} 13:06:35: INFO: TARGET SAID: 'Finished sector address 22351888' 13:06:35: INFO: 13:06:35: INFO: ======================================================= 13:06:35: INFO: ==================== {SUCCESS} ======================== 13:06:35: INFO: ======================================================= 13:06:35: INFO: {percent files transferred 99.99%} 13:06:35: INFO: In handleProgram('userdata_70.img') 13:06:35: INFO: Looking for file 'userdata_70.img' 13:06:35: INFO: ======================================================= 13:06:35: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_70.img'} 13:06:35: INFO: {<program> (8.00 KB) 16 sectors needed at location 22614016 on LUN 0} 13:06:35: INFO: ======================================================= 13:06:35: INFO: TARGET SAID: 'start 22614016, num 16' 13:06:35: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:35: INFO: {percent files transferred 99.99%} 13:06:35: INFO: TARGET SAID: 'Finished sector address 22614032' 13:06:35: INFO: 13:06:35: INFO: ======================================================= 13:06:35: INFO: ==================== {SUCCESS} ======================== 13:06:35: INFO: ======================================================= 13:06:35: INFO: {percent files transferred 99.99%} 13:06:35: INFO: In handleProgram('userdata_71.img') 13:06:35: INFO: Looking for file 'userdata_71.img' 13:06:35: INFO: ======================================================= 13:06:35: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_71.img'} 13:06:35: INFO: {<program> (8.00 KB) 16 sectors needed at location 22876160 on LUN 0} 13:06:35: INFO: ======================================================= 13:06:35: INFO: TARGET SAID: 'start 22876160, num 16' 13:06:35: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:35: INFO: {percent files transferred 99.99%} 13:06:36: INFO: TARGET SAID: 'Finished sector address 22876176' 13:06:36: INFO: 13:06:36: INFO: ======================================================= 13:06:36: INFO: ==================== {SUCCESS} ======================== 13:06:36: INFO: ======================================================= 13:06:36: INFO: {percent files transferred 99.99%} 13:06:36: INFO: In handleProgram('userdata_72.img') 13:06:36: INFO: Looking for file 'userdata_72.img' 13:06:36: INFO: ======================================================= 13:06:36: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_72.img'} 13:06:36: INFO: {<program> (8.00 KB) 16 sectors needed at location 23138304 on LUN 0} 13:06:36: INFO: ======================================================= 13:06:36: INFO: TARGET SAID: 'start 23138304, num 16' 13:06:36: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.016 seconds (500.00 KBps) 13:06:36: INFO: {percent files transferred 99.99%} 13:06:36: INFO: TARGET SAID: 'Finished sector address 23138320' 13:06:36: INFO: 13:06:36: INFO: ======================================================= 13:06:36: INFO: ==================== {SUCCESS} ======================== 13:06:36: INFO: ======================================================= 13:06:36: INFO: {percent files transferred 99.99%} 13:06:36: INFO: In handleProgram('userdata_73.img') 13:06:36: INFO: Looking for file 'userdata_73.img' 13:06:36: INFO: ======================================================= 13:06:36: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_73.img'} 13:06:36: INFO: {<program> (8.00 KB) 16 sectors needed at location 23400448 on LUN 0} 13:06:36: INFO: ======================================================= 13:06:36: INFO: TARGET SAID: 'start 23400448, num 16' 13:06:36: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:36: INFO: {percent files transferred 99.99%} 13:06:36: INFO: TARGET SAID: 'Finished sector address 23400464' 13:06:36: INFO: 13:06:36: INFO: ======================================================= 13:06:36: INFO: ==================== {SUCCESS} ======================== 13:06:36: INFO: ======================================================= 13:06:36: INFO: {percent files transferred 99.99%} 13:06:36: INFO: In handleProgram('userdata_74.img') 13:06:36: INFO: Looking for file 'userdata_74.img' 13:06:36: INFO: ======================================================= 13:06:36: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_74.img'} 13:06:36: INFO: {<program> (8.00 KB) 16 sectors needed at location 23662592 on LUN 0} 13:06:36: INFO: ======================================================= 13:06:36: INFO: TARGET SAID: 'start 23662592, num 16' 13:06:36: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:36: INFO: {percent files transferred 99.99%} 13:06:36: INFO: TARGET SAID: 'Finished sector address 23662608' 13:06:36: INFO: 13:06:36: INFO: ======================================================= 13:06:36: INFO: ==================== {SUCCESS} ======================== 13:06:36: INFO: ======================================================= 13:06:36: INFO: {percent files transferred 99.99%} 13:06:36: INFO: In handleProgram('userdata_75.img') 13:06:36: INFO: Looking for file 'userdata_75.img' 13:06:36: INFO: ======================================================= 13:06:36: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_75.img'} 13:06:36: INFO: {<program> (8.00 KB) 16 sectors needed at location 23924736 on LUN 0} 13:06:36: INFO: ======================================================= 13:06:36: INFO: TARGET SAID: 'start 23924736, num 16' 13:06:36: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:36: INFO: {percent files transferred 99.99%} 13:06:36: INFO: TARGET SAID: 'Finished sector address 23924752' 13:06:36: INFO: 13:06:36: INFO: ======================================================= 13:06:36: INFO: ==================== {SUCCESS} ======================== 13:06:36: INFO: ======================================================= 13:06:36: INFO: {percent files transferred 99.99%} 13:06:36: INFO: In handleProgram('userdata_76.img') 13:06:36: INFO: Looking for file 'userdata_76.img' 13:06:36: INFO: ======================================================= 13:06:36: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_76.img'} 13:06:36: INFO: {<program> (8.00 KB) 16 sectors needed at location 24186880 on LUN 0} 13:06:36: INFO: ======================================================= 13:06:37: INFO: TARGET SAID: 'start 24186880, num 16' 13:06:37: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.016 seconds (500.00 KBps) 13:06:37: INFO: {percent files transferred 99.99%} 13:06:37: INFO: TARGET SAID: 'Finished sector address 24186896' 13:06:37: INFO: 13:06:37: INFO: ======================================================= 13:06:37: INFO: ==================== {SUCCESS} ======================== 13:06:37: INFO: ======================================================= 13:06:37: INFO: {percent files transferred 99.99%} 13:06:37: INFO: In handleProgram('userdata_77.img') 13:06:37: INFO: Looking for file 'userdata_77.img' 13:06:37: INFO: ======================================================= 13:06:37: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_77.img'} 13:06:37: INFO: {<program> (8.00 KB) 16 sectors needed at location 24449024 on LUN 0} 13:06:37: INFO: ======================================================= 13:06:37: INFO: TARGET SAID: 'start 24449024, num 16' 13:06:37: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:37: INFO: {percent files transferred 99.99%} 13:06:37: INFO: TARGET SAID: 'Finished sector address 24449040' 13:06:37: INFO: 13:06:37: INFO: ======================================================= 13:06:37: INFO: ==================== {SUCCESS} ======================== 13:06:37: INFO: ======================================================= 13:06:37: INFO: {percent files transferred 99.99%} 13:06:37: INFO: In handleProgram('userdata_78.img') 13:06:37: INFO: Looking for file 'userdata_78.img' 13:06:37: INFO: ======================================================= 13:06:37: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_78.img'} 13:06:37: INFO: {<program> (8.00 KB) 16 sectors needed at location 24711168 on LUN 0} 13:06:37: INFO: ======================================================= 13:06:37: INFO: TARGET SAID: 'start 24711168, num 16' 13:06:37: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.016 seconds (500.00 KBps) 13:06:37: INFO: {percent files transferred 99.99%} 13:06:37: INFO: TARGET SAID: 'Finished sector address 24711184' 13:06:37: INFO: 13:06:37: INFO: ======================================================= 13:06:37: INFO: ==================== {SUCCESS} ======================== 13:06:37: INFO: ======================================================= 13:06:37: INFO: {percent files transferred 99.99%} 13:06:37: INFO: In handleProgram('userdata_79.img') 13:06:37: INFO: Looking for file 'userdata_79.img' 13:06:37: INFO: ======================================================= 13:06:37: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_79.img'} 13:06:37: INFO: {<program> (8.00 KB) 16 sectors needed at location 24973312 on LUN 0} 13:06:37: INFO: ======================================================= 13:06:37: INFO: TARGET SAID: 'start 24973312, num 16' 13:06:37: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.031 seconds (258.06 KBps) 13:06:37: INFO: {percent files transferred 99.99%} 13:06:37: INFO: TARGET SAID: 'Finished sector address 24973328' 13:06:37: INFO: 13:06:37: INFO: ======================================================= 13:06:37: INFO: ==================== {SUCCESS} ======================== 13:06:37: INFO: ======================================================= 13:06:37: INFO: {percent files transferred 99.99%} 13:06:37: INFO: In handleProgram('userdata_80.img') 13:06:37: INFO: Looking for file 'userdata_80.img' 13:06:37: INFO: ======================================================= 13:06:37: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_80.img'} 13:06:37: INFO: {<program> (8.00 KB) 16 sectors needed at location 25235456 on LUN 0} 13:06:37: INFO: ======================================================= 13:06:38: INFO: TARGET SAID: 'start 25235456, num 16' 13:06:38: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.031 seconds (258.06 KBps) 13:06:38: INFO: {percent files transferred 99.99%} 13:06:38: INFO: TARGET SAID: 'Finished sector address 25235472' 13:06:38: INFO: 13:06:38: INFO: ======================================================= 13:06:38: INFO: ==================== {SUCCESS} ======================== 13:06:38: INFO: ======================================================= 13:06:38: INFO: {percent files transferred 99.99%} 13:06:38: INFO: In handleProgram('userdata_81.img') 13:06:38: INFO: Looking for file 'userdata_81.img' 13:06:38: INFO: ======================================================= 13:06:38: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_81.img'} 13:06:38: INFO: {<program> (8.00 KB) 16 sectors needed at location 25497600 on LUN 0} 13:06:38: INFO: ======================================================= 13:06:38: INFO: TARGET SAID: 'start 25497600, num 16' 13:06:38: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:38: INFO: {percent files transferred 99.99%} 13:06:38: INFO: TARGET SAID: 'Finished sector address 25497616' 13:06:38: INFO: 13:06:38: INFO: ======================================================= 13:06:38: INFO: ==================== {SUCCESS} ======================== 13:06:38: INFO: ======================================================= 13:06:38: INFO: {percent files transferred 99.99%} 13:06:38: INFO: In handleProgram('userdata_82.img') 13:06:38: INFO: Looking for file 'userdata_82.img' 13:06:38: INFO: ======================================================= 13:06:38: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_82.img'} 13:06:38: INFO: {<program> (8.00 KB) 16 sectors needed at location 25759744 on LUN 0} 13:06:38: INFO: ======================================================= 13:06:38: INFO: TARGET SAID: 'start 25759744, num 16' 13:06:38: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:38: INFO: {percent files transferred 99.99%} 13:06:38: INFO: TARGET SAID: 'Finished sector address 25759760' 13:06:38: INFO: 13:06:38: INFO: ======================================================= 13:06:38: INFO: ==================== {SUCCESS} ======================== 13:06:38: INFO: ======================================================= 13:06:38: INFO: {percent files transferred 99.99%} 13:06:38: INFO: In handleProgram('userdata_83.img') 13:06:38: INFO: Looking for file 'userdata_83.img' 13:06:38: INFO: ======================================================= 13:06:38: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_83.img'} 13:06:38: INFO: {<program> (8.00 KB) 16 sectors needed at location 26021888 on LUN 0} 13:06:38: INFO: ======================================================= 13:06:38: INFO: TARGET SAID: 'start 26021888, num 16' 13:06:38: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:38: INFO: {percent files transferred 99.99%} 13:06:38: INFO: TARGET SAID: 'Finished sector address 26021904' 13:06:38: INFO: 13:06:38: INFO: ======================================================= 13:06:38: INFO: ==================== {SUCCESS} ======================== 13:06:38: INFO: ======================================================= 13:06:38: INFO: {percent files transferred 99.99%} 13:06:38: INFO: In handleProgram('userdata_84.img') 13:06:38: INFO: Looking for file 'userdata_84.img' 13:06:38: INFO: ======================================================= 13:06:38: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_84.img'} 13:06:38: INFO: {<program> (8.00 KB) 16 sectors needed at location 26284032 on LUN 0} 13:06:38: INFO: ======================================================= 13:06:38: INFO: TARGET SAID: 'start 26284032, num 16' 13:06:38: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:38: INFO: {percent files transferred 100.00%} 13:06:39: INFO: TARGET SAID: 'Finished sector address 26284048' 13:06:39: INFO: 13:06:39: INFO: ======================================================= 13:06:39: INFO: ==================== {SUCCESS} ======================== 13:06:39: INFO: ======================================================= 13:06:39: INFO: {percent files transferred 100.00%} 13:06:39: INFO: In handleProgram('userdata_85.img') 13:06:39: INFO: Looking for file 'userdata_85.img' 13:06:39: INFO: ======================================================= 13:06:39: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_85.img'} 13:06:39: INFO: {<program> (8.00 KB) 16 sectors needed at location 26546176 on LUN 0} 13:06:39: INFO: ======================================================= 13:06:39: INFO: TARGET SAID: 'start 26546176, num 16' 13:06:39: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:39: INFO: {percent files transferred 100.00%} 13:06:39: INFO: TARGET SAID: 'Finished sector address 26546192' 13:06:39: INFO: 13:06:39: INFO: ======================================================= 13:06:39: INFO: ==================== {SUCCESS} ======================== 13:06:39: INFO: ======================================================= 13:06:39: INFO: {percent files transferred 100.00%} 13:06:39: INFO: In handleProgram('userdata_86.img') 13:06:39: INFO: Looking for file 'userdata_86.img' 13:06:39: INFO: ======================================================= 13:06:39: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_86.img'} 13:06:39: INFO: {<program> (8.00 KB) 16 sectors needed at location 26808320 on LUN 0} 13:06:39: INFO: ======================================================= 13:06:39: INFO: TARGET SAID: 'start 26808320, num 16' 13:06:39: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:39: INFO: {percent files transferred 100.00%} 13:06:39: INFO: TARGET SAID: 'Finished sector address 26808336' 13:06:39: INFO: 13:06:39: INFO: ======================================================= 13:06:39: INFO: ==================== {SUCCESS} ======================== 13:06:39: INFO: ======================================================= 13:06:39: INFO: {percent files transferred 100.00%} 13:06:39: INFO: In handleProgram('userdata_87.img') 13:06:39: INFO: Looking for file 'userdata_87.img' 13:06:39: INFO: ======================================================= 13:06:39: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_87.img'} 13:06:39: INFO: {<program> (8.00 KB) 16 sectors needed at location 27070464 on LUN 0} 13:06:39: INFO: ======================================================= 13:06:39: INFO: TARGET SAID: 'start 27070464, num 16' 13:06:39: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:39: INFO: {percent files transferred 100.00%} 13:06:39: INFO: TARGET SAID: 'Finished sector address 27070480' 13:06:39: INFO: 13:06:39: INFO: ======================================================= 13:06:39: INFO: ==================== {SUCCESS} ======================== 13:06:39: INFO: ======================================================= 13:06:39: INFO: {percent files transferred 100.00%} 13:06:39: INFO: In handleProgram('userdata_88.img') 13:06:39: INFO: Looking for file 'userdata_88.img' 13:06:39: INFO: ======================================================= 13:06:39: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_88.img'} 13:06:39: INFO: {<program> (8.00 KB) 16 sectors needed at location 27332608 on LUN 0} 13:06:39: INFO: ======================================================= 13:06:39: INFO: TARGET SAID: 'start 27332608, num 16' 13:06:39: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps) 13:06:39: INFO: {percent files transferred 100.00%} 13:06:39: INFO: TARGET SAID: 'Finished sector address 27332624' 13:06:39: INFO: 13:06:39: INFO: ======================================================= 13:06:39: INFO: ==================== {SUCCESS} ======================== 13:06:39: INFO: ======================================================= 13:06:39: INFO: {percent files transferred 100.00%} 13:06:39: INFO: In handleProgram('gpt_main0.bin') 13:06:39: INFO: Looking for file 'gpt_main0.bin' 13:06:39: INFO: ======================================================= 13:06:39: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\gpt_main0.bin'} 13:06:39: INFO: {<program> (17.00 KB) 34 sectors needed at location 0 on LUN 0} 13:06:39: INFO: ======================================================= 13:06:40: INFO: TARGET SAID: 'start 0, num 34' 13:06:40: INFO: FILE ACCESS SLOW!! 17.00 KB in 0.015 seconds ( 1.11 MBps) --- Overall to target 0.010 seconds (1.66 MBps) 13:06:40: INFO: {percent files transferred 100.00%} 13:06:40: INFO: TARGET SAID: 'Finished sector address 34' 13:06:40: INFO: 13:06:40: INFO: ======================================================= 13:06:40: INFO: ==================== {SUCCESS} ======================== 13:06:40: INFO: ======================================================= 13:06:40: INFO: {percent files transferred 100.00%} 13:06:40: INFO: In handleProgram('gpt_backup0.bin') 13:06:40: INFO: Looking for file 'gpt_backup0.bin' 13:06:40: INFO: ======================================================= 13:06:40: INFO: {<program> FILE: 'C:\Users\thanhnamPDAviet\Desktop\1\gpt_backup0.bin'} 13:06:40: INFO: {<program> (16.50 KB) 33 sectors needed at location 0 on LUN 0} 13:06:40: INFO: ======================================================= 13:06:40: INFO: TARGET SAID: 'start 30535647, num 33' 13:06:40: INFO: FILE ACCESS SLOW!! 16.50 KB in 0.015 seconds ( 1.07 MBps) --- Overall to target 0.010 seconds (1.61 MBps) 13:06:40: INFO: {percent files transferred 100.00%} 13:06:40: INFO: TARGET SAID: 'Finished sector address 30535680' 13:06:40: INFO: 13:06:40: INFO: ======================================================= 13:06:40: INFO: ==================== {SUCCESS} ======================== 13:06:40: INFO: ======================================================= 13:06:40: INFO: {percent files transferred 100.00%} 13:06:40: INFO: ============================================================== 13:06:40: INFO: Files used and their paths 13:06:40: INFO: 1 'C:\Users\thanhnamPDAviet\AppData\Roaming\Qualcomm\QFIL\port_trace.txt' 13:06:40: INFO: 2 'C:\Users\thanhnamPDAviet\Desktop\1\rawprogram_unsparse.xml' 13:06:40: INFO: 3 'C:\Users\thanhnamPDAviet\Desktop\1\NON-HLOS.bin' 13:06:40: INFO: 4 'C:\Users\thanhnamPDAviet\Desktop\1\sbl1.mbn' 13:06:40: INFO: 5 'C:\Users\thanhnamPDAviet\Desktop\1\rpm.mbn' 13:06:40: INFO: 6 'C:\Users\thanhnamPDAviet\Desktop\1\tz.mbn' 13:06:40: INFO: 7 'C:\Users\thanhnamPDAviet\Desktop\1\hyp.mbn' 13:06:40: INFO: 8 'C:\Users\thanhnamPDAviet\Desktop\1\sec.dat' 13:06:40: INFO: 9 'C:\Users\thanhnamPDAviet\Desktop\1\emmc_appsboot.mbn' 13:06:40: INFO: 10 'C:\Users\thanhnamPDAviet\Desktop\1\splash.img' 13:06:40: INFO: 11 'C:\Users\thanhnamPDAviet\Desktop\1\boot.img' 13:06:40: INFO: 12 'C:\Users\thanhnamPDAviet\Desktop\1\recovery.img' 13:06:40: INFO: 13 'C:\Users\thanhnamPDAviet\Desktop\1\system_1.unsparse' 13:06:40: INFO: 14 'C:\Users\thanhnamPDAviet\Desktop\1\system_2.unsparse' 13:06:40: INFO: 15 'C:\Users\thanhnamPDAviet\Desktop\1\system_3.unsparse' 13:06:40: INFO: 16 'C:\Users\thanhnamPDAviet\Desktop\1\system_4.unsparse' 13:06:40: INFO: 17 'C:\Users\thanhnamPDAviet\Desktop\1\system_5.unsparse' 13:06:40: INFO: 18 'C:\Users\thanhnamPDAviet\Desktop\1\system_6.unsparse' 13:06:40: INFO: 19 'C:\Users\thanhnamPDAviet\Desktop\1\system_7.unsparse' 13:06:40: INFO: 20 'C:\Users\thanhnamPDAviet\Desktop\1\system_8.unsparse' 13:06:40: INFO: 21 'C:\Users\thanhnamPDAviet\Desktop\1\system_9.unsparse' 13:06:40: INFO: 22 'C:\Users\thanhnamPDAviet\Desktop\1\system_10.unsparse' 13:06:40: INFO: 23 'C:\Users\thanhnamPDAviet\Desktop\1\system_11.unsparse' 13:06:40: INFO: 24 'C:\Users\thanhnamPDAviet\Desktop\1\system_12.unsparse' 13:06:40: INFO: 25 'C:\Users\thanhnamPDAviet\Desktop\1\system_13.unsparse' 13:06:40: INFO: 26 'C:\Users\thanhnamPDAviet\Desktop\1\system_14.unsparse' 13:06:40: INFO: 27 'C:\Users\thanhnamPDAviet\Desktop\1\system_15.unsparse' 13:06:40: INFO: 28 'C:\Users\thanhnamPDAviet\Desktop\1\system_16.unsparse' 13:06:40: INFO: 29 'C:\Users\thanhnamPDAviet\Desktop\1\system_17.unsparse' 13:06:40: INFO: 30 'C:\Users\thanhnamPDAviet\Desktop\1\system_18.unsparse' 13:06:40: INFO: 31 'C:\Users\thanhnamPDAviet\Desktop\1\system_19.unsparse' 13:06:40: INFO: 32 'C:\Users\thanhnamPDAviet\Desktop\1\system_20.unsparse' 13:06:40: INFO: 33 'C:\Users\thanhnamPDAviet\Desktop\1\cache_1.img' 13:06:40: INFO: 34 'C:\Users\thanhnamPDAviet\Desktop\1\cache_2.img' 13:06:40: INFO: 35 'C:\Users\thanhnamPDAviet\Desktop\1\cache_3.img' 13:06:40: INFO: 36 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_1.img' 13:06:40: INFO: 37 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_2.img' 13:06:40: INFO: 38 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_3.img' 13:06:40: INFO: 39 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_4.img' 13:06:40: INFO: 40 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_5.img' 13:06:40: INFO: 41 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_6.img' 13:06:40: INFO: 42 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_7.img' 13:06:40: INFO: 43 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_8.img' 13:06:40: INFO: 44 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_9.img' 13:06:40: INFO: 45 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_10.img' 13:06:40: INFO: 46 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_11.img' 13:06:40: INFO: 47 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_12.img' 13:06:40: INFO: 48 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_13.img' 13:06:40: INFO: 49 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_14.img' 13:06:40: INFO: 50 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_15.img' 13:06:40: INFO: 51 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_16.img' 13:06:40: INFO: 52 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_17.img' 13:06:40: INFO: 53 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_18.img' 13:06:40: INFO: 54 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_19.img' 13:06:40: INFO: 55 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_20.img' 13:06:40: INFO: 56 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_21.img' 13:06:40: INFO: 57 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_22.img' 13:06:40: INFO: 58 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_23.img' 13:06:40: INFO: 59 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_24.img' 13:06:40: INFO: 60 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_25.img' 13:06:40: INFO: 61 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_26.img' 13:06:40: INFO: 62 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_27.img' 13:06:40: INFO: 63 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_28.img' 13:06:40: INFO: 64 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_29.img' 13:06:40: INFO: 65 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_30.img' 13:06:40: INFO: 66 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_31.img' 13:06:40: INFO: 67 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_32.img' 13:06:40: INFO: 68 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_33.img' 13:06:40: INFO: 69 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_34.img' 13:06:40: INFO: 70 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_35.img' 13:06:40: INFO: 71 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_36.img' 13:06:40: INFO: 72 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_37.img' 13:06:40: INFO: 73 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_38.img' 13:06:40: INFO: 74 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_39.img' 13:06:40: INFO: 75 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_40.img' 13:06:40: INFO: 76 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_41.img' 13:06:40: INFO: 77 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_42.img' 13:06:40: INFO: 78 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_43.img' 13:06:40: INFO: 79 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_44.img' 13:06:40: INFO: 80 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_45.img' 13:06:40: INFO: 81 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_46.img' 13:06:40: INFO: 82 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_47.img' 13:06:40: INFO: 83 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_48.img' 13:06:40: INFO: 84 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_49.img' 13:06:40: INFO: 85 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_50.img' 13:06:40: INFO: 86 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_51.img' 13:06:40: INFO: 87 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_52.img' 13:06:40: INFO: 88 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_53.img' 13:06:40: INFO: 89 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_54.img' 13:06:40: INFO: 90 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_55.img' 13:06:40: INFO: 91 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_56.img' 13:06:40: INFO: 92 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_57.img' 13:06:40: INFO: 93 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_58.img' 13:06:40: INFO: 94 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_59.img' 13:06:40: INFO: 95 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_60.img' 13:06:40: INFO: 96 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_61.img' 13:06:40: INFO: 97 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_62.img' 13:06:40: INFO: 98 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_63.img' 13:06:40: INFO: 99 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_64.img' 13:06:40: INFO: 100 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_65.img' 13:06:40: INFO: 101 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_66.img' 13:06:40: INFO: 102 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_67.img' 13:06:40: INFO: 103 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_68.img' 13:06:40: INFO: 104 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_69.img' 13:06:40: INFO: 105 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_70.img' 13:06:40: INFO: 106 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_71.img' 13:06:40: INFO: 107 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_72.img' 13:06:40: INFO: 108 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_73.img' 13:06:40: INFO: 109 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_74.img' 13:06:40: INFO: 110 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_75.img' 13:06:40: INFO: 111 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_76.img' 13:06:40: INFO: 112 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_77.img' 13:06:40: INFO: 113 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_78.img' 13:06:40: INFO: 114 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_79.img' 13:06:40: INFO: 115 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_80.img' 13:06:40: INFO: 116 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_81.img' 13:06:40: INFO: 117 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_82.img' 13:06:40: INFO: 118 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_83.img' 13:06:40: INFO: 119 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_84.img' 13:06:40: INFO: 120 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_85.img' 13:06:40: INFO: 121 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_86.img' 13:06:40: INFO: 122 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_87.img' 13:06:40: INFO: 123 'C:\Users\thanhnamPDAviet\Desktop\1\userdata_88.img' 13:06:40: INFO: 124 'C:\Users\thanhnamPDAviet\Desktop\1\gpt_main0.bin' 13:06:40: INFO: 125 'C:\Users\thanhnamPDAviet\Desktop\1\gpt_backup0.bin' 13:06:40: INFO: _ (done) 13:06:40: INFO: | | 13:06:40: INFO: __| | ___ _ __ ___ 13:06:40: INFO: / _` |/ _ \| '_ \ / _ \ 13:06:40: INFO: | (_| | (_) | | | | __/ 13:06:40: INFO: \__,_|\___/|_| |_|\___| 13:06:40: INFO: {All Finished Successfully} 13:06:40: INFO: Overall to target 140.167 seconds (10.05 MBps) 13:06:40: INFO: {percent files transferred 100.00%} Writing log to 'C:\Users\thanhnamPDAviet\AppData\Roaming\Qualcomm\QFIL\port_trace.txt', might take a minute Log is 'C:\Users\thanhnamPDAviet\AppData\Roaming\Qualcomm\QFIL\port_trace.txt' Binary build date: Jun 3 2015 @ 17:12:06 Build version: 15.06. 3.17.12.06 13:06:40: INFO: FH_LOADER WAS CALLED EXACTLY LIKE THIS ************************************************ C:\Program Files\Qualcomm\QPST\bin\fh_loader.exe --port=\\.\COM2 --sendxml=patch0.xml --search_path=C:\Users\thanhnamPDAviet\Desktop\1 --noprompt --showpercentagecomplete --zlpawarehost=1 --memoryname=eMMC ************************************************ 13:06:40: INFO: Current working dir (cwd): C:\Users\thanhnamPDAviet\AppData\Roaming\Qualcomm\QFIL\ 13:06:40: INFO: Showing network mappings to allow debugging 13:06:40: INFO: 13:06:40: INFO: Trying to store 'patch0.xml' in string table 13:06:40: INFO: Looking for file 'patch0.xml' 13:06:40: INFO: User wants to talk to port '\\.\COM2' 13:06:40: INFO: Took 0.00000000 seconds to open port 13:06:40: INFO: Sorting TAGS to ensure order is <configure>,<erase>, others, <patch>,<power> 13:06:40: INFO: If you don't want this, use --dontsorttags 13:06:40: INFO: Sending <configure> 13:06:41: INFO: TARGET SAID: 'Host's payload to target size is too large' 13:06:41: INFO: TARGET SAID: 'logbuf@0x0801DC08 fh@0x0801AA70' 13:06:41: INFO: fh.attrs.MaxPayloadSizeToTargetInBytes = 16384 13:06:41: INFO: fh.attrs.MaxPayloadSizeToTargetInBytesSupported = 16384 13:06:41: INFO: Target returned NAK for your <configure> but it does not seem to be an error. This is ok, fh_loader.exe attributes updated 13:06:41: INFO: TARGET SAID: 'Patched sector 9 with 01D1EFDE' 13:06:41: INFO: TARGET SAID: 'Patched sector 30535654 with 01D1EFDE' 13:06:41: INFO: TARGET SAID: 'Patched sector 1 with 01D1EFDE' 13:06:41: INFO: TARGET SAID: 'Patched sector 30535679 with 01D1EFDE' 13:06:41: INFO: TARGET SAID: 'Patched sector 1 with 01D1EFFF' 13:06:41: INFO: TARGET SAID: 'Patched sector 30535679 with 01D1EFFF' 13:06:41: INFO: TARGET SAID: 'Patched sector 30535679 with 01D1EFDF' 13:06:41: INFO: TARGET SAID: 'crc start sector 2, over bytes 4096' 13:06:41: INFO: TARGET SAID: 'Patched sector 1 with 8B757AB0' 13:06:42: INFO: TARGET SAID: 'crc start sector 30535647, over bytes 4096' 13:06:42: INFO: TARGET SAID: 'Patched sector 30535679 with 8B757AB0' 13:06:42: INFO: TARGET SAID: 'Patched sector 1 with 00000000' 13:06:42: INFO: TARGET SAID: 'crc start sector 1, over bytes 92' 13:06:42: INFO: TARGET SAID: 'Patched sector 1 with 39E6896F' 13:06:42: INFO: TARGET SAID: 'Patched sector 30535679 with 00000000' 13:06:42: INFO: TARGET SAID: 'crc start sector 30535679, over bytes 92' 13:06:42: INFO: TARGET SAID: 'Patched sector 30535679 with AF3F1C81' 13:06:42: INFO: ============================================================== 13:06:42: INFO: Files used and their paths 13:06:42: INFO: 1 'C:\Users\thanhnamPDAviet\AppData\Roaming\Qualcomm\QFIL\port_trace.txt' 13:06:42: INFO: 2 'C:\Users\thanhnamPDAviet\Desktop\1\patch0.xml' 13:06:42: INFO: _ (done) 13:06:42: INFO: | | 13:06:42: INFO: __| | ___ _ __ ___ 13:06:42: INFO: / _` |/ _ \| '_ \ / _ \ 13:06:42: INFO: | (_| | (_) | | | | __/ 13:06:42: INFO: \__,_|\___/|_| |_|\___| 13:06:42: INFO: {All Finished Successfully} 13:06:42: INFO: FILE ACCESS SLOW!! 0.00 B in 0.015 seconds ( 0.00 Bps) --- Overall to target 1.529 seconds (0.00 Bps) Writing log to 'C:\Users\thanhnamPDAviet\AppData\Roaming\Qualcomm\QFIL\port_trace.txt', might take a minute Log is 'C:\Users\thanhnamPDAviet\AppData\Roaming\Qualcomm\QFIL\port_trace.txt' Binary build date: Jun 3 2015 @ 17:12:06 Build version: 15.06. 3.17.12.06 13:06:42: INFO: FH_LOADER WAS CALLED EXACTLY LIKE THIS ************************************************ C:\Program Files\Qualcomm\QPST\bin\fh_loader.exe --port=\\.\COM2 --noprompt --showpercentagecomplete --zlpawarehost=1 --memoryname=eMMC --setactivepartition=0 ************************************************ 13:06:42: INFO: Current working dir (cwd): C:\Users\thanhnamPDAviet\AppData\Roaming\Qualcomm\QFIL\ 13:06:42: INFO: Showing network mappings to allow debugging 13:06:42: INFO: User wants to talk to port '\\.\COM2' 13:06:42: INFO: Took 0.00000000 seconds to open port 13:06:42: INFO: Sorting TAGS to ensure order is <configure>,<erase>, others, <patch>,<power> 13:06:42: INFO: If you don't want this, use --dontsorttags 13:06:42: INFO: Sending <configure> 13:06:42: INFO: TARGET SAID: 'Host's payload to target size is too large' 13:06:42: INFO: TARGET SAID: 'logbuf@0x0801DC08 fh@0x0801AA70' 13:06:42: INFO: fh.attrs.MaxPayloadSizeToTargetInBytes = 16384 13:06:42: INFO: fh.attrs.MaxPayloadSizeToTargetInBytesSupported = 16384 13:06:42: INFO: Target returned NAK for your <configure> but it does not seem to be an error. This is ok, fh_loader.exe attributes updated 13:06:42: INFO: Sending <setbootablestoragedrive> 13:06:42: INFO: TARGET SAID: 'Set bootable drive to 0.' 13:06:42: INFO: ============================================================== 13:06:42: INFO: Files used and their paths 13:06:42: INFO: 1 'C:\Users\thanhnamPDAviet\AppData\Roaming\Qualcomm\QFIL\port_trace.txt' 13:06:42: INFO: _ (done) 13:06:42: INFO: | | 13:06:42: INFO: __| | ___ _ __ ___ 13:06:42: INFO: / _` |/ _ \| '_ \ / _ \ 13:06:42: INFO: | (_| | (_) | | | | __/ 13:06:42: INFO: \__,_|\___/|_| |_|\___| 13:06:42: INFO: {All Finished Successfully} 13:06:42: INFO: FILE ACCESS SLOW!! 0.00 B in 0.015 seconds ( 0.00 Bps) --- Overall to target 0.218 seconds (0.00 Bps) Writing log to 'C:\Users\thanhnamPDAviet\AppData\Roaming\Qualcomm\QFIL\port_trace.txt', might take a minute Log is 'C:\Users\thanhnamPDAviet\AppData\Roaming\Qualcomm\QFIL\port_trace.txt' Download Succeed Finish Download
