iphone x treo táo khởi động lại cần giúp
Thảo luận trong 'SỬA CHỮA PHẦN CỨNG.' bắt đầu bởi tunglg, 15/8/23.
  1. 15/8/23 lúc 11:25
    tunglg
    tunglg
    con ip X của mình để kênh màn thì dùng ok nhưng cứ ráp màn hình vào là treo táo khởi động lại ,mong anh em giúp đỡ
    {"bug_type":"210","timestamp":"2023-04-30 07:02:18.00 +0900","os_version":"iPhone OS 15.6.1 (19G82)","incident_id":"BFEE5D92-9FAA-461C-AB15-1DF9FA32CC7E"}
    "build" : "iPhone OS 15.6.1 (19G82)",
    "product" : "iPhone10,3",
    "socId" : "0x00008015",
    "kernel" : "Darwin Kernel Version 21.6.0: Wed Aug 10 15:38:24 PDT 2022; root:xnu-8020.142.2~1\/RELEASE_ARM64_T8015",
    "incident" : "BFEE5D92-9FAA-461C-AB15-1DF9FA32CC7E",
    "crashReporterKey" : "b79608887319398ae1120c87746af4a5b20700bc",
    "date" : "2023-04-30 07:02:18.35 +0900",
    "panicString" : "panic(cpu 0 caller 0xfffffff01644c560): userspace watchdog timeout: no successful checkins from SpringBoard since monitoring enabled by backboardd (89 seconds ago)\nservice: backboardd, total successful checkins since load (100 seconds ago): 11, last successful checkin: 0 seconds ago\nservice: SpringBoard, no successful checkins since monitoring enabled by backboardd (89 seconds ago)\nservice: mediaserverd, total successful checkins since load (100 seconds ago): 5, last successful checkin: 0 seconds ago\nservice: logd, total successful checkins since load (100 seconds ago): 11, last successful checkin: 0 seconds ago\nservice: thermalmonitord, total successful checkins since load (100 seconds ago): 3, last successful checkin: 0 seconds ago\nservice: runningboardd, total successful checkins since load (100 seconds ago): 11, last successful checkin: 0 seconds ago\nservice: wifid, total successful checkins since load (100 seconds ago): 4, last successful checkin: 10 seconds ago\n\nDebugger message: panic\nMemory ID: 0x1\nOS release type: User\nOS version: 19G82\nKernel version: Darwin Kernel Version 21.6.0: Wed Aug 10 15:38:24 PDT 2022; root:xnu-8020.142.2~1\/RELEASE_ARM64_T8015\nKernel UUID: C16FAFF4-4A21-36DC-9C96-306BFFB1BCDC\niBoot version: iBoot-7459.140.15\nsecure boot?: YES\nPaniclog version: 13\nKernel slide: 0x000000000cf68000\nKernel text base: 0xfffffff013f6c000\nmach_absolute_time: 0xb079c58e\nEpoch Time: sec usec\n Boot : 0x644d9361 0x000a7b48\n Sleep : 0x00000000 0x00000000\n Wake : 0x00000000 0x00000000\n Calendar: 0x644d93ce 0x00099d47\n\nZone info:\n Zone map: 0xffffffe271f3c000 - 0xffffffe871f3c000\n . VM : 0xffffffe271f3c000 - 0xffffffe3585a0000\n . RO : 0xffffffe3585a0000 - 0xffffffe3a526c000\n . GEN0 : 0xffffffe3a526c000 - 0xffffffe48b8d0000\n . GEN1 : 0xffffffe48b8d0000 - 0xffffffe571f34000\n . GEN2 : 0xffffffe571f34000 - 0xffffffe65859c000\n . GEN3 : 0xffffffe65859c000 - 0xffffffe73ec04000\n . DATA : 0xffffffe73ec04000 - 0xffffffe871f3c000\n Metadata: 0xffffffe872138000 - 0xffffffe873938000\n Bitmaps : 0xffffffe873938000 - 0xffffffe874938000\n\nCORE 0 is the one that panicked. Check the full backtrace for details.\nCORE 1: PC=0xfffffff014aec1a4, LR=0xfffffff014aec1a4, FP=0xffffffe271a13f00\nCORE 2: PC=0x0000000180bb9c1c, LR=0x0000000180bb9b24, FP=0x000000016b3e20f0\nCORE 3: PC=0xfffffff014aec1a4, LR=0xfffffff014aec1a4, FP=0xffffffe271a23f00\nCORE 4: PC=0xfffffff014bf7578, LR=0xfffffff014bf7574, FP=0xffffffe9f6833e90\nCORE 5: PC=0xfffffff014aec1a4, LR=0xfffffff014aec1a4, FP=0xffffffe271d63f00\nCompressor Info: 0% of compressed pages limit (OK) and 0% of segments limit (OK) with 0 swapfiles and OK swap space\nTotal cpu_usage: 44744575\nThread task pri cpu_usage\n0xffffffe48c3728b0 watchdogd 97 0\n0xffffffe48c64b640 watchdogd 31 0\n0xffffffe48befef78 kernel_task 0 5058348\n0xffffffe48b9306c8 kernel_task 0 0\n0xffffffe48befc6c8 kernel_task 0 0\n\nPanicked task 0xffffffe572b87240: 229 pages, 3 threads: pid 60: watchdogd\nPanicked thread: 0xffffffe48c3728b0, backtrace: 0xffffffe2719b3200, tid: 1234\n\t\t lr: 0xfffffff014abd7f4 fp: 0xffffffe2719b3240\n\t\t lr: 0xfffffff014abd57c fp: 0xffffffe2719b32b0\n\t\t lr: 0xfffffff014bf4de8 fp: 0xffffffe2719b3320\n\t\t lr: 0xfffffff014bf3de0 fp: 0xffffffe2719b33d0\n\t\t lr: 0xfffffff0151655fc fp: 0xffffffe2719b33e0\n\t\t lr: 0xfffffff014abd2a4 fp: 0xffffffe2719b3770\n\t\t lr: 0xfffffff014abd2a4 fp: 0xffffffe2719b37d0\n\t\t lr: 0xfffffff0164bf528 fp: 0xffffffe2719b37f0\n\t\t lr: 0xfffffff01644c560 fp: 0xffffffe2719b3810\n\t\t lr: 0xfffffff01644bf54 fp: 0xffffffe2719b3830\n\t\t lr: 0xfffffff01644b43c fp: 0xffffffe2719b3950\n\t\t lr: 0xfffffff0150e99e8 fp: 0xffffffe2719b3af0\n\t\t lr: 0xfffffff014bbc868 fp: 0xffffffe2719b3c10\n\t\t lr: 0xfffffff014ac3a1c fp: 0xffffffe2719b3ca0\n\t\t lr: 0xfffffff014a974d0 fp: 0xffffffe2719b3d00\n\t\t lr: 0xfffffff014aadf68 fp: 0xffffffe2719b3d90\n\t\t lr: 0xfffffff014be9338 fp: 0xffffffe2719b3e60\n\t\t lr: 0xfffffff014bf4234 fp: 0xffffffe2719b3f10\n\t\t lr: 0xfffffff0151655fc fp: 0xffffffe2719b3f20\n\n",
    "panicFlags" : "0x802",
    "otherString" : "\n** Stackshot Succeeded ** Bytes Traced 136193 (Uncompressed 352816) **\n",
    "memoryStatus" : {"compressorSize":0,"compressions":0,"decompressions":0,"busyBufferCount":0,"memoryPressureDetails":{"pagesWanted":0,"pagesReclaimed":0},"pageSize":16384,"memoryPressure":false,"memoryPages":{"active":65268,"throttled":0,"fileBacked":95738,"wired":25111,"purgeable":380,"inactive":21914,"free":5882,"speculative":45013}
  2. 15/8/23 lúc 14:29
    anhtuhonglinh
    anhtuhonglinh
    kênh màn dùng ok, ráp vào reset thì anh coi kĩ coi gập, chạm cáp đâu đó ko, main có hở gì ko.
    còn tình trạng như cái panic anh đăng thì ko phải cấn chạm hay gì đâu.
    panic có trăm ngàn lỗi, em cũng ko nhớ hết dc, nhưng riêng wachdog timeout không có điểm missing sensor như của anh thì không xác định được nguyên nhân lỗi.
    em từng rảnh sàng luôn cả main mới nhưng vẫn lỗi, ko hết.
    có thể kinh nghiệm em còn non, lỗi này em bó tay. :)))))
    tunglg thích bài này.
  3. 16/8/23 lúc 09:25
    Nuyễn Vỹ
    Nuyễn Vỹ
    Ơ anh ơi cho em hỏi tí, là phải có dòng missing sensor mới xác định được là do mic hay cụm à anh, tại em cũng gặp vài quả giống như chủ tus mà em thử thay đuôi sạc vẫn done
  4. 16/8/23 lúc 10:04
    anhtuhonglinh
    anhtuhonglinh
    đúng vậy.
    tunglgNuyễn Vỹ thích điều này.
