công cụ chạy trên win :http://www.mediafire.com/download/c42w72jfqdrvowb/Linux_Reader.rar anh em làm theo hướng dẫn như hình sẽ ok dùng 7z để giải nén mở sgs2toext4.jar convert file system.img >>ext4.img tiếp mở công cụ Linux_Reader.exe để mount sẽ được như hình
gần Tết ae 4rum share toàn kèo hot, kiểu này mong đến Tết hoài mất thôi, Can be used on most Samsung Galaxy phones. Each TAR.MD5 release contains multiple files. Each of these files corresponds to a specific partition on your device. These files are formatted to be mounted by your device but not by a computer. We will be converting them from a .img partition type to an .img.ext4 type partition so we can mount them and read them through Windows. For this tutorial we will be opening up the system.img (the system files partition). Prerequisites A PC running Windows. A stock TAR.MD5 release. DiskInternals Linux Reader (must be installed on the Windows PC). SGS2toEXT4 Utility. *Be sure to extract the JAR file from the ZIP archive. 7-Zip . InstructionsRight click on the TAR.MD5 and select Open with 7-Zip.A message will popup that says, "There is no correct record at the end of archive." Press ok and ignore it.Extract system.img to your desktop (or folder of choice).Run the sgs2toext4.jar utility. A window titled "Drop .img here" will popup.Take the system.img icon and drag and drop it into the white space on the "Drop .img here" window. It will now create a new file on your desktop titled system.ext4.img.Close the "Drop .img here" window.Open DiskInternals Linux Reader.Select "Mount image" from the column on the left.Make sure the "Raw Disk Images" option is selected and press Next.Navigate to where you saved system.ext4.img and select it.You will now see a new Hard Disk Drive titled "Linux Ext Volume 1".You can now select the drive and navigate it the same as you would on your device.*You can mount multiple ext4 images at one time so make sure you select the right one.To extract a file you select / highlight it and then press save at the top. This will extract the file from the ext4 partition and save it to Windows. Congratulations you have unpacked your first system.img from a TAR.MD5!
bạn vô ổ c copy dường dẫn như zậy C:\Program Files\Java\jre7\bin\java.exe" -jar sgs2toext4.jar đánh trên cmd nhé là nó sẽ chạy
copy công cụ vào ổ d hoặc f gì đó giản nén ra ,ở cửa xổ lúc đó bạn lấy 1 tay nhấn shift trên bàn phím sẽ hiện ra bảng có dòng chữ commant cmd rời gõ như hình
