Huawei GR5 BLL-L22 Mở Khoa FRP By Chimera Nhận Mở Khóa Gmail - FRP Huawei GR5 BLL-L22 Qua Teamviewer Mã: [Removing factory reset protection...] Collecting information about the device... Trying to remove factory reset protection lock... This did not work, trying some other ways... Checking if we need to do some magic... Reading secret... Calculating some magic from the secret... This may take a while. Be patient! Do NOT disconnect the phone! Sending magic to the device... Checking if the magic succeed... Wiping device... Finished successfully. Finished at local time: [03.03.17 11:25:10] WorkID:
Huawei GR5 (BLL-L22) Mở Khóa Xác Minh Tài haonr Gmail By Chimera Huawei GR5 (BLL-L22) Removing factory reset protection Mã: [Removing factory reset protection...] Collecting information about the device... Trying to remove factory reset protection lock... This did not work, trying some other ways... Checking if we need to do some magic... Reading secret... Calculating some magic from the secret... This may take a while. Be patient! Do NOT disconnect the phone! Sending magic to the device... Checking if the magic succeed... Wiping device... Finished successfully.
Huawei GR5 BLL-L22 Remove FRP By Chimera Huawei GR5 BLL-L22 Xóa Tài Khoản Gmail By Chimera Làm cho khách ở xa,nên phải làm qua Team.Mã:Removing factory reset protection lock... This way did not work. Removing factory reset protection lock... This way did not work. Checking if factory challenge needed... Reading factory challenge... Calculating response for the challenge... This may take a while. Be patient! Do NOT disconnect the phone! Sending response to the device... Checking if the factory challenge-response succeed... Wiping device... Finished successfully.
Huawei GR5 Mini BLL-L22 Khóa Xác Minh Tài Khoản Gmail Huawei GR5 Mini BLL-L22 Xóa FRP By ChimeraMã:@thanhnamPDAviet [Removing factory reset protection...] Collecting information about the device... Removing factory reset protection lock... This way did not work. Removing factory reset protection lock... This way did not work. Checking if factory challenge needed... Reading factory challenge... Calculating response for the challenge... This may take a while. Be patient! Do NOT disconnect the phone! Sending response to the device... Checking if the factory challenge-response succeed... Wiping device... Finished successfully. Finished at local time: [08.04.17 13:06:09]
Huawei GR5 2017 BLL-L22 Khóa Xác Minh Tài Khoản Gmail (FRP) Huawei GR5 2017 BLL-L22 Xóa FRP By Chimera. Mã:@thanhnamPDAviet [Removing factory reset protection...] Collecting information about the device... Removing factory reset protection lock... This way did not work. Removing factory reset protection lock... This way did not work. Checking if factory challenge needed... Reading factory challenge... Calculating response for the challenge... This may take a while. Be patient! Do NOT disconnect the phone! Sending response to the device... Checking if the factory challenge-response succeed... Wiping device... Finished successfully. Finished at local time: [08.23.17 08:50:16]
Huawei GR5 BLL-L22 Khóa Xác Minh Tài Khoản Gmail Huawei GR5 BLL-L22 Xóa FRP By ChimeraMã:@thanhnamPDAviet 2017-08-26 Printing phone history Update Firmware 8/26/2017 9:28:41 AM Update Firmware 8/26/2017 9:08:46 AM [Removing factory reset protection...] Collecting information about the device... Removing factory reset protection lock... This way did not work. Removing factory reset protection lock... This way did not work. Checking if factory challenge needed... Reading factory challenge... Calculating response for the challenge... This may take a while. Be patient! Do NOT disconnect the phone! Sending response to the device... Checking if the factory challenge-response succeed... Wiping device... Finished successfully. Finished at local time: [08.26.17 17:02:17]
Huawei GR5 2017 BLL-L22 Khóa Xác Minh Tài Khoản Gmail (FRP) Huawei GR5 2017 BLL-L22 Remove FRP By EFY Huawei GR5 2017 BLL-L22 Remove FRP Via TeamviewerMã:@thanhnamPDAviet Connecting Fastboot ... Connecting Fastboot Ok Model Phone:BLL-L22 SW: :BLL-L22C636B370 Connecting Server .. Connecting Server Ok Erase Success , The Device Will Reboot And Factory Resets
