Help C2.01
Thảo luận trong 'SỬA CHỮA PHẦN CỨNG.' bắt đầu bởi cuongbonn, 10/12/15.
  1. 10/12/15 lúc 11:03
    cuongbonn
    cuongbonn
    Các bác xem hộ em file log với
    Nhờ cao nhân chỉ giáo
    Flashing started
    Creating product data items list
    Product data items list created
    Backup not required
    Flashing phone
    Initializing
    Scanning image files...
    Waiting for USB device...
    Loading secondary boot code: 15040 bytes
    Secondary boot loaded
    BB Asic Index is: 00
    Asic ID is: 000000010000022600000001020C192102044100
    EM Asic ID is: 00001051
    EM Asic ID is: 00001060
    Public ID is: 13A0011092B963402E6A8455780CFFE5BF1A29B1
    Asic Mode ID: 00
    Hash: 7B045400E1752022F9EB80B0DEA9C65D
    ROM ID: 67E82268F29CEA60
    Device type is: 05
    Device Index is: 00
    Manufacturer code: 0000
    Device ID: 0000
    Extended device ID: 0000
    Revision ID: 0000
    Device type is: 04
    Device Index is: 00
    Manufacturer code: FFFF
    Device ID: 0000
    Revision ID: 0000
    Device type is: 00
    Device Index is: 00
    Device ID: 0000
    Revision ID: 0000
    Device type is: 00
    Device Index is: 01
    Device ID: 0001
    Revision ID: 0000
    Device type is: 03
    Device Index is: 00
    Manufacturer code: 00EC
    Device ID: 0030
    Revision ID: 0431
    Loading update server code: 634586 bytes
    Update server loaded
    Asic CMT: Start programming 56485 KB...
    Asic CMT: Programming data sent: 0%
    Asic CMT: Programming data sent: 10%
    Asic CMT: Programming data sent: 20%
    Asic CMT: Programming data sent: 30%
    Asic CMT: Programming data sent: 40%
    Asic CMT: Programming data sent: 50%
    Asic CMT: Programming data sent: 60%
    Asic CMT: Programming data sent: 70%
    Asic CMT: Programming data sent: 80%
    Asic CMT: Programming data sent: 90%
    Asic CMT: Programming data sent: 100%
    Programming complete
    Asic CMT: Verifying communication to device...
    Waiting for communication response: 25
    Waiting for communication response: 24
    Waiting for communication response: 23
    Waiting for communication response: 22
    Waiting for communication response: 21
    Waiting for communication response: 20
    Waiting for communication response: 19
    Waiting for communication response: 18
    Waiting for communication response: 17
    Waiting for communication response: 16
    Waiting for communication response: 15
    Waiting for communication response: 14
    Waiting for communication response: 13
    Waiting for communication response: 12
    Waiting for communication response: 11
    Waiting for communication response: 10
    Waiting for communication response: 9
    Waiting for communication response: 8
    Waiting for communication response: 7
    Waiting for communication response: 6
    Waiting for communication response: 5
    Waiting for communication response: 4
    Waiting for communication response: 3
    Error 0x8401F121 communicating to phone. Unable to verify comm.
    Warning: Unable to communicate to product after flashing
    Starting to recover the phone
    Recovering phone
    Initializing
    Phone recovery completed. Waiting for phone to boot up
    Bootup successful
    Verifying communication to product (before flash finalizing)
    Failed to verfy communication to product
    All operations completed
    Firmware updating failed.
  2. 10/12/15 lúc 11:12
    Tmobile_VFS
    Tmobile_VFS
    tình trạng ban đầu thế nào ? có box thì flash thử xem được ko? hơi nghi nghi quá ;)
  3. 10/12/15 lúc 11:25
    cuongbonn
    cuongbonn
    cắm nguồn thì lên hình sạc pin
    em bật máy lên thì hiện nokia xong mất ấn phím bất kì thì lên màn trắng xóa rồi tắt
  4. 10/12/15 lúc 11:34
    caothanhchuyen
    caothanhchuyen
    tải fw cao nhất hoặc file chuẩn rồi flash lại xem nào.vệ sinh sạch chân usb.đã từng bị 2730 như thế
  5. 10/12/15 lúc 11:36
    Tùng Nguyễn GSM
    Tùng Nguyễn GSM
    Quăng team lên or liên hệ chữ kí em làm thử sao e nạp hoài đâu có lỗi bác giống như lỗi sai fw sao á
  6. 10/12/15 lúc 12:21
    cuongbonn
    cuongbonn
    Vâng em cảm ơn bác để em thử xem sao
  7. 10/12/15 lúc 12:21
    cuongbonn
    cuongbonn
    để em vệ sinh chân usb rồi thử lại xem tn có gì em báo bác ạ
  8. 10/12/15 lúc 13:23
    tienphat830
    tienphat830
    tháo máy ra để con upp coi có lên không bác khả năng hở chân
  9. 10/12/15 lúc 13:31
    Tmobile_VFS
    Tmobile_VFS
    chạy FW cao nhất nếu còn backup đc thì save lại có khả năng cặp ra đi rồi
