Gsd Android Tool v1.0.1 - Tools By Pass Frp - Flash Firmware
Thảo luận trong 'CÁC DÒNG ANDROID KHÁC' bắt đầu bởi lyhaithanh, 11/5/18.
  1. 11/5/18 lúc 17:01
    lyhaithanh
    lyhaithanh
    Có thể anh em sẽ cần
    Quote:
    Gsd android tool is a tool for Android phone service
    The unique features of this tool will definitely attract your attention
    Impact Tools features
    Part of samsung > Unlock This option is called Samsung, but you can also use it for other Brand.
    Quote:
    1 - scan and full information In Selected Mode
    2 - Reset Frp Adb Mode
    3 - Reset Frp dial Mode
    4 - Bypass All Screen Lock In Frp = On Or of and Oem = on Or Of encrypted data partition and uncrypted Need Flash Eng-root
    5 - Bypass All Screen Lock In Adb Mode = need Root Access
    6 - Bypass All Screen Lock In Twrp Mode = No need Root and More ...
    7 - Bypass All Screen Lock In sideload Mode = Custom Recovery Data Modification Method
    8 - Bypass All Screen Lock In Sildeload Mode = Custom Recovery Need (encrypted data Partition)
    9 - Important Make RvSecuRity use Boot.img for Unlock = No need Root Or any Think Just Need Boot.img
    What is RvSecuRitY?
    We succeeded in 2014 by modifying the kernel, unlocking the Android device without clearing the data
    Then we began mass production of these kernels for each Android device We put the names of these kernels "RvSecuRitY" (Remove Security)
    We added the button for making these kernels to this software. you can drop boot.img to input section and get remove screen lock kernel very easy And write it by flasher(Odin , Spflashtool, and more ... ) on the device
    This tool unlock all encrypted data partition w/o data loss
    This method no need to twrp or root , you just need orginal boot.img (that you can extract from orginal firmware)
    samsung > Android Part You can use some of the options for this brand for other brands.
    Quote:
    1 - Read Full Information
    2 - exit Safe And Factory Mode = Need Root Access
    3 - Full Format Device = Need Root Access
    4 - enable Multi Language Samsung = Need Root access
    5 - ٍٍEnable Call recording (The main functionality hidden in Samsung.)= Need Root access
    6 - Enable Blacklist (The main functionality hidden in Samsung.) = need root Access
    7 - ٍEnable Hardware Version In About Phone(The main functionality hidden in Samsung.) = Need Root Access
    8 - disable update System Notification = Need Root access
    9 - disable Anti-Malware Application Samsung = need Root Access
    10 - Enable Camera Shutter (The main functionality hidden in Samsung.)
    11 - reboot Device In Normal , download , recovery , Bootloader Mode
    12 - Write File (flash) In sideload Mode
    13 - Important Read (backup) automatically boot , cache , efs , hidden , param , recovery , system partition = dd backup in Adb Mode Need Root Access
    14 - Important Restore (backup) automatically boot , cache , efs , hidden , param , recovery , system partition = dd backup restore in Adb Mode Need Root Access
    Other Brands > Main Menu
    Quote:
    1 - Read Full Information on Device = Adb Mode
    2 - Read Package Name System and Non=system Applocation = adb mode
    3 - Bypass all Screen Lock = Need Adb and Root Access
    4 - Full Format Device = adb Mode Need Root Access
    5 - Enable Multi Language Htc Devices = adb Mode Need Root Access
    6 - Important Get Length and Begin Address For Reset Frp Mediatek Devices (you can unlock Frp by using Length and Begin Address)
    7 - Backup Nvrm Mediatek Device = adb mode Need Root Access
    8 - write Nvrm Mediatek Backup = adb Mode Need Root Accesss
    9 - Important
    10 - adb Reboot Device To Edl mode , recovery , Fastboot , Normal Mode
    11 - Find Country Device Use imei Phone
    Other Brand > Fastboot Part
    Quote:
    1 - Read Full Information Device !
    2 - Read Full Information Hisilicon Devices Emmc
    3 - Frp Reset = Need Bootloader Unlocked
    4 - Full Format Device = Need Bootloader Unlock
    5 - Relock Bootloader Unlocked
    6 - Erase Partition Menu (Erase Boot , Recovery ,System , Data ,cache Partition)
    7 - unlock Bootloader menu (Unlock Bootloader Use Code Sony , Huawei and more ... and Unlock Bootloader Htc Device Use Unlock.bin)
    8 - reboot fastboot in edl mode , bootloader , RUU , Normal Mode
    9 - Flash Single File + Erase (Flash boot , recovery , system , splash , radio , data )
    10 - advanced Menu Flasher (Flash Multi file zip File , Boot , Recovery , Recovery2 , system , data , splash , radio , Modem , Cache , cust , Fastboot , Nvme files)
    11 - Nokia X , Xl , X+ Flasher Menu (system , boot , recovery , variant , data , cache , Preload)
    Important Developer Tools > System.img Tools
    Quote:
    1 - Read Full Information System.img File
    2 - Unpack any System.img 2.3 to 7.x
    3 - Repack System Folder 2.3 to 7.x
    4 - Convert Sparse Header System.img To 32
    5 - Make System.img Flashable In flashers On You Device (Need Root Access)
    Important Developer Tools > kernel Tools
    Quote:
    1 - Unpack Recovery , Boot.img
    2 - Repack Unpacked Kernel
    3 - Convert File_Contexts.bin To File_Contexts For Repack system Extracted Folder
    4 - Important Make RvSecurity Kernel For Bypass All Code = Need Boot.img
    5 - Make adb Enabler Kernel = need boot.img
    6 - Important make Pre-root Kernel (Chainfire Instructions) = need Boot.img
    7 - Make Dm-verity Error Fixer = need Boot.img
    End of capability definition [​IMG]
    To help you use this tool , We added a "Tooltip" for guidance , You can move your mouse over the button and see the functionality of the button.[​IMG]
    If I had an empty time. In the future, I will try to get the full tutorial on how to use this tool in the next section
    If you have any problems, please report this topic . This tool is portable Version No Need Install[​IMG]
    Tool Cần :
    NetFramework3.5
    LINK : Download
    Nguồn : Sưu Tầm
    Hoàng0387897888 thích bài này.
  2. 11/5/18 lúc 17:09
    nhokkhoa
    nhokkhoa
    Tks bác chờ kèo test :D Mà s dung lượng nhẹ quá ta
    lyhaithanh thích bài này.
  3. 11/5/18 lúc 17:21
    lyhaithanh
    lyhaithanh
    cái này đi sưu tầm về anh ơi
