Giúp, Lumia 1520 dính HS-USB LOADER 9008
Thảo luận trong 'WINDOWS PHONES' bắt đầu bởi goldenfish, 14/3/16.
  1. 14/3/16 lúc 13:36
    goldenfish
    goldenfish
    Khách bảo thằng con làm rớt, wifi ko nối dc, sáng nay mò qua kêu anh hỏi thằng cháu trong sg rồi, nó nói do máy bị treo á, reset lại là dc, thấy ko thơm rồi, đưa cho tự rết, bấm khỏi động lại cái là em nó đi luôn (trc đó vẫn lên ok), nghĩ lại mình may vãi, mém là ăn đạn.... >:)
    ATF flash done, log đẹp.
    nhưng vẫn dính 9008
    Windows Phone 8/8.1/10 Flashing Started
    Loading Flash Files Please Wait...
    [DEAD BOOT REPAIR via USB is SUPPORTED]
    Windows Phone 8/8.1/10 Lumia Flasher
    If the Phone is ALIVE
    1. Power On the Phone and Connect it to the USB Port
    If the Phone is DEAD
    1. Connect Phone to the USB Port
    2. Press and Hold the VOLUME DOWN and POWER Buttons
    3. Wait until the Phone Vibrates Shortly...
    4. Stop Pressing the Buttons...
    If the Phone is DEAD BOOT
    2. Install Correct Drivers:
    "Nokia Emergency Connectivity" Located at:
    C:\AdvanceBox Turbo Flasher\Driver\NOKIA_X2_USB_DRIVERS\
    Process Cancelled...
    Recovery Handle Found! - (Qualcomm)
    PBL Emergency Download Detected
    Start Sending Firehose Loader...
    Firehose Loader Sent!
    Executing Firehose Loader...
    Start Processing Firehose Payload...
    MSG_SIGNATURE Sent....
    Validation is enabled.
    MSG_HASHTABLE Sent....
    MSG_XML_CONFIGURE_\8974_edl_fh_image_config.xml Sent...
    MSG_XML_PROGRAM_SBL1 Sent...
    start 53248, num 635
    Finished sector address 53883
    MSG_XML_PROGRAM_RPM Sent...
    start 65536, num 382
    Finished sector address 65918
    MSG_XML_PROGRAM_TZ Sent...
    start 69632, num 569
    Finished sector address 70201
    MSG_XML_PROGRAM_UEFI Sent...
    start 61440, num 2229
    Finished sector address 63669
    MSG_XML_PROGRAM_WINSECAPP Sent...
    start 73728, num 538
    Finished sector address 74266
    MSG_XML_PROGRAM_TZAPPS Sent...
    start 77824, num 1037
    Finished sector address 78861
    MSG_XML_PROGRAM_DBI Sent...
    start 57344, num 36
    Finished sector address 57380
    MSG_XML_ERASE_DDR Sent...
    start 36864, num 32
    Finished address 36896
    MSG_XML_ERASE_PLAT Sent...
    start 167936, num 16384
    Finished address 184320
    MSG_XML_ERASE_EFIESP Sent...
    start 184320, num 65536
    Finished address 249856
    MSG_XML_PROGRAM_8974_gpt_v1_0.bin Sent...
    start 0, num 34
    Finished sector address 34
    MSG_XML_POWER Sent...
    Firehose Payload All Sent!
    Waiting for USB Cycle...
    USB Cycle OK!
    Rebooting Phone...
    Nokia Phone Info Mode Initiated...
    Please wait upto 15 Seconds for SW Reset
    1. Press and Hold the VOLUME DOWN and POWER
    2. Wait until the Phone Reboots...
    3. Wait until you see BIG "NOKIA" Logo
    Version: 2.5.2.:
    Product Code: 059V317
    Module Code: 0205754
    Basic Tranceiver Code: 059T1J9
    Continuing Previous Boot...
    Please wait upto 30 Seconds for Boot Re-entry
    Boot Flash Mode Successful...
    Buffers Flushed OK...
    Phone Info Query Start...
    Blocks Returned: 0x09 Blocks
    Block ID 0x01 : 00241000
    Block ID 0x1F : 00
    Block ID 0x02 : 00240000
    Block ID 0x03 : 03A3E000
    Block ID 0x05 : Nokia.MSM8974.P6081.2.2
    Block ID 0x0D : 0001
    Block ID 0x0F : 0301010100000101FF
    Block ID 0x10 : 01001F0000
    Block ID 0x20 : 010000000100000004
    Checking SD Card Size...
    Card Size: 0x00000000
    Checking Platform Security Status...
    Platform Secure Boot Status: Active
    Secure FFU EFUSE Status: Active
    Debug Status: Active
    RDC Status: Not Active
    Authentication Status: Not Active
    UEFI Secure Boot Status: Active
    Checking Secure FFU Mode...
    Secure FFU Mode :
    Query Flash App Information...
    Flash App Information: 02021D023400
    UEFI App: FLASH APP
    Flash App Protocol Version: 2.29
    Flash App Implementation Version: 2.52
    Query ROOT KEY HASH...
    ROOT_KEY_HASH: 3774964A7E6AC7EF7D428DDC0C0EAD71640B0D8DD3BFC3829110AF2D8ED68D7C
    Query PUBLIC ID...
    PUBLIC_ID: 039082F9E37ADD9567875AB6FDF90EF471F5942B
    Query eMMC Info...
    EMMC Manufacture ID: TOSHIBA
    EMMC Product SN : 5D17744B
    EMMC_SIZE: 32 Gigabytes
    Query Battery Charge Status...
    BATTERY CHARGE_STATUS: 59%
    Sending Image Signatures...
    Image Signatures Accepted!
    Erasing Data Partition...
    Data Partition Erased Successfully
    Fixing Partitions...
    Preparing Buffers for DATA LOOP...
    Allocating System RAM OK!
    Start Sending DATA BLOCKS...
    Finished Sending all DATA BLOCKS!
    Exiting FLASH Mode via REBOOT...
    Exit FLASH Mode Successful!
    Flashing Done!
    Total Flashing Time : 00:04:13
    anh em ai gặp qua phán dùm bệnh em nó với, có phải đã bốc kít ko :eek:
