Giúp e con masstel X6
Thảo luận trong 'SỬA CHỮA PHẦN MỀM.' bắt đầu bởi HoàngSơn Mobile, 2/2/19.
  1. 2/2/19 lúc 09:04
    HoàngSơn Mobile
    HoàngSơn Mobile
    FD19CBC0-784F-4305-A658-F0768C82F68C. e nhận con masstel X6 mà kg biết nó reset thế nào mà cũng không biết có rom không các bác trên đây ai biết giúp đỡ e với ạ
    793C7E52-2238-45A8-96BA-9EAB4DA280CB.
  2. 22/2/19 lúc 16:05
    anhtanha
    anhtanha
  3. 22/2/19 lúc 16:06
    anhtanha
    anhtanha
    Wait for phone...
    Phone found! [ 4 ]
    Sync...
    Inital Boot Ok!
    BB_CPU_PID : 6580
    BB_CPU_NME : [MediaTek] MT6580_S00
    BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000
    Processing BROM stage
    Settings for BROM configured!
    SecCfgVal : 0x00000000
    BromVer : 0x00FF
    BLVersion : 0x0001
    PreLoader : Active [ Boot with PL ]
    BootLdrSS : NORMAL with PRELOADER
    Processing DA stage
    DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07
    Sending and initialize DA ...
    Running DA ver.4.2 on BBID : 0x94
    NAND Flash : NOT INSTALLED
    eMMC Flash : 8801034D384231364728A98159227537
    Initialize Memory ...
    DRAM already initialized by Preloader
    DAgent sent , init HW now
    eMMC FlashIC initialized
    [eMMC] : FLASH_VEN : 0x88 , OEM : 0103
    [eMMC] : FLASH_INF : [FORESEE] , G61B8
    [eMMC] : FLASH_CID : 8801034D384231364728A98159227537
    [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000
    [eMMC] : FLASH_LEN : 0x000000039D000000
    [eMMC] : FLASH_UCP : 14800 MiB [eMMC 16 GiB]
    DEV RID : 0xCCF520C9D290A843B6BA0ABCC3DE280F
    INT RAM : 0x00020000
    EXT RAM : 0x40000000 [1 GiB]
    BOOT TYPE : EMMC_FLASH_BOOT
    SOC VERIFY : C1
    Boot Ok!
    Clear FRP ( Google Reset Protection )
    Clear Ok!
    Clear DIN
    Clear Ok!
    Clear USERDATA
    Clear Ok!
    Clear CACHE
    Clear Ok!
    Done!
    Elapsed: 00:01:21
    Reconnect Power/Cable!
