flash vsmart JOY 3 V430A done By Z3X Emmc Manager
Thảo luận trong 'VSMART ANDROID' bắt đầu bởi Đỗ Đức Vũ ™, 25/9/20.
  1. 25/9/20 lúc 11:10
    Đỗ Đức Vũ ™
    Đỗ Đức Vũ ™
    Mã:
    Source: Qualcomm 9008 EMMC/UFS/Manual
    Generation: GPT [QC/SAMS/BCM/INTEL/MTK]
    Box Voltage set to: 2800 mV
    Scanner Thread Created..
    Config: 1011111111101111
    Setup HiPower CLK: OFF
    Connecting To EasyJtag Plus Box: 2800mV/42MHz/8BIT
    EasyJtag Plus Box Found! Result: 0/OK
    EasyJtag Plus S/N: B62B29AB74700895
    EasyJtag Plus Box FirmWare: 2.53
    Box Bus Width = 8 BIT
    Box Hardware  = EasyJtag 2nd Generation
    Use Qlm 9008 (EDL) Mode..
    Please Connect Qlm Device in 9008 (EDL) Mode..
     Selected Primary Memory Type: AUTO
    Waiting For Device..
    Found Device:
     Path: \\?\usb#vid_05c6&pid_9008#5&18f65433&0&12#{86e0d1e0-8089-11d0-9ce4-08003e301f73}
     Desc: Qualcomm HS-USB QDLoader 9008
     HWID: USB\VID_05C6&PID_9008&REV_0000
     Name: Qualcomm HS-USB QDLoader 9008 (COM6)
     Vendor: Qualcomm Incorporated
    Trying Connect to Device..
    Open Port OK
    Sahara OK, Get Data..
    Read Qualcomm CPU Info OK
     S/N: 0x5964EE59
     HW ID: 0x000BA0E1016E0000
     HASH: 0x7F24DE1F375E9FF058492FB27F422566B6E96D33C7422F663089D12D46EB55FA
     SBL : 0x00000000
     DEV HASH: 0x00000182FABB
     CPU : SnapDragon 632 [SDM632]
    Using Qlm Loader: prog_emmc_firehose_8953_ddr (3).mbn
    Sending Loader..
    Loader Size: 442552 bytes
    Loader CheckSum: 0x33164CE2
    Loader Info:
     HWID: 0x000BA0E1016E0000
     SWID: 0x0000000000000003
     CPU:  MSM8953
     CERT Cnt: 3
    Wait..
    Loader Sent, Run FireHose..
    Get Memory Type.. [AUTO]
    Detected Memory: EMMC
    FireHose Config Info: MSM8953, Memory: eMMC, Ver: 1
    Ext Info: 0x00002000/0x00100000/0x00001000/0x00001000
    FireHose Configure OK
    Get Protocol Type..
    Detected Generic FireHose Type..
    Reading EMMC ROM's Info..
     EMMC ROM #1 -> 61071360 / 29.12 GB
     EMMC ROM #2 -> 8192 / 4.00 MB
     EMMC ROM #3 -> 8192 / 4.00 MB
    Memory Type: EMMC
    Physical Partitions: 3
    Packet Size: 16384
    Sector Size: 512
    EMMC Vendor: 0x15 -> SAMSUNG
    EMMC NAME: QD63MB
    BOOT OK, FireHose Ready..
     Selected Primary Memory Type: EMMC
    Run Main Engine..
    Scanning GUID Partition Table from ROM1
    GUID Partition Table is Found. Max Parts: 56
    GPT: GPT   [000000000000 - 000000004400] Size: 17.00 KB
    GPT: MODEM   [000004000000 - 000005800000] Size: 88.00 MB
    GPT: FSC   [00000C000000 - 000000000400] Size: 1.00 KB
    GPT: SSD   [00000C001000 - 000000002000] Size: 8.00 KB
    GPT: SBL1   [00000C003000 - 000000080000] Size: 512.00 KB
    GPT: SBL1BAK   [00000C083000 - 000000080000] Size: 512.00 KB
    GPT: RPM   [00000C103000 - 000000080000] Size: 512.00 KB
    GPT: RPMBAK   [00000C183000 - 000000080000] Size: 512.00 KB
    GPT: TZ   [00000C203000 - 000000200000] Size: 2.00 MB
    GPT: TZBAK   [00000C403000 - 000000200000] Size: 2.00 MB
    GPT: DEVCFG   [00000C603000 - 000000040000] Size: 256.00 KB
    GPT: DEVCFGBAK   [00000C643000 - 000000040000] Size: 256.00 KB
    GPT: DSP   [00000C683000 - 000001000000] Size: 16.00 MB
    GPT: MODEMST1   [00000D683000 - 000000180000] Size: 1.50 MB
    GPT: MODEMST2   [00000D803000 - 000000180000] Size: 1.50 MB
    GPT: DDR   [000010000000 - 000000008000] Size: 32.00 KB
    GPT: FSG   [000010008000 - 000000180000] Size: 1.50 MB
    GPT: SEC   [000010188000 - 000000004000] Size: 16.00 KB
    GPT: SPLASH   [000014000000 - 000000B00000] Size: 11.00 MB
    GPT: ABOOT   [000018000000 - 000000100000] Size: 1.00 MB
    GPT: ABOOTBAK   [000018100000 - 000000100000] Size: 1.00 MB
    GPT: DTBO   [000018200000 - 000000800000] Size: 8.00 MB
    GPT: DTBOBAK   [000018A00000 - 000000800000] Size: 8.00 MB
    GPT: VBMETA   [000019200000 - 000000010000] Size: 64.00 KB
    GPT: VBMETABAK   [000019210000 - 000000010000] Size: 64.00 KB
    GPT: BOOT   [000019220000 - 000004000000] Size: 64.00 MB
    GPT: RECOVERY   [00001D220000 - 000004000000] Size: 64.00 MB
    GPT: DEVINFO   [000021220000 - 000000100000] Size: 1.00 MB
    GPT: SYSTEM   [000021320000 - 0000C0000000] Size: 3.00 GB
    GPT: VENDOR   [0000E1320000 - 000030600000] Size: 774.00 MB
    GPT: CACHE   [000114000000 - 000010000000] Size: 256.00 MB
    GPT: PERSIST   [000124000000 - 000002000000] Size: 32.00 MB
    GPT: MISC   [000126000000 - 000000100000] Size: 1.00 MB
    GPT: KEYSTORE   [000126100000 - 000000080000] Size: 512.00 KB
    GPT: CONFIG   [000126180000 - 000000008000] Size: 32.00 KB
    GPT: OEM   [000126188000 - 000010000000] Size: 256.00 MB
    GPT: LIMITS   [000138000000 - 000000008000] Size: 32.00 KB
    GPT: MOTA   [00013C000000 - 000000080000] Size: 512.00 KB
    GPT: DIP   [00013C080000 - 000000100000] Size: 1.00 MB
    GPT: MDTP   [00013C180000 - 000002000000] Size: 32.00 MB
    GPT: SYSCFG   [00013E180000 - 000000080000] Size: 512.00 KB
    GPT: MCFG   [00013E200000 - 000000400000] Size: 4.00 MB
    GPT: LKSECAPP   [000140000000 - 000000020000] Size: 128.00 KB
    GPT: LKSECAPPBAK   [000140020000 - 000000020000] Size: 128.00 KB
    GPT: CMNLIB   [000140040000 - 000000100000] Size: 1.00 MB
    GPT: CMNLIBBAK   [000140140000 - 000000100000] Size: 1.00 MB
    GPT: CMNLIB64   [000140240000 - 000000100000] Size: 1.00 MB
    GPT: CMNLIB64BAK   [000140340000 - 000000100000] Size: 1.00 MB
    GPT: KEYMASTER   [000140440000 - 000000100000] Size: 1.00 MB
    GPT: KEYMASTERBAK   [000140540000 - 000000100000] Size: 1.00 MB
    GPT: APDP   [000144000000 - 000000040000] Size: 256.00 KB
    GPT: MSADP   [000144040000 - 000000040000] Size: 256.00 KB
    GPT: DPO   [000144080000 - 000000002000] Size: 8.00 KB
    GPT: LOGDUMP   [000144082000 - 000004000000] Size: 64.00 MB
    GPT: USERDATA   [000148082000 - 0005FFB79E00] Size: 24.00 GB
    GPT: BACKUP_GPT   [000747BFBE00 - 000000004200] Size: 16.50 KB
    Reading Table Completed
    Scanning GUID Partition Table from ROM2
    GPT Signature Not Found. Break..
    Scanning GUID Partition Table from ROM3
    Partition #5   mount as [/MODEM] -> 88.00 MB
    Partition #16   mount as [/dev_16] -> 16.00 MB
    Partition #32   mount as [/dev_32] -> 3.00 GB
    Partition #33   mount as [/dev_33] -> 774.00 MB
    Partition #34   mount as [/cache] -> 256.00 MB
    Partition #35   mount as [/mnt/vendor/persist] -> 32.00 MB
    Partition #58   mount as [/data] -> 24.00 GB
    EmptyCheck:
     EMPTY -> #5 - [FSC]
     EMPTY -> #6 - [SSD]
     EMPTY -> #30 - [DEVINFO]
     EMPTY -> #35 - [MISC]
     EMPTY -> #36 - [KEYSTORE]
     EMPTY -> #38 - [OEM]
     EMPTY -> #39 - [LIMITS]
     EMPTY -> #40 - [MOTA]
     EMPTY -> #41 - [DIP]
     EMPTY -> #43 - [SYSCFG]
     EMPTY -> #44 - [MCFG]
     EMPTY -> #53 - [APDP]
     EMPTY -> #54 - [MSADP]
     EMPTY -> #55 - [DPO]
     EMPTY -> #56 - [LOGDUMP]
    EmptyCheck: Done
    Warning! Device Blocked by FRP
    For Reset FRP Try to Tools Tab
    Press Reset FRP Button
    Partition #38 -> CONFIG
    Android Info:
    Brand		   = vsmart
    Vendor		  = vsmart
    Device		  = casuarina
    Model		   = Joy 3
    Product		 = casuarina
    CPU ABI		 = arm64-v8a
    Android Version = 9
    Firm Version	= PKQ1.190601.001.V430A_OPEN_U_M6_20200516
    Inc. Version	= V430A_OPEN_U_M6_20200516
    Firm Date	   = Sat May 16 01:39:00 +07 2020
    Security Patch  = 2020-05-01
    Android Info:
    Platform		= msm8953
    Scanner Thread Terminated
    Elapsed: 00:00:12:566
    Found 59 Partition(s)..
    Scan Done. Init Main Engine...
    Use Qlm EMMC Device: Qualcomm HS-USB QDLoader 9008 (COM6)
    Reader Engine Initialized.. 0/OK
    Operation Done: [Init Engine], Elapsed: 00:00:00:037
    DucAnhTk, thanhco, viettinh2 thành viên khác thích điều này.
  2. 25/9/20 lúc 13:48
    thanhco
    thanhco
    hảng này mới ra mà lổi sw nhiều ghê chắc khách họ củng bỏ thôi , chạy xong rồi chắc nó sẻ bị lại . làm thợ thì nhờ máy lổi nhưng rom nó khó kiếm nên củng bỏ mấy bận rồi
  3. 25/9/20 lúc 14:12
    congdongnet
    congdongnet
    Mua hàng Vmart là sai lầm. Quá nhiều lỗi
  4. 25/9/20 lúc 15:31
    use-free
    use-free
    hỏi ngu ae phát là rom vsmart là do anh em làm hay từ vsmart ạ.:D
  5. 25/9/20 lúc 16:24
    Đỗ Đức Vũ ™
    Đỗ Đức Vũ ™
    rom read từ máy sống nhé bác =)))
    thanhco thích bài này.
  6. 25/9/20 lúc 16:31
    Đỗ Đức Vũ ™
    Đỗ Đức Vũ ™
    thế mà lại nhiều người dùng mới tài kakaka đồng tiền đi liền với chất lượng thôi bác =))))
  7. 25/9/20 lúc 16:45
    Rượu&Tình
    Rượu&Tình
    con này khóa boot bung gì đâu mà sao phải khổ nhục thế kia
  8. 25/9/20 lúc 16:53
    Đỗ Đức Vũ ™
    Đỗ Đức Vũ ™
    làm gì khổ bác =)))) flash 9008 thôi mà
  9. 25/9/20 lúc 17:15
    thanhco
    thanhco
    làm dv online mấy vụ pass màn hình với FRP còn tin tưởng . chứ mấy cái vụ chạy online dòng này củng sợ như dòng oppo r831k chạy xong máy lổi khách quay lại khi đó khó ăn khó nói bên dv chắc sẻ nói ko phải máy đó . file thì họ ko bán ( họ nói ko biết chạy ,chạy ko lên lại đổ lổi do file nện họ ôm file ) kkkk
  10. 25/9/20 lúc 17:20
    thanhco
    thanhco
    hôm trước bài bên kia có anh chạy con OPPO a3s củng như vậy hay sao á , hihihi
    p/s cái vấn đề nan giải dòng này vẩn là rom ở đâu ?????
  11. 25/9/20 lúc 17:25
    Rượu&Tình
    Rượu&Tình
    vag chưa xem video em lại tưởng câu dây với đục ổ hiih
    GSM Team NgheAn thích bài này.
  12. 25/9/20 lúc 21:20
    epkinhgiare2019
    epkinhgiare2019
    mai chạy e con nhé active v1
    TrongNguyen132 thích bài này.
  13. 25/9/20 lúc 21:22
    QuangSangGSM
    QuangSangGSM
    UMT hoặc mi flash flash ok cần gì rườm rà.anh em cần rom flash liên hệ zalo em.
    quimobile2NhậtAn Mobile thích điều này.
  14. 25/9/20 lúc 21:28
    epkinhgiare2019
    epkinhgiare2019
    a e tiện cho mình hỏi camera máy androids bị bụi bẩn mua nước rửa camera của iphone rửa có sạch được k mọi người
  15. 25/9/20 lúc 23:43
    Đỗ Đức Vũ ™
    Đỗ Đức Vũ ™
    Ê tôi có nói phải bắt buộc dùng Z3X Emmc Manager à ???
    ngứa răng ngứa lợi thì đi chỗ khác nhé ! ăn nói cho chuẩn và toppic tôi tạo ra k phải chỗ ông vào ăn nói vớ vẩn =)))))
    Crack, thanhcoepkinhgiare2019 thích điều này.
  16. 26/9/20 lúc 06:16
    GSM Team NgheAn
    GSM Team NgheAn
    Xin file với ạ ! Thanks bro
  17. 26/9/20 lúc 09:33
    No-iMEi
    No-iMEi
    Cái web này hết thời rồi, giờ chỉ còn lại số ít nick vàng thôi, đa số là dịch vụ nên không thu hút được người tham gia
    Đỗ Đức Vũ ™, MinhThiện*thanhco thích điều này.
  18. 24/11/20 lúc 07:47
    thanhco
    thanhco
    bác nào có rom con này up cho em xin vs .thanks
  19. 24/11/20 lúc 09:42
    thuanrau
    thuanrau
    cho xin 250k á!
    thanhcoTrongNguyen132 thích điều này.
  20. 24/11/20 lúc 13:00
    DucAnhTk
    DucAnhTk
    Flash rom read mất imei ko bác
