Fix iTunes Error 1015
Thảo luận trong 'SỮA CHỮA PHẦN MỀM, FIRMWARE.' bắt đầu bởi Nguyên-NEEDCHANGE, 28/5/12.
  1. 28/5/12 lúc 00:54
    Nguyên-NEEDCHANGE
    Nguyên-NEEDCHANGE
    Lang thang lượm lặt được cái này, đem về chia sẻ Anh Em nhà mình ... :D
    How to Fix iTunes Error 1015 ? error 1015 occurred with users who are trying to downgrade, upgrade or restore, their firmware on their iPhone 4S, 4, 3gs – iPod Touch 3G, 4G – iPad 3, 2, 1 onany iOS 4.x or iOS 5.x.
    Absinthejailbreak Team will show an easy way to fix 1015 error by using two ways First way by using “RecBoot”, Second way by using “LibUSB”
    First Way: How to fix iTunes error 1015 (RecBoot):
    Step 1: Download and Install RecBoot on your computer.
    * Download RecBoot for Mac
    * Download RecBoot for Windows
    * Download RecBoot for Linux
    Step 2: Shut down iTunes if it is opened.
    Step 3: Put your i-device into DFU mode (if you don’t know follow the steps below)
    * Connect your iPhone with your PC then open iTunes
    * Hold down power button and home button both at the same time for 10 seconds
    * After the 10 seconds release the power button and still pressing on the home button for another 10 seconds
    Step 4: Now iTunes will inform you by the message below. Recovery Mode message
    Step 5: Open RecBoot and click on Exit Recovery mode.
    Now you can restore custom IPSW file or downgrade the firmware without iTunes Error 1015.
    Second Way: How to fix iTunes error 1015 using (LibUSB):
    Step 1: Download and Install correct version (32 bit / 64 bit) of LibUSB here.
    Step 2: Download and Run Error 1015 Fixer Tool .
    Step 3: Run iTunes and when you get the error, click the button on the Error 1015 Fixer Tool which says “Fix My Error”
    That’s it.
  2. 28/5/12 lúc 01:09
    Van-Anh
    Van-Anh
    a dịch ra TV cho ae dễ hiểu luôn đi :D
  3. 28/5/12 lúc 10:05
    satthudt
    satthudt
    1015 mình đá ra nhanh hơn không sao lại làm gì vậy cho phức tạp huynh
  4. 28/5/12 lúc 11:14
    967_unlock
    967_unlock
    ow để sửa chữa iTunes Lỗi 1015? lỗi 1015 đã xảy ra với những người dùng đang cố gắng để hạ cấp, nâng cấp hoặc khôi phục lại, firmware của họ trên iPhone 4S, 4, 3gs - iPod Touch 3G, 4G - iPad 3, 2, 1 onany iOS 4.x hoặc 5.x. iOS
    Absinthejailbreak Nhóm sẽ hiển thị một cách dễ dàng để sửa chữa 1.015 lỗi bằng cách sử dụng hai cách cách đầu tiên bằng cách sử dụng "RecBoot", cách thứ hai bằng cách sử dụng "LibUSB"
  5. 28/5/12 lúc 11:28
    Nguyên-NEEDCHANGE
    Nguyên-NEEDCHANGE
    4 với 4S dính 1015 khó đá lắm ... Bài viết chỉ mang tính chất sưu tầm lượm lặt, sẽ có lúc hữu dụng ... :-*
