eMMC Oppo r827 nhờ mọi người giúp đỡ
Thảo luận trong 'OPPO, VIVO, REALME ANDROID' bắt đầu bởi thangmobile89, 6/11/17.
  1. 6/11/17 lúc 17:41
    thangmobile89
    thangmobile89
    Em nhận thay emmc cho r827
    Em thay emmc KMK7X000VM-B314
    Thay và chage cid ok
    Flash ok nhưng lên treo logo đứng im
    Log em nó đây ạ
    Có gì sai sót nhờ mọi người chỉ giúp em ạ
    Em cảm ơn
    111/6/2017 3:04:16 PM> Success! Now Reconnect all eMMC Lines [POWER, CMD, CLK, DAT0] to finalize CID Patch !
    11/6/2017 3:04:18 PM> Looking for EasyJTAG box...
    11/6/2017 3:04:18 PM> EasyJTAG API ver. 2008
    11/6/2017 3:04:18 PM> Setting IO Levels to 3.3V
    11/6/2017 3:04:18 PM> Setting frequence to 21 Mhz
    11/6/2017 3:04:18 PM> HiPower mode is OFF
    11/6/2017 3:04:19 PM> OpenUSB returned = 0
    11/6/2017 3:04:19 PM> Power Controller returned = 0
    11/6/2017 3:04:20 PM> EasyJTAG Box Serial = 1800601B80202E89
    11/6/2017 3:04:20 PM> EasyJTAG Box Firmware = 01.60
    11/6/2017 3:04:20 PM> HiPower mode is OFF
    11/6/2017 3:04:20 PM> Frequence: 21 Mhz
    11/6/2017 3:04:20 PM> CMD Pullup Level: 2041 mV
    11/6/2017 3:04:20 PM> CMD Active Level: 2413 mV
    11/6/2017 3:04:20 PM> eMMC Init returned = 0
    11/6/2017 3:04:20 PM> EMMC Device Information :
    11/6/2017 3:04:20 PM> EMMC CID: 1501004B4A533030420357C0D82971FC
    11/6/2017 3:04:20 PM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C
    11/6/2017 3:04:20 PM> EMMC Manufacture Name: SAMSUNG
    11/6/2017 3:04:20 PM> EMMC Manufacture ID: 0x15 , OEM ID: 0100
    11/6/2017 3:04:20 PM> EMMC Manufacture Date: 7/2014 , Rev: 03
    11/6/2017 3:04:20 PM> EMMC NAME: KJS00M , S/N: 57C0D829 , rev. 03
    11/6/2017 3:04:20 PM> EMMC NAME (HEX): 4B4A53303042
    11/6/2017 3:04:20 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
    11/6/2017 3:04:20 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
    11/6/2017 3:04:20 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 2048 KB (000000200000)
    11/6/2017 3:04:20 PM> EMMC Permanent Write Protection: No
    11/6/2017 3:04:20 PM> EMMC Temporary Write Protection: No
    11/6/2017 3:04:20 PM> Extended CSD Information :
    11/6/2017 3:04:20 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
    11/6/2017 3:04:20 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
    11/6/2017 3:04:20 PM> Boot Bus Config: 0x00 , width 1bit
    11/6/2017 3:04:20 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
    11/6/2017 3:04:20 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07
    11/6/2017 3:04:20 PM> Device supports partitioning features
    11/6/2017 3:04:20 PM> Device can have enhanced technological features in partitions and user data area
    11/6/2017 3:04:20 PM> Device can have extended partitions attribute
    11/6/2017 3:04:20 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
    11/6/2017 3:04:20 PM> Backup saved: KJS00M_57C0D829_20171106_150420.extcsd
    11/6/2017 3:04:20 PM> EMMC Init completed.
  2. 6/11/17 lúc 17:45
    congvumobile
    congvumobile
    KMK7U000VM-B309 . dùng mã này ok nhe a. đừng dùng b314.
    thangmobile89 thích bài này.
  3. 6/11/17 lúc 17:49
    nguyenthinhmobi
    nguyenthinhmobi
    thư chia boot rpmp xung 2:2:1 xem sao bạn
  4. 6/11/17 lúc 18:06
    thangmobile89
    thangmobile89
    Không có emmc này mới chết anh àh
    Giờ chỉ còn b314
  5. 6/11/17 lúc 18:07
    thangmobile89
    thangmobile89
    Em thử rồi, vẫn vậy anh
    Cho xuống 1mb và 128k cũng thế luôn ạ
    congvumobile thích bài này.
  6. 6/11/17 lúc 18:11
    congvumobile
    congvumobile
    làm cở nào cũng vậy. set boot thế nào cũng vậy. đã làm qua rồi. b309 lên ok. b314 có em lên em không lên. chỉ treo logo thôi.
  7. 6/11/17 lúc 18:14
    thangmobile89
    thangmobile89
    Dạ cảm ơn anh
    Nhờ anh em emmc mã này được không ạ kmk5u000vm-b309
  8. 6/11/17 lúc 18:18
    Quoc_TraVinh
    Quoc_TraVinh
    con này change CID về Skhynix boot 4mb ok
    kh_mobile thích bài này.
  9. 6/11/17 lúc 18:19
    congvumobile
    congvumobile
    ok. 4gb
  10. 6/11/17 lúc 18:31
    thangmobile89
    thangmobile89
    Anh cho em hỏi là 4-4 hay sao ạ
    Em set 4-2 thì ok
    Nhưng 4-4 không set được anh
  11. 6/11/17 lúc 19:11
    Bảo@Minh
    Bảo@Minh
    dòng này set thành 4m đi log ok là 4m nhá.hay sửa theo log này là ok
    EMMC CID : 90014A4838473264040503A2462BC1DC
    EMMC CSD : D02701320F5903FFFFFFFFEF8A4040D2
    EMMC Manufacturer ID: 0090 , OEM ID: 014A
    EMMC Date: 12/2014 Rev.0x5
    EMMC NAME: H8G2d , S/N: 60966443
    EMMC NAME (HEX): 48384732642000
    EMMC ROM1 (Main User Data) C
    \pacity: 7456 MB
    EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
    EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
    EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
    EMMC Password Locked: No
    Extended CSD rev 1.6 (MMC 4.5)
    Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1)
    Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x48.
    H/W reset function [RST_N_FUNCTION]: 0x01
    High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00004000]
    Partitioning Support [PARTITIONING_SUPPORT]: 0x07
    Device support partitioning feature
    Device can have enhanced tech.
    Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x01
  12. 6/11/17 lúc 21:36
    thangmobile89
    thangmobile89
    Em cảm ơn anh
    nhưng EMMC RPMB (Replay Protected Memory Block) Capacity: 2048 KB (000000200000)
    Không set được 4mb anh ơi
    Set báo lỗi, không được, chỉ set được 2mb trở xuống thôi anh
  13. 7/11/17 lúc 08:42
    Bảo@Minh
    Bảo@Minh
    con này đổi bình thường chắc chọn nhầm
  14. 7/11/17 lúc 09:02
    Heisenberg
    Heisenberg
    dễ nhưng không dễ mà khó cũng chẳng khó !:3
  15. 7/11/17 lúc 09:06
    thangmobile89
    thangmobile89
    NHờ anh chỉ dẫn giúp thằng em với ạ
    Em cảm ơn
    Em change báo lỗi thế này anh
    Operation: Changing BOOT and RPMB sizes ...
    New BOOT size: 4096 Kb
    New RPMB size: 4096 Kb
    Error: CMD CRC Error
  16. 7/11/17 lúc 10:26
    Phanlinh_mobile
    Phanlinh_mobile
    KMK7X000VM-B314 mã này thay ok, ko cần KMK7U000VM-B309 .mình đã thay rất nhiều con r827 với mã này, up lên treo là do rom bạn tải file này R827EX_11_A.07_160505 up lên bảo đảm ok nó dung chung cho bản 4g và 8g
  17. 7/11/17 lúc 11:19
    thangmobile89
    thangmobile89
    Em cũng thử rồi anh
    Lên treo logo rồi tắt anh àh
    Mọi người cho em hỏi Em change cid qua H4G1d rồi
    Giờ em muốn về lại Cid samsung được không ạ
    Em giờ úp lại fw cứ báo lỗi This eMMC is not Samsung
  18. 7/11/17 lúc 11:26
    quangtrongmobi
    quangtrongmobi
    câu điểm tp ra mass rồi up lại fimware
  19. 7/11/17 lúc 11:39
    thangmobile89
    thangmobile89
    Em cảm ơn
  20. 7/11/17 lúc 11:58
    Phanlinh_mobile
    Phanlinh_mobile
    dùng easyjtag plus đổi cid qua samsung rồi update file ware emmc ko cần câu tp. còn phần kia thì set boot rom 2,3 =4m rpmb=4m nhé.easyjtag plus set meditek partiton config ko cần repair extcsd
  21. 7/11/17 lúc 13:52
    thangmobile89
    thangmobile89
    Em làm như anh chỉ dẫn nhưng vẫn lên treo logo anh ạ
    Nhờ mọi người chỉ dẫn tiếp ạ
    Log mới đây ạ
    HiPower mode is OFF
    Frequence: 21 Mhz
    CMD Pullup Level: 2052 mV
    CMD Active Level: 3145 mV
    EMMC CID: 90014A483847326404012400D8297172
    EMMC Manufacture Name: SKHYNIX
    EMMC Manufacture ID: 0x90 , OEM ID: 014A
    EMMC Manufacture Date: 7/2014 , Rev: 01
    EMMC NAME: H8G2d , S/N: 2400D829 , rev. 01
    EMMC NAME (HEX): 483847326404
    EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
    Backup saved: H8G2d_2400D829_20171107_134511.extcsd
  22. 7/11/17 lúc 14:07
    an_gau
    an_gau
    Treo logo vậy là được rồi. Chú ý dòng này :
    * Giờ chọn mục CONFIRM: tích vô là ok. Sau đó nạp rom lại.
  23. 7/11/17 lúc 14:11
    Đình_Nghệ An
    Đình_Nghệ An
    kmk7x là 8g nếu có room bin 8g hoặc file flashtool 8G nạp là ok
  24. 7/11/17 lúc 14:17
    Đình_Nghệ An
    Đình_Nghệ An
    k biết có phải chủ thớt ib bên zalo hôm qua không ... nhưng nói thiệt e nghỉ làm emmc lâu rồi ... treo logo là ok rồi đó ...quan trọng là room thui ... sợ nó lên xanh màn kìa ... gửi thớt cái link tét ok trên cả bản 4G và 8G luôn
    làm emmc quan trọng là cái log ok ... làm ok máy nào ,save log lại sau này nhìn đó mà changer cho đúng... k có thì lên google tìm log rồi nhìn vây mà làm thui
    https://drive.google.com/file/d/0BzqjCrCp3gU2cDZJQkpPV05EZkE/view
  25. 7/11/17 lúc 15:03
    thangmobile89
    thangmobile89
    Em cảm ơn các anh đã giúp đỡ
    Nhưng em chạy file bin và file flashtool cũng lên trep oppo ạ
    Quần từ hôm qua đến giờ vẫn chưa được
    No hành em quá
  26. 7/11/17 lúc 16:03
    Lê Anh VF
    Lê Anh VF
    a đã thay con khác chưa? mmc nó đâu co bất tử đâu a,ram ngáp ngáp cũng ko lên nổi đâu
  27. 7/11/17 lúc 18:31
    thangmobile89
    thangmobile89
    Em còn 1 con đó anh ah
    Chắc là do emmc
    Em đóng qua main khác cũng như vậy luôn ạ
  28. 7/11/17 lúc 18:35
    quankom
    quankom
    kmk7x thay ok.lên logo sập thì tải file này về flash là lên R827EX_11_A.07_160505
  29. 7/11/17 lúc 19:37
    thangmobile89
    thangmobile89
    Em chân thành cảm ơn các anh đã giúp đỡ em
    máy đã ok rồi ạ
  30. 7/11/17 lúc 23:19
    Minh Duy Gsm
    Minh Duy Gsm
    Cho xin giải pháp luôn anh. Thanks
  31. 8/11/17 lúc 06:58
    senanh
    senanh
    Không biết box nào làm đc như thớt nói vậy đổi cid vẩn updete emmc đc hả em chưa gặp qua của em là ufi sau khi đổ cid thì lệnh updete emmc nó bị ẩn đi phải restore cid lại thì nó mới hiện mong cao thủ nào đi qua cho xin chút kinh ngiệm
  32. 8/11/17 lúc 09:03
    thangmobile89
    thangmobile89
    Đổi cid SK hynix không update đươc fw bác ơi, chắc bác hiểu nhầm rồi
    Ở đây là emmc samsung sau khi đổi cid sang SK hynix thì không thể update fw emmc đươc
    Muốn up lại fw cho emmc thì dùng easy jtag plus change cid về samsung
    Change cid samsung xong thì up lại fw cho emmc thôi
  33. 8/11/17 lúc 09:05
    thangmobile89
    thangmobile89
    Flash file này ok luôn anh R827EX_11_A.07_160505
