driver Z3x box
Thảo luận trong 'SAMSUNG ANDROID' bắt đầu bởi tavanuyen, 10/5/16.
  1. 10/5/16 lúc 08:23
    tavanuyen
    tavanuyen
    như tiêu đề ai có driver box z3x không sher em với ... em cắm box vào máy tính thiếu driver ạ
  2. 10/5/16 lúc 08:46
    Dangkhoa_VFS
    Dangkhoa_VFS
    driver trong thư mục cài đặc có mà................
  3. 10/5/16 lúc 08:54
    công vĩnhlong
    công vĩnhlong
    ko dc qua yahoo em làm cho lẹ
  4. 10/5/16 lúc 08:55
    tavanuyen
    tavanuyen
    thank đã xong .. nhưng repari imei máy em đã root rồi mà bị lỗi này là sao ạ
    REPAIR INSTRUCTIONS:
    Phone must be rooted!
    If the software can't root the phone automatically,
    then you must root your device manually.
    1. Power on the phone.
    2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or
    tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+.
    3. Connect the phone to PC with USB cable, install drivers if needed.
    4. Select device in ADB settings.
    5. Fill values what you need to repair.
    6. Press 'Repair' button.
    7. Press 'Reset EFS' if you need to reset it.
    Be carefully, do not perform this without necessity and make backup before.
    8. Press 'Disable Factory Mode' or 'Patch Sertificate' if needed.
    Operation: Repair
    Selected model: GT-N7100
    Software version: 25.3
    If you are looking for 'Repair Network' function then you should use 'Patch Certificate'
    Waiting ADB device... OK
    Reading phone info...
    Model:
    Android version:
    Product code:
    Phone version:
    PDA version:
    CSC version:
    CSC country code:
    CSC sales code:
    HW version:
    Phone S/N:
    Modem board:
    RF cal date:
    IMEI:
    Checking Super user right... false
    Rooting phone, please wait... error
  5. 10/5/16 lúc 08:58
    tavanuyen
    tavanuyen
    *#0808# . chọn DM+MODEM+ADB máy tính báo driver unknow .. ai có driver ko sher em với ạ
