Downgrade f500l 6.0 ver 21a về 20C ok
Thảo luận trong 'LG ANDROID' bắt đầu bởi thangmobile89, 22/3/17.
  1. 22/3/17 lúc 11:18
    thangmobile89
    thangmobile89
    3/21/2017 4:38:26 PM> Looking for EasyJTAG box...
    3/21/2017 4:38:26 PM> EasyJTAG API ver. 2008
    3/21/2017 4:38:26 PM> Setting IO Levels to 3.3V
    3/21/2017 4:38:26 PM> Setting frequence to 14 Mhz
    3/21/2017 4:38:26 PM> HiPower mode is OFF
    3/21/2017 4:38:27 PM> OpenUSB returned = 0
    3/21/2017 4:38:27 PM> Power Controller returned = 0
    3/21/2017 4:38:27 PM> EasyJTAG Box Serial = xxxxxxxxxxxxx
    3/21/2017 4:38:27 PM> EasyJTAG Box Firmware = 01.58
    3/21/2017 4:38:27 PM> HiPower mode is OFF
    3/21/2017 4:38:27 PM> CMD Pullup Level: 2031 mV
    3/21/2017 4:38:27 PM> CMD Active Level: 2970 mV
    3/21/2017 4:38:27 PM> eMMC Init returned = 0
    3/21/2017 4:38:27 PM> EMMC Device Information :
    3/21/2017 4:38:27 PM> EMMC CID: 110100303332473332000A1A23CB2304
    3/21/2017 4:38:27 PM> EMMC CSD: D02700328F5903FFFFFFFFE7864000A6
    3/21/2017 4:38:27 PM> EMMC Manufacture Name: TOSHIBA
    3/21/2017 4:38:27 PM> EMMC Manufacture ID: 0x11 , OEM ID: 0100
    3/21/2017 4:38:27 PM> EMMC Manufacture Date: 2/2016 , Rev: 00
    3/21/2017 4:38:27 PM> EMMC NAME: 032G32 , S/N: 0A1A23CB , rev. 00
    3/21/2017 4:38:27 PM> EMMC NAME (HEX): 303332473332
    3/21/2017 4:38:27 PM> EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000)
    3/21/2017 4:38:27 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
    3/21/2017 4:38:27 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
    3/21/2017 4:38:27 PM> EMMC Permanent Write Protection: No
    3/21/2017 4:38:27 PM> EMMC Temporary Write Protection: No
    3/21/2017 4:38:27 PM> Extended CSD rev: 1.8 (MMC 5.1)
    3/21/2017 4:38:27 PM> Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot
    3/21/2017 4:38:27 PM> Boot Bus Config: 0x00 , width 1bit
    3/21/2017 4:38:27 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
    3/21/2017 4:38:27 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07
    3/21/2017 4:38:27 PM> Device supports partitioning features
    3/21/2017 4:38:27 PM> Device can have enhanced technological features in partitions and user data area
    3/21/2017 4:38:27 PM> Device can have extended partitions attribute
    3/21/2017 4:38:27 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
    3/21/2017 4:38:27 PM> Backup saved: 032G32_0A1A23CB_20170321_163827.extcsd
    3/21/2017 4:38:27 PM> EMMC Init completed.
    3/21/2017 4:38:27 PM> Operation: Write by vendor (LG)
    3/21/2017 4:38:27 PM> Filename: F500L20C_00.kdz
    3/21/2017 4:38:27 PM> Model: LG-F500L
    3/21/2017 4:38:27 PM> Software: F500L20c
    3/21/2017 4:38:27 PM> BuildTime: 0000-00-00 00:00:00
    3/21/2017 4:38:27 PM> Total Files: 68
    3/21/2017 4:38:27 PM> Unpacking files from the firmware. Please wait ...
    3/21/2017 4:40:22 PM> Unpack done
    3/21/2017 4:40:22 PM> Partition name: MODEM
    3/21/2017 4:40:22 PM> Filename: modem_32768.bin , Offset: 000001000000 , filesize: 78643200 bytes
    3/21/2017 4:40:22 PM> eMMC switching to ROM1
    3/21/2017 4:40:22 PM> Erasing partition...
    3/21/2017 4:40:28 PM> Writing partition...
    3/21/2017 4:41:52 PM> Done writing partition. Write speed: 912.62 Kb/s
    3/21/2017 4:41:52 PM> Partition name: PMIC
    3/21/2017 4:41:52 PM> Filename: pmic_229376.bin , Offset: 000007000000 , filesize: 524288 bytes
    3/21/2017 4:41:52 PM> eMMC switching to ROM1
    3/21/2017 4:41:52 PM> Erasing partition...
    3/21/2017 4:41:53 PM> Writing partition...
    3/21/2017 4:41:53 PM> Done writing partition. Write speed: 1336.82 Kb/s
    3/21/2017 4:41:53 PM> Partition name: SBL1
    3/21/2017 4:41:53 PM> Filename: sbl1_230400.bin , Offset: 000007080000 , filesize: 1048576 bytes
    3/21/2017 4:41:53 PM> eMMC switching to ROM1
    3/21/2017 4:41:53 PM> Erasing partition...
    3/21/2017 4:41:54 PM> Writing partition...
    3/21/2017 4:41:55 PM> Done writing partition. Write speed: 1071.78 Kb/s
    3/21/2017 4:41:55 PM> Partition name: TZ
    3/21/2017 4:41:55 PM> Filename: tz_232448.bin , Offset: 000007180000 , filesize: 1048576 bytes
    3/21/2017 4:41:55 PM> eMMC switching to ROM1
    3/21/2017 4:41:55 PM> Erasing partition...
    3/21/2017 4:41:56 PM> Writing partition...
    3/21/2017 4:41:57 PM> Done writing partition. Write speed: 1104.30 Kb/s
    3/21/2017 4:41:57 PM> Partition name: SDI
    3/21/2017 4:41:57 PM> Filename: sdi_234496.bin , Offset: 000007280000 , filesize: 524288 bytes
    3/21/2017 4:41:57 PM> eMMC switching to ROM1
    3/21/2017 4:41:57 PM> Erasing partition...
    3/21/2017 4:41:58 PM> Writing partition...
    3/21/2017 4:41:58 PM> Done writing partition. Write speed: 1368.70 Kb/s
    3/21/2017 4:41:58 PM> Partition name: HYP
    3/21/2017 4:41:58 PM> Filename: hyp_235520.bin , Offset: 000007300000 , filesize: 524288 bytes
    3/21/2017 4:41:58 PM> eMMC switching to ROM1
    3/21/2017 4:41:58 PM> Erasing partition...
    3/21/2017 4:41:59 PM> Writing partition...
    3/21/2017 4:41:59 PM> Done writing partition. Write speed: 1327.27 Kb/s
    3/21/2017 4:41:59 PM> Partition name: RPM
    3/21/2017 4:41:59 PM> Filename: rpm_236544.bin , Offset: 000007380000 , filesize: 524288 bytes
    3/21/2017 4:41:59 PM> eMMC switching to ROM1
    3/21/2017 4:42:00 PM> Erasing partition...
    3/21/2017 4:42:00 PM> Writing partition...
    3/21/2017 4:42:01 PM> Done writing partition. Write speed: 1130.80 Kb/s
    3/21/2017 4:42:01 PM> Partition name: ABOOT
    3/21/2017 4:42:01 PM> Filename: aboot_237568.bin , Offset: 000007400000 , filesize: 1048576 bytes
    3/21/2017 4:42:01 PM> eMMC switching to ROM1
    3/21/2017 4:42:01 PM> Erasing partition...
    3/21/2017 4:42:01 PM> Writing partition...
    3/21/2017 4:42:02 PM> Done writing partition. Write speed: 1016.26 Kb/s
    3/21/2017 4:42:02 PM> Partition name: SBL1BAK
    3/21/2017 4:42:02 PM> Filename: sbl1bak_241664.bin , Offset: 000007600000 , filesize: 1048576 bytes
    3/21/2017 4:42:02 PM> eMMC switching to ROM1
    3/21/2017 4:42:03 PM> Erasing partition...
    3/21/2017 4:42:03 PM> Writing partition...
    3/21/2017 4:42:04 PM> Done writing partition. Write speed: 1072.12 Kb/s
    3/21/2017 4:42:04 PM> Partition name: PMICBAK
    3/21/2017 4:42:04 PM> Filename: pmicbak_243712.bin , Offset: 000007700000 , filesize: 524288 bytes
    3/21/2017 4:42:04 PM> eMMC switching to ROM1
    3/21/2017 4:42:05 PM> Erasing partition...
    3/21/2017 4:42:05 PM> Writing partition...
    3/21/2017 4:42:05 PM> Done writing partition. Write speed: 1359.00 Kb/s
    3/21/2017 4:42:05 PM> Partition name: TZBAK
    3/21/2017 4:42:05 PM> Filename: tzbak_244736.bin , Offset: 000007780000 , filesize: 1048576 bytes
    3/21/2017 4:42:05 PM> eMMC switching to ROM1
    3/21/2017 4:42:06 PM> Erasing partition...
    3/21/2017 4:42:06 PM> Writing partition...
    3/21/2017 4:42:07 PM> Done writing partition. Write speed: 1086.64 Kb/s
    3/21/2017 4:42:07 PM> Partition name: HYPBAK
    3/21/2017 4:42:07 PM> Filename: hypbak_246784.bin , Offset: 000007880000 , filesize: 524288 bytes
    3/21/2017 4:42:07 PM> eMMC switching to ROM1
    3/21/2017 4:42:08 PM> Erasing partition...
    3/21/2017 4:42:08 PM> Writing partition...
    3/21/2017 4:42:08 PM> Done writing partition. Write speed: 1278.04 Kb/s
    3/21/2017 4:42:09 PM> Partition name: RPMBAK
    3/21/2017 4:42:09 PM> Filename: rpmbak_247808.bin , Offset: 000007900000 , filesize: 524288 bytes
    3/21/2017 4:42:09 PM> eMMC switching to ROM1
    3/21/2017 4:42:09 PM> Erasing partition...
    3/21/2017 4:42:09 PM> Writing partition...
    3/21/2017 4:42:10 PM> Done writing partition. Write speed: 1161.80 Kb/s
    3/21/2017 4:42:10 PM> Partition name: ABOOTBAK
    3/21/2017 4:42:10 PM> Filename: abootbak_248832.bin , Offset: 000007980000 , filesize: 1048576 bytes
    3/21/2017 4:42:10 PM> eMMC switching to ROM1
    3/21/2017 4:42:10 PM> Erasing partition...
    3/21/2017 4:42:11 PM> Writing partition...
    3/21/2017 4:42:12 PM> Done writing partition. Write speed: 1015.50 Kb/s
    3/21/2017 4:42:12 PM> Partition name: SDIBAK
    3/21/2017 4:42:12 PM> Filename: sdibak_252928.bin , Offset: 000007B80000 , filesize: 524288 bytes
    3/21/2017 4:42:12 PM> eMMC switching to ROM1
    3/21/2017 4:42:12 PM> Erasing partition...
    3/21/2017 4:42:13 PM> Writing partition...
    3/21/2017 4:42:13 PM> Done writing partition. Write speed: 1334.26 Kb/s
    3/21/2017 4:42:13 PM> Partition name: PERSIST
    3/21/2017 4:42:13 PM> Filename: persist_294912.bin , Offset: 000009000000 , filesize: 5242880 bytes
    3/21/2017 4:42:13 PM> eMMC switching to ROM1
    3/21/2017 4:42:13 PM> Erasing partition...
    3/21/2017 4:42:14 PM> Writing partition...
    3/21/2017 4:42:18 PM> Done writing partition. Write speed: 1429.84 Kb/s
    3/21/2017 4:42:18 PM> Partition name: SEC
    3/21/2017 4:42:18 PM> Filename: sec_376832.bin , Offset: 00000B800000 , filesize: 524288 bytes
    3/21/2017 4:42:18 PM> eMMC switching to ROM1
    3/21/2017 4:42:18 PM> Erasing partition...
    3/21/2017 4:42:19 PM> Writing partition...
    3/21/2017 4:42:19 PM> Done writing partition. Write speed: 1387.31 Kb/s
    3/21/2017 4:42:19 PM> Partition name: RCT
    3/21/2017 4:42:19 PM> Filename: rct_379904.bin , Offset: 00000B980000 , filesize: 524288 bytes
    3/21/2017 4:42:19 PM> eMMC switching to ROM1
    3/21/2017 4:42:19 PM> Erasing partition...
    3/21/2017 4:42:20 PM> Writing partition...
    3/21/2017 4:42:20 PM> Done writing partition. Write speed: 1421.55 Kb/s
    3/21/2017 4:42:20 PM> Partition name: LAF
    3/21/2017 4:42:20 PM> Filename: laf_393216.bin , Offset: 00000C000000 , filesize: 31981568 bytes
    3/21/2017 4:42:20 PM> eMMC switching to ROM1
    3/21/2017 4:42:20 PM> Erasing partition...
    3/21/2017 4:42:23 PM> Writing partition...
    3/21/2017 4:42:57 PM> Done writing partition. Write speed: 905.22 Kb/s
    3/21/2017 4:42:57 PM> Partition name: BOOT
    3/21/2017 4:42:57 PM> Filename: boot_491520.bin , Offset: 00000F000000 , filesize: 27262976 bytes
    3/21/2017 4:42:57 PM> eMMC switching to ROM1
    3/21/2017 4:42:58 PM> Erasing partition...
    3/21/2017 4:43:00 PM> Writing partition...
    3/21/2017 4:43:33 PM> Done writing partition. Write speed: 795.29 Kb/s
    3/21/2017 4:43:33 PM> Partition name: RECOVERY
    3/21/2017 4:43:33 PM> Filename: recovery_573440.bin , Offset: 000011800000 , filesize: 28835840 bytes
    3/21/2017 4:43:33 PM> eMMC switching to ROM1
    3/21/2017 4:43:34 PM> Erasing partition...
    3/21/2017 4:43:36 PM> Writing partition...
    3/21/2017 4:44:07 PM> Done writing partition. Write speed: 902.77 Kb/s
    3/21/2017 4:44:07 PM> Partition name: RAW_RESOURCES
    3/21/2017 4:44:07 PM> Filename: raw_resources_770048.bin , Offset: 000017800000 , filesize: 3670016 bytes
    3/21/2017 4:44:07 PM> eMMC switching to ROM1
    3/21/2017 4:44:07 PM> Erasing partition...
    3/21/2017 4:44:08 PM> Writing partition...
    3/21/2017 4:44:13 PM> Done writing partition. Write speed: 711.80 Kb/s
    3/21/2017 4:44:13 PM> Partition name: RAW_RESOURCESBAK
    3/21/2017 4:44:13 PM> Filename: raw_resourcesbak_778240.bin , Offset: 000017C00000 , filesize: 3670016 bytes
    3/21/2017 4:44:13 PM> eMMC switching to ROM1
    3/21/2017 4:44:14 PM> Erasing partition...
    3/21/2017 4:44:14 PM> Writing partition...
    3/21/2017 4:44:19 PM> Done writing partition. Write speed: 712.45 Kb/s
    3/21/2017 4:44:19 PM> Partition name: FACTORY
    3/21/2017 4:44:19 PM> Filename: factory_917504.bin , Offset: 00001C000000 , filesize: 31457280 bytes
    3/21/2017 4:44:19 PM> eMMC switching to ROM1
    3/21/2017 4:44:20 PM> Erasing partition...
    3/21/2017 4:44:22 PM> Writing partition...
    3/21/2017 4:44:56 PM> Done writing partition. Write speed: 903.19 Kb/s
  2. 22/3/17 lúc 11:37
    auchanvan
    auchanvan
    Nhớ không lầm thì con này hạ xuống 5.1 còn được nữa mà !
  3. 22/3/17 lúc 11:38
    caothanglc
    caothanglc
    dùng easy jtag hạ đây mà :)
  4. 22/3/17 lúc 11:41
    auchanvan
    auchanvan
    jtag hạ cũng như up rom hạ thôi, nếu máy không hạ được thì jtag hạ cũng chết như rạ
  5. 22/3/17 lúc 12:09
    thangmobile89
    thangmobile89
    máy lên ver cao nhất rồi
    Không dùng tool hạ được
    Nạp tới boot là đứng
    Máy treo download mode ngay
    nên mới dùng easy jtag hạ
    Nếu hạ bằng tool thì được thì đã ngon bác ợ
