Lượm nhặt về cho anh em tham khảo , trên forum mrt . About huawei flash file knowledge in mrt QuotePost by zhulianqi » Tue Jan 21, 2020 4:02 pm when we download one huawei flash file like emui 9.1 emui 10.0 we can get 6 *.app file like this and we are flash it need like the pics, ptable.app first then update.app now we can make one txt file put all the file name inside and use mrt hw flash tool you can select it make flash it in the one time as we know;if mobile has frp and huawei id;we can not downgrade mobile version emui10 to emui9.1 or like emui9.1.226 we can not downgrade to emui 9.1.193 but with mrt,it is Possible!!! and sure 100%%%% how to do? take one save mobile version flsah file and take it verlist save to same file with what i want to right ex,i take emui10.0.0185 flash file,use mrt take the base_patble,cust_ptable,preloader patble,base update,cust_update,preload_update.... save to same file name.like base_patble.app save same Folder base_patble.app_verlist then you can flash it!!! even downgrade!!! the flsah txt file we are still same before like this,when flashing mobile,auto replace the flsah file verlist form we are creat!!! also you can take L29 verlist put in the AL00 and make Transformation ex,take vog-L29 verlist and put in the VOG-AL00 flash it!!! Top zhulianqi Site Admin Posts: 36 Joined: Tue Aug 13, 2019 6:58 pm Has thanked: 15 times Been thanked: 360 times Re: About huawei flash file knowledge in mrt QuotePost by zhulianqi » Tue Jan 21, 2020 4:36 pm is possible without same mobile version i can downgrade the mobile!!! yes,is true also!!! now we are learn more about this!!! 3 fastboot order get the mobile 3 version info fastboot oem oeminforead-BASE_VERSION fastboot oem oeminforead-CUSTOM_VERSION fastboot oem oeminforead-PRELOAD_VERSION form update_sd_base Folder the app all are same also cust also preload we can use hex edit tool and creat it this is form org file we can see every version end 0x0a;like \n we are creat like we are the base_sd_base creat a file and save it like this also we can flash to any version!!! here just a sample,you need do the cust and preload also!!!
