Info: 1. Power Off Phone , Remove Battery, Insert Battery Back 2. Insert USB cable. In some cases Required Hold BootKey 3. Use Miracle Boot Key In cases Boot key not Find 4. Battery Should be Charged more then 50% Waiting for USB Port... Set PreLoader USB VCOM Port (COM24) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6572 SW:0000 Ver: CA01 Downloading Boot8 ... Nand Flash Type: Nand_NEW_0072 Nand Flash Code: 009800BC(00900066) Nand Flash Size: 0x20000000 Hex Bytes INT/EXT RAM Size: 0xC4800+0x0 Reading Size: 0x21000000 Reading infr(Nand)... PRELOADER BaseAddr:0x0 Size:0x80000 PRO_INFO BaseAddr:0x80000 Size:0x100000 NVRAM BaseAddr:0x180000 Size:0x300000 PROTECT_F BaseAddr:0x480000 Size:0x300000 PROTECT_S BaseAddr:0x780000 Size:0x300000 SECCFG BaseAddr:0xA80000 Size:0x40000 UBOOT BaseAddr:0xAC0000 Size:0x80000 BOOTIMG BaseAddr:0xB40000 Size:0x600000 RECOVERY BaseAddr:0x1140000 Size:0x600000 SEC_RO BaseAddr:0x1740000 Size:0x40000 MISC BaseAddr:0x1780000 Size:0xC0000 LOGO BaseAddr:0x1840000 Size:0x100000 EXPDB BaseAddr:0x1940000 Size:0x200000 FAT BaseAddr:0x1B40000 Size:0x1400000 ANDROID BaseAddr:0x2F40000 Size:0x12C00000 FLAG BaseAddr:0x15B40000 Size:0x700000 CACHE BaseAddr:0x16240000 Size:0x700000 USRDATA BaseAddr:0x16940000 Size:0x8240000 BMTPOOL BaseAddr:0xFFFF0050 Size:0x0 Done. 1. Power Off Phone , Remove Battery, Insert Battery Back 2. Insert USB cable. In some cases Required Hold BootKey 3. Use Miracle Boot Key In cases Boot key not Find 4. Battery Should be Charged more then 50% Waiting for USB Port... Set PreLoader USB VCOM Port (COM24) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6572 SW:0000 Ver: CA01 Downloading Boot8 ... Nand Flash Type: Nand_NEW_0072 Nand Flash Code: 009800BC(00900066) Nand Flash Size: 0x20000000 Hex Bytes INT/EXT RAM Size: 0xC4800+0x0 Waiting for USB Port... Set DA USB VCOM Port (COM54) File Mode Reading Size: 0x21000000 Reading(Nand)... Read OK. total: 3 mins24 s >>File save to:\Wing_Hero_40_MTK6572_28052016.bin Download Now: Wing_Hero_40_MTK6572_28052016_Miracle.rar 247.9 MB https://mega.nz/#!pNYgiY6S!iaRSE0ovdm5h40wfTSJpHtbe8Otu0hxTEez8uPZG8S8
