driver em nó lấy NokiaSoftwareUpdaterForRetail_4.3.2.exe là ok trong ATF ko có nhé ace Nokia Phone Info Mode Initiated... Please wait upto 15 Seconds for SW Reset 1. Press and Hold the VOLUME DOWN and POWER 2. Wait until the Phone Reboots... 3. Wait until you see BIG "NOKIA" Logo 4. Stop Pressing the Buttons... Version: 2.5.2.11 Product Code: 059X1B4 Module Code: 0206509 Basic Tranceiver Code: 059W7D3 Continuing Previous Boot... Please wait upto 30 Seconds for Boot Re-entry Boot Flash Mode Successful... Buffers Flushed OK... Phone Info Query Start... Blocks Returned: 0x09 Blocks Block ID 0x01 : 00241000 Block ID 0x1F : 01 Block ID 0x02 : 00240000 Block ID 0x03 : 00E90000 Block ID 0x05 : Nokia.MSM8210.P6221.1.1 Block ID 0x0D : 0001 Block ID 0x0F : 0301010100000101FF Block ID 0x10 : 01000F0000 Block ID 0x20 : 010000000100000004 Checking SD Card Size... Card Size: 0x00000000 Checking Platform Security Status... Platform Secure Boot Status: Active Secure FFU EFUSE Status: Active Debug Status: Active RDC Status: Not Active Authentication Status: Not Active UEFI Secure Boot Status: Active Checking Secure FFU Mode... Secure FFU Mode : Query Flash App Information... Flash App Information: 020222023B00 UEFI App: FLASH APP Flash App Protocol Version: 2.34 Flash App Implementation Version: 2.59 Query ROOT KEY HASH... ROOT_KEY_HASH: 4D4365FCDE0253030F5F230D11EFE7D1A23E9823E21F6CD83469B47CBBD2505F Query PUBLIC ID... PUBLIC_ID: 606E9B5C80280DC02E9232B87688ACA0BCB58CA2 Query eMMC Info... EMMC Manufacture ID: HYNIX EMMC Product SN : 7B6A444D EMMC_SIZE: 8 Gigabytes Query Battery Charge Status... BATTERY CHARGE_STATUS: 29% Sending Image Signatures... Image Signatures Accepted! Erasing Data Partition... Data Partition Erased Successfully Preparing Buffers for DATA LOOP... Allocating System RAM OK! Start Sending DATA BLOCKS... Finished Sending all DATA BLOCKS! Exiting FLASH Mode via REBOOT... Exit FLASH Mode Successful! Flashing Done! Total Flashing Time : 00:06:56
máy này nó dính máy bay mà nó khóa màn hình 2 phút(rồi tắt tự khởi động lại) , giống như iphone bi vô hiệu hóa vậy nên mình ko kiểm tra được imei còn ko . Khi chạy lene thì nó ok cái này nó chỉ có cái là driver nó mò cả tiếng mới ra
