AE làm qua rồi coi dùm mình con này unclok xong có sóng ko zậySmart PhoneForm FactorBar4G TechnologyCDMA, LTE*ProcessorQualcomm® Snapdragon™ 1.2 GHz Dual-core, Dual-channel, Single LTE ChipsetNetworkTri-Band/Dual-Mode/LTE B2, B4Frequencies1.9 GHz CMDA PCS, 800 MHz CDMA, 1.7/2.1 GHz AWS***Data TransmissionEVDO, 1xRTT, LTEDimensions5.08" (H) x 2.61" (W) x 0.37" (D)Weight4.3 oz.DisplayTFT, 960 x 540 pixels, 4.5"Touch ScreenYesBattery Capacity2,150 mAhTalk TimeUp to 7 hours (in 1x only)*Standby TimeUp to 200 hours (in 1x only)*Internal Memory4.3 GB internal memorymicroSD™ Memory SlotSupports up to 32 GB memory card***Certain features may use more power and cause actual time to vary.**MicroSD cards sold separately.***All listed frequency support is network/carrier specific. When roaming, network specific frequency support may not be available. Check with your network provider to see if and to what extent they offer support for this device.
2G networkCDMA 800/19003G networkCDMA2000 1xEV-DO4G networkLTE 1700/1900/2100 (Bands 2,4)Data networkCDMA2000 EV-DO Rev A, LTECon này đời cũ của Sprint, CDMA Only. LTE B2 B4 không hỗ trợ ở VN. Unlock xong cũng không dùng được GSM. LTE thì không có bands, nếu có vô dc LTE thì cũng chỉ có Data không có Voice. Back luôn cho đỡ mất thời gian nha bác
