như tiêu đề máy bị lỗi emmc , em thay con khác vào . nhưng chạy spflashtool lỗi 4032 Z3X EasyJtag Software ver. 2.5.0.4 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 01FF800DE7468209, ,FW Ver.: 01.56 CMD Pullup Level:2093 mV CMD Active Level:2340 mV Box IO Level:2800 mV CLK Rate:14000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 90014A2058494E594816A101CFA840D8 EMMC CSD : D02701320F5903FFFFFFFFE78A4040E2 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 04/2013 Rev.0x16 EMMC NAME: XINYH , S/N: 2701250472 EMMC NAME (HEX): 2058494E594800 EMMC ROM1 (Main User Data) Capacity: 3696 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 2048 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: XINYH_2701250472_20161215_0855.extcsd Done. ace nào làm qua xin giúp em với , thanks
EMMC ROM1 (Main User Data) Capacity: 3696 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048kb đẩy lên 4mb 4mb + set boot x48
