Cần giúp LG - G5
Thảo luận trong 'LG ANDROID' bắt đầu bởi haphuong11qn, 28/4/18.
  1. 28/4/18 lúc 15:41
    haphuong11qn
    haphuong11qn
    LG - G5 -LS992 ZVF em up rom không biết có nhầm phiên bản không bây giờ hết vào dowloadmode được luôn ,gắn cáp nhận cổng Qualcomm HS-USB QDLoader 9008. máy hiện tai ko lên nguồn ,nhờ anh em giúp gấp ạ.thank
  2. 28/4/18 lúc 15:43
    haphuong11qn
    haphuong11qn
    hecking data...OK
    Platform: LG Qualcomm
    Selected port: COM58
    Selected model: LS992
    Reading info...
    IMEI: 355602-07-248633-9
    Android version: 7.0
    Battery level: 42%
    SW Version: LS992ZVF
    Mode: Emergency
    Initializing flash...OK
    SW version: LS992ZVF_00
    LAF Version: 1.1
    Product ID: PT02S160509004451
    Target operator: SPR
    Hardware: rev_10
    Writing phone firmware without real necessity is at your own risk.
    Downgrade may lead to phone damage!
    Please, make sure the phone's battery is fully charged.
    Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs.
    To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices).
    You should not run any other programs or attach new devices to your computer during the flashing!
    Opening "LS992ZV8_04_1104.oct"...OK
    Setting options...OK
    Reading partitions...OK
    Formating USERDATA...OK
    Formating ENCRYPT...OK
    Sending signature...OK
    Writing PrimaryGPT...OK
    Writing laf...OK
    Writing factory...OK
    Writing persist...OK
    Writing system...OK
    Writing BackupGPT...OK
    Writing xbl...OK
    Writing xblbak...OK
    Writing xbl2...OK
    Writing xbl2bak...OK
    Writing boot...OK
    Writing recovery...OK
    Writing recoverybak...OK
    Writing tz...OK
    Writing tzbak...OK
    Writing aboot...OK
    Writing abootbak...OK
    Writing raw_resources...OK
    Writing raw_resourcesbak...OK
    Writing rpm...OK
    Writing rpmbak...OK
    Writing hyp...OK
    Writing hypbak...OK
    Writing pmic...OK
    Writing pmicbak...OK
    Writing devcfg...OK
    Writing devcfgbak...OK
    Writing modem...OK
    Writing sec...OK
    Writing keymaster...OK
    Writing keymasterbak...OK
    Writing cmnlib...OK
    Writing cmnlibbak...OK
    Writing cmnlib64...OK
    Writing cmnlib64bak...OK
    Writing apdp...OK
    Writing msadp...OK
    Finalizing...OK
    Writing firmware done!
    Performed by 2.8.0 Software version.
    Và nó đã bị mất nguồn
  3. 28/4/18 lúc 16:20
    vungoc-mobile
    vungoc-mobile
    Thay main hoặc vứt xó chờ thời...
  4. 28/4/18 lúc 16:34
    haphuong11qn
    haphuong11qn
    Hic, dính xương bác ơi! không con cách nào hả bác?
  5. 28/4/18 lúc 16:50
    huydq948
    huydq948
    Downgrade => brick
    Dính cái này thì xác định mua main đền thôi, LS992 Downgrade chết thì thua
  6. 28/4/18 lúc 16:57
    tieuhoangtu186
    tieuhoangtu186
    quay về nơi sản xuất
  7. 28/4/18 lúc 18:41
    Tuan Pham
    Tuan Pham
    Hạ cấp có thể dẫn đến hư hỏng điện thoại
  8. 28/4/18 lúc 18:49
    tieuhoangtu186
    tieuhoangtu186
    y như g532 log dẹp như NgocTrinh , mở éo lên
  9. 30/4/18 lúc 13:01
    thoiapple923
    thoiapple923
    Có luôn :D
    Bửa hạ 1 con V20 Sprint ZVA-->ZV8
  10. 30/4/18 lúc 15:14
    tran hoi
    tran hoi
    g5 mà hạ với nhảy nền thì xác định đền là cái chắc. đang chạy zvf hạ xuống zv8 thì tomiteo ngay là k oan uổng.
  11. 30/4/18 lúc 15:18
    caothanhchuyen
    caothanhchuyen
    mấy dòng lg sau này thường hạ ver hay chết
Mudim v0.8 Tắt VNI Telex VIQR Đủ kiểu Tự động Sửa lỗi chính tảDùng kiểu bỏ dấu mới [ Toggle (F9) Toggle Panel (F8) ]
