Cần giúp hack active ip4 lock 7.1.2
Thảo luận trong 'SỬA CHỮA PHẦN CỨNG.' bắt đầu bởi service8, 9/1/15.
  1. 9/1/15 lúc 21:32
    service8
    service8
    Em có cây ip4 lock ghép sim,em úp len 7.1.2 giu bb ok mà dùng tool hack active thì bị lỗi không hack active được,mog các anh đã làm qua chỉ giúp e .Thank ALL!!!!
  2. 9/1/15 lúc 21:53
    ios_1987
    ios_1987
    cúng đang cần , bài này tim lại có của đôn chia sẻ nhưng khó
  3. 9/1/15 lúc 22:18
    service8
    service8
    làm theo huong dẫn dùng tool hackactive nhung bi treo táo lunct/ct/
  4. 9/1/15 lúc 22:34
    No-iMEi
    No-iMEi
    1- Restore your Locked iPhone 4 .
    2- Get the device in DFU mode . ( lot of tutorials on internet )
    3- Use The Exploit for getting the device into SSH ( SSH-Ramdisk or JAR )
    4- Use WinSCP to SSH into the device .
    5- In the terminal "mount.sh"
    6- Go to mnt2/library/lockdown/data_ark ( copy that file to your desktop )
    7- Edit that file in windows with Plist Editor Pro .
    8- Erase all content and copy this code :
    <?xml version="1.0" encoding="UTF-8"?>
    <!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
    <plist version="1.0">
    <dict>
    <key>-BrickState</key>
    <true/>
    <key>-DeviceName</key>
    <string>iPhone</string>
    <key>-FirstFreePairExpired</key>
    <true/>
    <key>-PreviousSIMStatus</key>
    <string>kCTSIMSupportSIMStatusNotInserted</string>
    <key>-ProtocolVersion</key>
    <string>2</string>
    <key>-SBLockdownEverRegisteredKey</key>
    <false/>
    <key>-TimeIntervalSince1970</key>
    <integer>1406103042</integer>
    <key>-TimeZone</key>
    <string>America/Mexico_City</string>
    <key>-UseRaptorCerts</key>
    <false/>
    <key>com.apple.international-Language</key>
    <string>en</string>
    <key>com.apple.international-Locale</key>
    <string>en_US</string>
    <key>com.apple.mobile.backup-CloudBackupEnabled</key>
    <false/>
    <key>com.apple.mobile.backup-RequiresEncryption</key>
    <integer>0</integer>
    <key>com.apple.mobile.chaperone-migrated</key>
    <true/>
    <key>com.apple.mobile.lockdown_cache-ActivationState</key>
    <string>FactoryActivated</string>
    <key>com.apple.mobile.restriction-ProhibitAppDelete</key>
    <false/>
    <key>com.apple.mobile.restriction-ProhibitAppInstall</key>
    <false/>
    <key>com.apple.mobile.who-epoch_build</key>
    <string>11D257</string>
    <key>com.apple.mobile.who-uptodate</key>
    <integer>1</integer>
    <key>com.apple.mobile.who-uptodate_build</key>
    </dict>
    </plist>
    9- Save the changes and copy your new data_ark into mnt2/library/lockdown ( same folder where you got the file and REPLACE)
    10- Press Home button along with the power button ( to reset the device until recovery or itunes logo appears )
  5. 10/1/15 lúc 09:03
    service8
    service8
    thank a giup đỡ co thể chỉ chi tiết hơn ko a?
