cần giúp EMMC SKY A830K!
Thảo luận trong 'CÁC DÒNG ANDROID KHÁC' bắt đầu bởi manh_cuong, 27/3/15.
  1. 27/3/15 lúc 11:36
    manh_cuong
    manh_cuong
    máy nhận khách tự nhiên mất nguồn căm pc thấy nhận usb em repair boot báo lỗi, fomat emmc thì báo lỗi như này ae ai biết chỉ giúp e với ạ! có phải emmc đi bụi rùi ko ạ?
    eMMC Boot Information
    Revision 1.5 (for MMC v4.41)
    BOOT PARTITION : NOT BOOT ENABLED
    PARTITION ACCESS : R/W USER PARTITION
    PERM_BOOT_CFG_PROT : DISABLED
    PWR_BOOT_CFG_PROT : DISABLED
    BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED
    RESET BUS WIDTH : ENABLED
    eMMC FirmW UPDATE : DISABLED
    EMMC CACHE SIZE : 0 KB
    SUPER PAGE SIZE : 3584 KB
    HC ERASE GROUP SIZE: 512 KB
    USER AREA SIZE : 15634268160 BYTES
    BOOT PARTITION SIZE: 2048 KB
    RPMB PARTITION SIZE: 128 KB
    eMMC Device Information
    Manufacturer ID: SAMSUNG
    Device Type : Embedded BGA
    Application ID : 00
    Product Name : MAG2GA
    Product Rev : 0.6
    Product SN : 65119DFB
    Manufactured : January 2012
    Card Specific Data
    CSD_STRUCTURE : Extended
    SPEC_VERS : Version 4.1/4.2/4.3
    TAAC : 13 ns
    TRANS_SPEED : 4000000 KHz
    READ_BL_LEN : 512 Bytes
    C_SIZE : HIGH CAPACITY
    WP_GRP_ENABLE : YES
    WRITE_BL_LEN : 512 Bytes
    CONTENT_PROT_APP : NO
    PERM_WRITE_PROTECT: NO
    TMP_WRITE_PROTECT : NO
    Extended CSD Saved:
    1501004D41473247410665119DFB_999A3806.ext_csd
    Backup Directory:
    C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\
    Task Selected: Samsung Factory Format
    For eMMC Revision 1.5 (for MMC v4.41) and LOWER
    --> This will ERASE USER AREA, BOOT1, BOOT2, RPMB and EXT_CSD R/W/E Entries
    For eMMC Revision 1.6 (for MMC v4.5) and HIGHER
    --> This will ONLY ERASE USER AREA
    This eMMC is: Revision 1.5 (for MMC v4.41)
    Samsung Factory Format Start...
    ERROR: SAMSUNG_FACTORY_FORMAT FAILED 0x02
