cần giúp emmc c5 ultra
Thảo luận trong 'SONY ANDROID' bắt đầu bởi hoanganh store, 11/7/18.
  1. 11/7/18 lúc 09:42
    hoanganh store
    hoanganh store
    a nào gặp giúp e phát. e nạp báo lỗi vậy là sao ạ
    Setting frequence to 21 Mhz
    CMD Pullup Level: 1680 mV
    CMD Active Level: 1763 mV
    EMMC Device Information :
    EMMC CID: 150100523331314D42012CE8D47292A6
    EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C
    EMMC Manufacture : SAMSUNG , EMMC NAME: R311MB , HEX: 523331314D42 , S/N: 2CE8D472 , rev. 0x01
    EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 9/2015
    EMMC ROM 1 (Main User Data) Capacity: 14910 MB (0003A3E00000)
    EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
    EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
    EMMC GP1 (GP Partition 1) Capacity: 16 MB , ENH , WR_REL (000001000000)
    EMMC Permanent Write Protection: No
    EMMC Temporary Write Protection: No
    Extended CSD Information :
    Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
    Boot configuration [PARTITION_CONFIG]: 0x50 , Boot from: ROM3 (Boot partition 2)
    Boot Bus Config: 0x00 , width 1bit
    H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
    Supported partition features [PARTITIONING_SUPPORT]: 0x07
    Device supports partitioning features
    Device can have enhanced technological features in partitions and user data area
    Device can have extended partitions attribute
    Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01
    Backup saved: R311MB_2CE8D472_20180711_093940.extcsd
    EMMC Init completed.
    Opening file: Sony_Xperia_C5_Ultra_Dual_E5563_29.1.B.0.87_Customized_India.ftf
    preloader_s1sbl_PLATFORM-MT6752-LIVE-95CE-OEM1-ROOT_S1-BOOT-LIVE-4154-0004-MMC.sinb
    Found 3 supported eMMC CID:
    name = 'RNW00M' hex = 0x524E5730304D [SAMSUNG]
    name = 'R311MB' hex = 0x523331314D42 [SAMSUNG]
    name = 'HAG2e' hex = 0x484147326505 [SKHYNIX]
    eNAND_H26M52103FMR/16GB @FBGA169
    eNAND_H9TQ17A8GTMCUR-KTM/16GB @BGA221
    eNAND_H9TQ17A8GTMCUR-KUM/16GB @BGA221
    eNAND_H9TQ17ABJTMCUR-KTM/16GB @BGA221
    eNAND_H9TQ17ABJTMCUR-KUM/16GB @BGA221
    MTK
    GPT
    The addresses in the table are incorrect
    For correcting addresses, do not forget to add the CDF to the "Firmware files"
    Error: eMMC has a small size
