cần giúp coolpad E501
Thảo luận trong 'CÁC DÒNG ANDROID KHÁC' bắt đầu bởi Duy_lực mobile, 22/2/17.
  1. 22/2/17 lúc 09:11
    Duy_lực mobile
    Duy_lực mobile
    e đã cài full driver rồi,máy nhận driver ok,đã chon 2 file lun rồi nhưng k flash dc,ace coi dùm nó bị gì vậy?
  2. 22/2/17 lúc 09:14
    Duy_lực mobile
    Duy_lực mobile
  3. 22/2/17 lúc 09:14
    Duy_lực mobile
    Duy_lực mobile
  4. 22/2/17 lúc 09:20
    Duy_lực mobile
    Duy_lực mobile
    09:19:35 CELL1: V4.0.3.0
    09:19:35 CELL1: Cell 1 USB address is: 4A24969
    09:19:55 CELL1: Download Started...
    09:19:55 CELL1: Downloading CPB:
    09:19:55 CELL1: Init DownQueue...
    09:19:55 CELL1: 4.4.177.00.P2.150901.Y76_I01.def
    09:19:55 CELL1: Device connected, start to download ...
    09:19:55 CELL1: Get bootloader information ...
    09:19:55 CELL1: Bootloader is new !
    09:19:55 CELL1: Bootloader will not use CRC while system img!
    09:19:55 CELL1: Bootloader supports querying CID!
    09:19:55 CELL1: Bootloader does not support querying Secure !
    09:19:55 CELL1: Check device ...
    09:19:55 CELL1: Jump eMMC check. User setting.
    09:19:55 CELL1: Check phone pass !
    09:19:55 CELL1: The phone doesn't support check the secure!
    09:19:55 CELL1: Phone fix pass !
    09:19:55 CELL1: Switched device to upgrade mode ...
    09:19:55 CELL1: Start to download CPB ...
    09:19:55 CELL1: C:\Users\Administrator\Downloads\Compressed\Cool pad E501_4\E501\4.4.177.00.P2.150901.Y76_I01.def\4.4.177.00.P2.150901.Y76_I01.def.CPB
    09:19:55 CELL1: Start to download sbl1.mbn file ...
    09:19:55 CELL1: Transmit sbl1.mbn file size info OK
    09:19:56 CELL1: Transmit sbl1.mbn file Flag code OK
    09:19:56 CELL1: Start to download tz.mbn file ...
    09:19:56 CELL1: Transmit tz.mbn file size info OK
    09:19:56 CELL1: Transmit tz.mbn file Flag code OK
    09:19:56 CELL1: Start to download hyp.mbn file ...
    09:19:56 CELL1: Transmit hyp.mbn file size info OK
    09:19:56 CELL1: Transmit hyp.mbn file Flag code OK
    09:19:56 CELL1: Start to download rpm.mbn file ...
    09:19:56 CELL1: Transmit rpm.mbn file size info OK
    09:19:56 CELL1: Transmit rpm.mbn file Flag code OK
    09:19:56 CELL1: Start to download sbl1.mbn file ...
    09:19:56 CELL1: Transmit sbl1.mbn file size info OK
    09:19:56 CELL1: Start to download emmc_appsboot.mbn file ...
    09:19:56 CELL1: transmit emmc_appsboot.mbn file size info OK
    09:19:57 CELL1: Fail to transmit emmc_appsboot.mbn file Flag code
    09:19:57 CELL1: Res:bad aboot image
    09:19:57 CELL1: Fail to transmit emmc_appsboot.mbn file data !
    09:19:57 CELL1: Lock bootloader ...
    09:19:57 CELL1: Download failed,please try again!!
    09:19:57 CELL1: Total download time elapsed: 0 min : 2 sec
    09:19:57 CELL1: Downloading all files: Failed!
    như vậy là bị sao trời,ace nào làm qua giúp e phát
  5. 22/2/17 lúc 09:36
    danghueqn
    danghueqn
  6. 22/2/17 lúc 10:05
    Duy_lực mobile
    Duy_lực mobile
    lấy tool 4.0.3 và 4.0,flash báo lỗi,tool 3.98 chạy ok
    trung20055 thích bài này.
