cần ace giúp repair emmc sky a830s
Thảo luận trong 'CÁC DÒNG ANDROID KHÁC' bắt đầu bởi luyenmobile, 19/12/14.
  1. 19/12/14 lúc 15:48
    luyenmobile
    luyenmobile
    em dùng atf để sửa lỗi emmc con này,log atf báo done rồi mà em kẹp nguồn chỉ thấy kim đồng hồ dao động lên xuông thôi.sửa lỗi emmc xong có phải repair lại boot không ạ,đây là log của nó ace xem giúp em với
    1. DO NOT USE THE PHONE"S BATTERY
    2. Connect the Soldered TP Connections to ATF Box
    3. Disconnect the USB Cable and Wait until the
    the ATF Software will tell you to Connect the USB.
    Interface Reset OK!
    eMMC Access Type: SECTOR MODE
    eMMC Supported Voltage Range:
    3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V
    3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V
    CID : 1501004D414732474106E11DEA92
    CSD : D02701320F5903FFF6DBFFFF8A404007
    eMMC Boot Information
    Revision 1.5 (for MMC v4.41)
    BOOT PARTITION : NOT BOOT ENABLED
    PARTITION ACCESS : R/W USER PARTITION
    PERM_BOOT_CFG_PROT : DISABLED
    PWR_BOOT_CFG_PROT : DISABLED
    BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED
    RESET BUS WIDTH : ENABLED
    eMMC FirmW UPDATE : DISABLED
    EMMC CACHE SIZE : 0 KB
    SUPER PAGE SIZE : 3584 KB
    HC ERASE GROUP SIZE: 512 KB
    USER AREA SIZE : 15634268160 BYTES
    BOOT PARTITION SIZE: 2048 KB
    RPMB PARTITION SIZE: 128 KB
    eMMC Device Information
    Manufacturer ID: SAMSUNG
    Device Type : Embedded BGA
    Application ID : 00
    Product Name : MAG2GA
    Product Rev : 0.6
    Product SN : E11DEA92
    Manufactured : January 2012
    Card Specific Data
    CSD_STRUCTURE : Extended
    SPEC_VERS : Version 4.1/4.2/4.3
    TAAC : 13 ns
    TRANS_SPEED : 4000000 KHz
    READ_BL_LEN : 512 Bytes
    C_SIZE : HIGH CAPACITY
    WP_GRP_ENABLE : YES
    WRITE_BL_LEN : 512 Bytes
    CONTENT_PROT_APP : NO
    PERM_WRITE_PROTECT: NO
    TMP_WRITE_PROTECT : NO
    Extended CSD Saved:
    1501004D414732474106E11DEA92_3C484423.ext_csd
    Backup Directory:
    C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\
    Task Selected: Samsung Factory Format
    For eMMC Revision 1.5 (for MMC v4.41) and LOWER
    --> This will ERASE USER AREA, BOOT1, BOOT2, RPMB and EXT_CSD R/W/E Entries
    For eMMC Revision 1.6 (for MMC v4.5) and HIGHER
    --> This will ONLY ERASE USER AREA
    This eMMC is: Revision 1.5 (for MMC v4.41)
    Samsung Factory Format Start...
    Format Done!
    WARNING - WARNING - WARNING - WARNING - WARNING
    1. WRITE Back EXT_CSD Backup if Needed
    2. WRITE BOOT1 Image if Needed
    3. WRITE BOOT2 Image if Needed
    4. WRITE USER AREA Image if Needed
    Start Writing 0x00100000 Blocks at 0x00000000
    Partition Selected: USER AREA
    Total Elapsed Time 00:14:48
    Write Success!
