cần a giúp flash nkia 8800e-1 mất nguồn
Thảo luận trong 'SỬA CHỮA PHẦN MỀM.' bắt đầu bởi vietduc2011, 21/2/17.
  1. 21/2/17 lúc 10:53
    vietduc2011
    vietduc2011
    e nhận cây 8800e mất bộ sưu tập e cho vào ATF flash giờ mất nguồn luôn,ae ai rành giúp e với,e đưa log lên đây
    Number of Image Files: 2
    Processing Image File :
    rm233__10.00.mcusw
    CMT Type : BB5
    CMT Algorithm : BB5 ALGORITHM
    Secondary Sending Speed : 51000Hz
    Algorithm Sending Speed : 6500000Hz
    Program Sending Speed : 6500000Hz
    Message Reading Speed : 98000Hz
    Number of Blocks : 1227
    Entry Point: 0x4FFB
    Page Format : -1
    MAX PAGE : 0x00004000
    rm233__10.00.ppm_v
    CMT Type : BB5
    Number of Blocks : 383
    Entry Point: 0x00B6
    Page Format : -1
    AUTO SELECTED DEAD USB FLASHING...
    If Phone Booting does not Start in 5 Seconds,
    Then Perform Steps 1, 2, 3 and 4...
    1. Remove USB and Battery...
    2. Insert USB.
    3. Insert Battery. (Some phones boot automatically)
    4. Please Power on phone shortly...
    AdvanceFBox SendBootCodeEx
    InitialiseBootstrap_DCT5 DIR
    BootFlashMode_DCT5
    READING BOOTROM
    BootFlashModeDCT5Ex Succeded After 0 Tries
    SYSTEM_ID_RESPONSE_BB5 (0xC0) - 96 (0x60) bytes returned
    Number of Sub Blocks 7 (0x07)
    1 SYSTEM_ASIC_ID 01
    Block Length : 21 (15)
    BB ASIC Index : 0 (00) CMT
    ID DWORD 0 : 00000001
    ID DWORD 1 : 00000226
    ID DWORD 2 : 00010006
    ID DWORD 3 : 010C1921
    ID DWORD 4 : 01003000
    2 EM_ASIC_ID 02
    Block Length : 5 (05)
    ID DWORD 0 : 00000295
    3 EM_ASIC_ID 02
    ID DWORD 0 : 00000B22
    4 PUBLIC_ID 12
    ID DWORD 0 : 0B400217
    ID DWORD 1 : D0218C56
    ID DWORD 2 : E0BBDC46
    ID DWORD 3 : F652D7BC
    ID DWORD 4 : 86A13153
    5 ASIC_MODE_ID 13
    Block Length : 2 (02)
    Mode Id : 00
    6 ROOT_KEY_HASH 14
    Block Length : 17 (11)
    Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1
    7 ROM_ID 15
    Block Length : 9 (09)
    CRC 0 : 273F6D55
    CRC 1 : DFAAF68F
    ADL_SERVER: PROCESSING rm233__10.00.mcusw
    ADL_SERVER: ROOT_KEY_HASH MATCH FOUND
    ADL_SERVER: CMT CERTIFICATE BLOCK FOUND
    ADL_SERVER: CMT DATA BLOCKS FOUND
    ADL_SERVER: CONSOLIDATING CMT BLOCKS
    ADL_SERVER: PASUBTOC BLOCK FOUND
    BB5 ADL Loader Start Up... (Please Wait...)
    ERROR: ADL Loader was not accepted
    PAPUB Key HASH is EMPTY or BLANK.
    Try "Skip ADL Check" Option or use FBUS Flashing
    Booting/Flashing Failed...
    Please Try Again...
  2. 22/2/17 lúc 10:41
    Monday
    Monday
    8800e1.
    Chỉnh sửa cuối: 25/2/17
    vietduc2011 thích bài này.
  3. 25/2/17 lúc 15:32
    vietduc2011
    vietduc2011
  4. 25/2/17 lúc 16:47
    Monday
    Monday
    Chọn file rồi flash thôi, chọ speed như hình
    nhớ là 8800e nha, hình mình quên để ý model máy
  5. 26/2/17 lúc 20:33
    QuangLinh Mobile
    QuangLinh Mobile
    lắm con ổ cứng cà tưng flash phát ngỏm luôn . làm chân đóng lại flash lại mối lên
