con nay ko bỏ sim thì vào trong đc ;nhưng bỏ sim vào báo hạn chế điện thoại :em đả flash bằng atff nhưng ko hết bệnh đây là log em nó anh em xem giùm thanks ;nó chạy lâu ác :giờ mà vẩn con chạy Number of Image Files: 3 Processing Image File : rm614__08.71.mcusw CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 528 Entry Point: 0x01F2 Page Format : -1 MAX PAGE : 0x0000E000 Processing Image File : rm614__08.71.ppm_v CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 125 Entry Point: 0x0113 Page Format : -1 MAX PAGE : 0x0000E000 Processing Image File : rm614__08.71.image_v_059G6Z2 CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 238 Entry Point: 0x0147 Page Format : -1 MAX PAGE : 0x0000E000 AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 READING BOOTROM BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 86 (0x56) bytes returned Number of Sub Blocks 6 (0x06) 1 SYSTEM_ASIC_ID 01 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000000 ID DWORD 1 : 00000000 ID DWORD 2 : 22000509 ID DWORD 3 : 200C0000 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00005361 3 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000000 ID DWORD 1 : 002DD49B ID DWORD 2 : C902D5FB ID DWORD 3 : 67356804 ID DWORD 4 : 00344684 4 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 5 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 1B 0D 74 C5 32 CA 1C 61 33 94 0C 74 0E 8C 78 6E 6 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : DE56D582 CRC 1 : BDDE7A3A CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\BCM21351_usb2nd.fg Secondary Loader Sent.... MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0010 -> Device ID : 0011 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0030 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0431 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : XSR 1.6 SearchForBootstrap_DCT5 : No Error - 0 (0x00) Flash Descriptor Manufacturer Code : 00EC Device ID : 0030 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 08000000 (128 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\BCM21351_XSR16_usbalg.fg Algorithm Loader Sent... FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok START READING RPL DATA IMEI: 355933045183681 Reading : NPC... OK! Reading : CCC... OK! Reading : HWC... OK! Reading : R&D... OK! NPC CERTIFICATE INFORMATION (CMT): IMEI : 355933045183681 PRODUCT CODE : 059B7D2 WLAN ID : 9C:4A:7B:B3:AE:ED BLUETOOTH ID : 9C:4A:7B:B3:70:6C PUBLIC_ID : 00000000002DD49BC902D5FB6735680400344684 PAPUB_KEYS_HASH: 697F747788AD72E77DB3BC8DFEC0C28DA22F16D8 CCC CERTIFICATE INFORMATION (CMT): PRODUCT CODE : 059B7D2 HWC CERTIFICATE INFORMATION (CMT): PUBLIC_ID : 00000000002DD49BC902D5FB6735680400344684 PRODUCT CODE : 059B7D2 RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\355933045183681\355933045183681_45022.rpl PA PUBLIC KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: 697F747788AD72E77DB3BC8DFEC0C28DA22F16D8 Reading : ISA-USER... OK! ====================================================== PHONE FIRMWARE VERSION: V 08.71 15-11-11 RM-614 (c) Nokia ====================================================== ImagePath: C:\Users\Admin\Desktop\C3-00 RM-614 v08.71 ppm_v Full\ ImageFilename: rm614__08.71.mcusw Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) Certificate 1 Name : NPC ASIC Index : CMT 0 Certificate 2 Name : CCC ASIC Index : CMT 0 Certificate 3 Name : HWC ASIC Index : CMT 0 Certificate 4 Name : RND ASIC Index : CMT 0 Certificate 5 Name : R&D ASIC Index : CMT 0 STORE_CERTIFICATE_REQUEST_BB5 : 61 05 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 4E 44 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 B6 STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 00000004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 RO Start Address : 00020000 Size : 025E0000 Partition 2 ID : 00000008 FILESYSTEM Attribute : 00000001 RW Start Address : 02A00000 Size : 04B40000 Partition 3 ID : 0000000A PMM Attribute : 00000001 RW Start Address : 07540000 Size : 00600000 Partition 4 ID : 0000000B Attribute : 00000001 RW Start Address : 07B40000 Size : 00180000 PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF00000004000000030000000200020000025E0000000000080000000102A0000004B400000000000A0000000107540000006000000000000B0000000107B40000001800000D PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) StartErase_DCT5... BlockLength : 0x90 (144) ERASE Blocks : 0x03 (3) 0 ERASE_AREA_BB5 0x12 Block Length : 0x2B (43) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 00000000-0001FFFF 1 : 00020000-000203FF 2 : 00060000-012FFFFF 3 : 01300000-01DFFFFF 4 : 02600000-029FFFFF 1 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x02000000 Format Info : 000000000000000A0000000100000002000000640000000200000002000000010000000000000000 2 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x02000000 Format Info : 000000000000000B0000000000000002000000640000000200000002000000010000000000000000 ERASE_REQUEST_BB5 : 5005120B000300000000000001FFFF120B00030000020000000203FF120B00030000060000012FFFFF120B0003000130000001DFFFFF120B00030002600000029FFFFF11 FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000A00000001000000020000006400000002000000020000000100000000000000003B FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000B00000000000000020000006400000002000000020000000100000000000000003B Successfully Erased... Total blocks to write : 528 >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : ADA >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : RAP3NAND >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS [697F747788AD72E77DB3BC8DFEC0C28DA22F16D8] >> CMT Rootkey Hash CERT : UPDAPP >> CMT Rootkey Hash CERT : MCUSW >> CMT Rootkey Hash CERT : MCUSW1 >> CMT Rootkey Hash CERT : GENIO_INIT >> CMT Rootkey Hash CERT : ISA+DYNSW ImagePath: C:\Users\Admin\Desktop\C3-00 RM-614 v08.71 ppm_v Full\ ImageFilename: rm614__08.71.ppm_v StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 01E00000-025FFFFF ERASE_REQUEST_BB5 : 5001120B00030001E00000025FFFFF9E Successfully Erased... Total blocks to write : 125 ImagePath: C:\Users\Admin\Desktop\C3-00 RM-614 v08.71 ppm_v Full\ ImageFilename: rm614__08.71.image_v_059G6Z2 StartErase_DCT5... BlockLength : 0x3F (63) ERASE Blocks : 0x02 (2) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 02A00000-0753FFFF 1 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x02000000 Format Info : 00000000000000080000000000000002000000640000000200000002000000010000000000000000 ERASE_REQUEST_BB5 : 5001120B00030002A000000753FFFFE4 FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000800000000000000020000006400000002000000020000000100000000000000003E Successfully Erased... Total blocks to write : 238 ContinueFlash_DCT5 Complete Continue Flash Complete : : No Error - 0 (0x00) STATUS_REQUEST_BB5... 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000002 Additional Bad : 00000002 Correctable ECC : 00000000 FlashInfo.RestartMode : 2 Flashing Done... Total Flashing Time (Erase + Flashing) : 00:00:14 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 150 seconds)
log atf dài quá nhìn nản thật,nhìn log không thấy simlock nằm đâu hết,nghi banh simlock rồi,repair bằng bằng atf xem sao
