nhà chỉ có hwk với tool free thôi, đây là log chạy bằng hwk imeil vẩn còn Insert USB Cable to Switched OFF Phone and Power ON USB BOOT : 56,06 [Rm-614] [2.3.0.3] CMT ASICID: 000000000000000022000509200C0000 EM 1 ID : 00005361 CMT PUBID : 0000000000D7EF6DEE6D401D4C2825CC34D967C9 CMT MODE : 00 CMT HASH : 1B0D74C532CA1C6133940C740E8C786E CMT ROMID : DE56D582BDDE7A3A CMT 2ND Bt: BCM21351_usb2nd.fg, Ver: 11.34.0 CMT RMID0 : 00000000-00000000 CMT MCID0 : FFFF0000-00000000 CMT FLID0 : 00EC0030-00000431, Sam OneNAND-1G CMT RQALG : XSR 1.6 CMT 2ND Boot OK CMT ALGO : BCM21351_XSR16_usbalg.fg, Ver: 11.34.0 CMT KSIG0 : 697F747788AD72E77DB3BC8DFEC0C28DA22F16D8 CMT ALG Boot OK PASUBTOC : PA_SIMLOC30 Rebooting Mobile Set UI Defaults ... Insert USB Cable to Switched OFF Phone and Power ON USB BOOT : 56,06 [Rm-614] [2.3.0.3] CMT ASICID: 000000000000000022000509200C0000 EM 1 ID : 00005361 CMT PUBID : 0000000000D7EF6DEE6D401D4C2825CC34D967C9 CMT MODE : 00 CMT HASH : 1B0D74C532CA1C6133940C740E8C786E CMT ROMID : DE56D582BDDE7A3A CMT 2ND Bt: BCM21351_usb2nd.fg, Ver: 11.34.0 CMT RMID0 : 00000000-00000000 CMT MCID0 : FFFF0000-00000000 CMT FLID0 : 00EC0030-00000431, Sam OneNAND-1G CMT RQALG : XSR 1.6 CMT 2ND Boot OK CMT ALGO : BCM21351_XSR16_usbalg.fg, Ver: 11.34.0 CMT KSIG0 : 697F747788AD72E77DB3BC8DFEC0C28DA22F16D8 CMT ALG Boot OK IMAGE : rm614__08.71.mcusw CMT NAND Erase Area: 0x00000000-0001FFFF CMT NAND Erase Area: 0x00020000-000203FF CMT NAND Erase Area: 0x00060000-012FFFFF CMT NAND Erase Area: 0x01300000-01DFFFFF CMT NAND Erase Area: 0x02600000-029FFFFF CMT NAND Partition Format CMT NAND Partition Format CMT FLASH ERASE OK, Time: 00:00 Written: 11 Certificate(s) CMT FLASH WRITE OK, Time: 00:29 IMAGE : rm614__08.71.image_v_059G6Z2 CMT NAND Erase Area: 0x02A00000-0753FFFF CMT NAND Partition Format CNT FLASH ERASE OK, Time: 00:01 CNT FLASH WRITE OK, Time: 00:14 IMAGE : rm614__08.71.ppm_v CMT NAND Erase Area: 0x01E00000-025FFFFF PPM FLASH ERASE OK, Time: 00:00 PPM FLASH WRITE OK, Time: 00:07 Flashing Completed, Rebooting Mobile
CMT RMID0 : 00000000-00000000 CMT MCID0 : FFFF0000-00000000 lỗi này hwk thì bó tay, chỉ có atf thì nhanh
còn IMEI thì banh simlock , ko có backup thì ATF cũng nhè , kèo này dính phốt thì mua máy cũ thay cho khách thôi .
