Mua Bell & Ross BR 03 WHITE CERAMIC BR0392-WH-C/SCA
Thảo luận trong 'ĐIỆN TỬ - ĐIỆN LẠNH - ĐIỆN GIA DỤNG.' bắt đầu bởi anyick, 25/3/23.
    anyick (Offline)
    Hải Phòng
    245,000 (VNĐ)
    Ship COD
    23659874 Click để xem
    Gửi 25/3/23, 0 Trả lời, 399 Đọc
  1. 25/3/23 lúc 18:36
    anyick
    anyick
    A Replica Bell & Ross Watches That Looks Like an Airplane Radar
    Fasten your seat belt and make sure your seat and tray table are in a fully upright position.
    Everyone has their own opinion about Bell & Ross. It's the brand you get or don't. No matter which side you're on, you can't deny that it's become a signature style. The B&R aesthetic is somewhere between military-inspired and industrial-style – resulting in (often) blacked-out square cases with highly legible, functional dials.best replica watch site
    Yesterday, the brand unveiled a new — but familiar — BR-0392 Red Radar watch, a 42mm numeral with the recognizable Bell & Ross case design. The first iteration of the piece debuted at Baselworld in 2011 and was one of the most surprising launches of the year. Ten years later, the brand introduced a black ceramic model with a dial reminiscent of a real aircraft control radar. The time is read by a system of rotating discs and analog hands, all hidden in a red sapphire crystal.
    They say being an aircraft controller is the hardest job in the world - I have to think part of the difficulty is learning to read radar displays and react accordingly. Looking at this watch, if you don't know, you might think it's just a flying radar attached to a rubber strap. But it actually underscores what makes this product so interesting. You see, Bell & Ross is using a very basic movement with a BR-CAL.302 (Selitta-SW300-1 base). This is a standard off-the-shelf movement modified by the brand. That's what a lot of companies say - modified. But what exactly does that mean? In this case, a lot.
    What B&R did was develop a disc system and mount it to the movement itself. This gives the dial a creative and wild look. Even the brand calls it a "watchmaking UFO". But it's not the first time the base movement has been bumped up to this level, even using a puck system to achieve a unique-looking display -- but it's just as cool every time. I have to think there is a learning curve in telling this time.replica watches for sale
    Red crystals, an all-ceramic case, rubber strap and 100-meter water resistance make this watch wearable in almost any situation. Next time you're at the airport, you can jump into the tower and say, "Hey guys, I get it."
    Base
    Brand: Bell & Ross
    Model: BR-0392 Red Radar
    Diameter: 42 mm
    Case material: matte black ceramic
    Dial color: red
    Scale: painted in red
    Water resistance: 100 meters
    Strap/Bracelet: Rubber Strap
    sports
    Caliber: BR-CAL.302
    Functions: hours, minutes, seconds
    Diameter: 25.6mm
    Power Reserve: 38
    Winding: automatic
    Frequency: 4Hz
    Number of Gems: 25
    Certified Chronometer: No
    Bell & Ross BR V2-94 Full Lum
    Lum is the word.
    Following in the footsteps of the recently launched BR 03-93 GMT, Bell & Ross has released its latest luminous experiment. Using a now relatively familiar case design and configuration (styled through the Vintage line of chronographs in the basic BR V2-94 design), the new BR V2-94 Full Lum still presents a fresh look with its contrasting Super-LumiNova. The watch is a follow-up to 2020's big light new arrivals, most notably the BR 03-92 Diver Full Lum and the BR03-92 HUD Limited Edition, the former of which, like today's model, also uses a lume in a variety of contrasting colors to produce its namesake" Full Lum" appearance.replica luxury watches
    While not as significant as the brand's first bezel-bezel, square-shaped GMT, it does show Bell & Ross's commitment to color options uncommon in its larger catalog and the use of high-brightness, contrasting dials to create these unique offerings continued interest in color matching. The model joins an already diverse range of watches currently offered in the V2-94 collection and in the larger Vintage collection produced by the brand. While it may seem out of place to outsiders, it fits perfectly with the rest of Bell & Ross' work.
    Looking closely at its details, we first see a familiar case profile, as seen in other V2-94 chronographs. With a case diameter of 41 mm and a water resistance of 100 meters, with tapered lugs, screw-down push buttons and a fixed bezel with anodized black inserts, it feels like a solid dive chronograph dedicated to A classic reinvention in tool watch format.Replica Richard Mille Felipe Massa
    As for the straightforward look of the case, once we get under the domed anti-reflective coated sapphire crystal, we see the true star of the watch. The dial is completely painted in fluorescent green, giving the surface a bright, eye-catching style even in good light. Then, when low-light conditions are introduced, the style really shines, with the black paint contrasting bright Super-LumiNova green. Reading the time is an exercise in heightened clarity, accentuated by the small numerals – but most notably the 30-minute chronograph sub-dial at 9 o’clock – with a contrasting luminous colour.
    As for other details that are not so bright, the configuration of the dial is in line with the brand's previous V2-94 chronograph, with oversized Arabic numerals on the top and bottom of the dial, and the other two quarters of the main sub-dial hour position, 4:30 position The small non-luminous date window, and the aviation-inspired hands in the center of the dial. It might be interesting for Bell & Ross to add a non-green element, perhaps in a red-tipped second hand or something like a line, but the brand may have decided the look was sharp enough and kept it.
    As for its movement, Bell & Ross stuck with the standard BR-CAL.301 they use in the collection (which is based on the ETA 2894-2 and offers a 42-hour power reserve). Like the mechanism used in previous releases of Greenwich Mean Time (GMT), this automatic chronograph movement helps to provide the watch with easy-to-service, practical mechanical power, helping to focus attention on the highly luminous function of the wearer.replica Jacob & Co. Astronomia Casino
    Base
    Brand: Bell & Ross
    Model: BR V2-94 Full Lum
    Diameter: 41 mm
    Thickness: 13.55mm
    Case Material: Steel
    Dial color: luminous green
    Index: Illuminated in all 12 positions, Arabic at 6 o'clock and 12 o'clock
    Lume: Come on.
    Strap/Bracelet: Black Rubber
    sports
    Movement: ETA 2894-2 / BR-CAL.301
    Functions: Hours, minutes, seconds, date, chronograph seconds, 30-minute chronograph
    Power reserve: 42 hours
    Winding: automatic
    Frequency: 28,800 vph
