ARBUTUS AR3 PLUS Xóa FRP By Miracle
Thảo luận trong 'CÁC DÒNG ANDROID KHÁC' bắt đầu bởi thanhnamPDAviet, 23/5/17.
  1. 23/5/17 lúc 08:31
    thanhnamPDAviet
    thanhnamPDAviet
    Xóa Xác Minh Gmail FRP ARBUTUS AR3 PLUS By Miracle
    Tags:ARBUTUS AR3 PLUS FRP,ARBUTUS AR3 PLUS Xác Minh Gmail,ARBUTUS AR3 PLUS ByPass,
    Mã:
      Welcome to use Miracle Box
     (World's First Fuzzy Logic Based Tool)
      Update:16-01-09
      Connected OK.
      Check Authentication...
      Check the new version.
      Fuzzy Logic Method is very safe and reliable !
      Definition Applied
      1. Power Off Phone , Remove Battery, Insert Battery Back
      2. Insert USB cable. In some cases Required Hold BootKey
      3. Use Miracle Boot Key In cases Boot key not Find
      4. Battery Should be Charged more then 50%
      Waiting for USB Port...
      Set MediaTek PreLoader USB VCOM Port (COM4)
      Please Hold "ON" to connect with the phone...
      Connected to Phone.
      CPU: MT6580 SW:0000 Ver: CA00
      Downloading Boot8 ...
      EMMC Size: 0x03AB400000
      Flash Type: EMMC
      INT/EXT RAM  Size: 0x0+0x0
      Reset Setting...
    >>Done.(Need to wait a few minutes the phone is switched)
