Alcatel Onetouch 2045X unlock ok
Thảo luận trong 'SỬA CHỮA PHẦN MỀM.' bắt đầu bởi Thienbaogsm, 12/3/17.
  1. 12/3/17 lúc 12:58
    Thienbaogsm
    Thienbaogsm
    Searching phone;
    Phone detected (@oem50.inf,%vcom_bootrom%;MediaTek USB Port)
    Preparing to start meta mode;
    COM opened ok;
    Phone must be powered off;
    Keep pressing the power button if serial used !
    (for USB connection keep SPACE or * (STAR) key pressed and insert the usb cable)
    Connecting;
    Meta mode entered;
    Baseband Chip: MT6276
    Sw version: 2045X_L2EN_V1.5_160712_CAM30_MCP128_64_FM_BT_AU_OPTUS
    Hw Version: HW01
    Reading phone info;
    IMEI: 351530-08-112530-5
    Reading simlock info;
    Unlock codes:
    Locked to: 505-02
    code_cat_n: 25139863 enabled: yes tries: 3
    code_cat_ns: 56781234 enabled: no tries: 5
    code_cat_sp: 11112222 enabled: no tries: 5
    code_cat_c: 33334444 enabled: no tries: 5
    code_cat_sim: 55556666 enabled: no tries: 5
    code_cat_ns_sp: 77778888 enabled: no tries: 5
    code_cat_sim_c: 99990000 enabled: no tries: 5
    Time needed - 00:00:16
  2. 4/6/17 lúc 11:14
    duyrin
    duyrin
    có tool crack unlock con alcatel 2045x cho em xin với anh? thank a nhiu đang có con ko unlock được a
  3. 12/7/18 lúc 18:01
    tanmobile4437
    tanmobile4437
    Có file unlock ko em đang cần
