Alcatel 5044T Unlock Network By CM2
Thảo luận trong 'CÁC DÒNG ANDROID KHÁC' bắt đầu bởi thanhnamPDAviet, 21/11/17.
  1. 21/11/17 lúc 08:33
    thanhnamPDAviet
    thanhnamPDAviet
    Alcatel 5044T Unlock Network Via Teamviewer
    Mã:
    @thanhnamPDAviet
    Operation : SP Unlock [ v1.58 ]
    Mode : Direct Unlock
    1. Power Off Phone , Remove battery , Insert back
    2. Insert USB cable. In some cases require hold BootKey
    Wait for phone...
    Phone found! [ 42 ]
    Sync...
    Inital Boot Ok!
    BB_CPU_PID : 6737
    BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00
    BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
    Processing BROM stage
    Settings for BROM configured!
    SecCfgVal : 0x00000000
    BromVer   : 0x00FF
    BLVersion : 0x0001
    PreLoader : Active [ Boot with PL ]
    BootLdrSS : NORMAL with PRELOADER
    Processing DA stage
    DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07
    Sending and initialize DA ...
    Running DA ver.4.2 on BBID : 0x93
    NAND Flash : NOT INSTALLED
    eMMC Flash : 484A019061344738CA4EA53281B9E682
    Initialize Memory ...
    DRAM already initialized by Preloader
    DAgent sent , init HW now
    eMMC FlashIC initialized
    [eMMC] : FLASH_VEN : 0x90 , OEM : 014A
    [eMMC] : FLASH_INF : [HYNIX] , 2a4G8
    [eMMC] : FLASH_CID : 90014A483847346132A54ECA82E62481
    [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000
    [eMMC] : FLASH_LEN : 0x00000001D2000000
    [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
    DEV RID	: 0xF85F4F29BBF896B705244054CA9A699C
    INT RAM	: 0x00020000
    EXT RAM	: 0x40000000 [1 GiB]
    BOOT TYPE  : EMMC_FLASH_BOOT
    SOC VERIFY : C1
    Boot Ok!
    SIM Lock Status : Locked!
    Unlocking now ...
    Unlock done!
    Done!
    Elapsed: 00:00:29
    Reconnect Power/Cable!
