ae xem giúp e
Thảo luận trong 'SỬA CHỮA PHẦN CỨNG.' bắt đầu bởi hoanglong89, 11/4/15.
  1. 11/4/15 lúc 09:30
    hoanglong89
    hoanglong89
    [Xin giúp] ae xem giúp log 1202
    như tiêu đề ae xem giúp e xem máy bị sao ạ
    thaks ae
    ImageFile:\SOFTWARE\NOKIA\1202 RH-112\1202 RH-112 v4.03ppmMR\rh112_004.030
    PhoneType : DCT4
    Algorithm : DCT4 ALGORITHM
    Supported Hardwares :
    > 2293
    Secondary Sending Speed : 100000Hz
    Algorithm Sending Speed : 6500000Hz
    Program Sending Speed : 6500000Hz
    Message Reading Speed : 51000Hz
    Number of Blocks : 148
    Entry Point: 0x00E7
    Is128k: True
    Boot Check, Please wait...
    MCUID Response
    MessageID : 92
    msbUPP_ID : 22
    lsbUPP_ID : 93
    Boot OK
    Boot File: C:\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\u3_2nd.fia
    DataLen : 000009D8
    Secondary Loader Sent...
    Boot OK!
    MCU_CONFIGURATION_RESPONSE_DCT4_MUL3
    DCT4 Mess 9F MUL3 Mess 9F
    TransMode : 03
    NumFlash : 02
    DevAddr0 : 01
    ManuId0 : 0020 - ST
    DevId0 : 8828 - Type not in database
    ExtId0 : 0000
    RevId0 : 0321
    SectorSize0: 10
    Reserved0 : 00
    DevAddr1 : 02
    ManuId1 : 0000 - Flash
    DevId1 : 0001 - not used
    ExtId1 : 0000
    RevId1 : 0000
    SectorSize1: 00
    Reserved1 : 00
    ExtBUSC : AD 7E B6 1A 23 10 03 40 C6 05 E4 01 20 A2 65 14
    CheckSum : 96
    ReceiveConfigurationResponse_DCT4 - FLS1_NO_ERROR
    SearchForBootstrap_DCT4 : No Error
    Algo Match File : C:\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\u3_st_i.fia
    ALGO SENT..
    Perform AUTHENTICATION..
    MSID: 84EBB7F0A80DD1E19D804E85FC
    DecodedMSID: 843E4EBAE900863371A9000000
    EncodedFAID: D3C02CBE47A8CE74BD1F5658
    Authentication : SUCCESSFULL
    Erasing address:
    >> 01000000 : 0100FFFF
    BB_PROGRAMMING_STATUS_REQUEST : 04 FF
    ProgrammingStatus_DCT4 : No Error - 0 (0x00)
    >> 01010000 : 013AFFFF
    >> 013B0000 : 013EFFFF
    >> 017C0000 : 017EFFFF
    >> 01FC0000 : 01FEFFFF
    Erasing Done
    Flashing ImageFile
    Data Corruption Detected...
    Attempting to Rewrite Block
    FAILED..
    Flashing FAILED...
    Flashing ERROR
  2. 11/4/15 lúc 09:32
    hoanglong89
    hoanglong89
    check thoải mái nhưng ko factory và chạy đc ạ các cao nhân cho e xin ý kiến với
  3. 11/4/15 lúc 09:34
    thanhtu04081982
    thanhtu04081982
    máy mất nguồn do mất data lổi flash........anh sài fbux hay cáp vậy
  4. 11/4/15 lúc 09:46
    hoanglong89
    hoanglong89
    fbbus a ơi nếu dùng cáp đa năng hay ôp lưng tốt hơn hả a
  5. 11/4/15 lúc 10:46
    thanhtu04081982
    thanhtu04081982
    anh vệ sinh và khò nóng con u và flash thử
  6. 11/4/15 lúc 13:03
    hoanglong89
    hoanglong89
    thanks a chắc chết cặp rồi
  7. 11/4/15 lúc 13:46
    hop iphone
    hop iphone
    đống lại cái cặp cho nó ,
