ae xem dùm em cái look e63
Thảo luận trong 'SỬA CHỮA PHẦN CỨNG.' bắt đầu bởi mrthang39, 3/1/15.
  1. 3/1/15 lúc 09:54
    mrthang39
    mrthang39
    MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C086F250
    Using device: USB ROM and HTI, FW ver: 00.50, SN: 010056B0
    Connection status: UHCI:HUB::USB 2.00 (Full-speed)
    Driver: NMWCD, ver: 7.1.32.117
    Module ver: 1.0.0.21762(03-12-2014), Library ver: 1.0.0.14473(03-12-2014)
    Processing MCU file: rm437_510.21.010_prd.c00
    [BB5,XSR 1.5] size: 63.43 MB
    Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 000C192101011103, 0003192101011103, 400C192101011103, 4003192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103
    Make sure USB cable, Battery and charger are removed from device.
    Insert USB cable, Battery back to device(make sure to have fully charged battery).
    Insert Charger or Press phone's power button(if flashing doesnt start automatically)
    Waiting for USB ROM device ...
    Device connected: nmwcdnsuc\Nokia USB Flashing Generic (), PORT_ID: 2677AE7B
    CMT SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13]
    CMT EM0 ID: 00000296
    CMT EM1 ID: 00000B22
    CMT PUBLIC ID: 0E20020EEE960158CEA63E00D692F8426B4E1A68
    CMT ASIC MODE ID: 00
    CMT ROOT KEY HASH: 9A28E119033B91D14D22838C86D0D53C
    CMT ROM ID: 4B9B75103E691FF8
    Loading CMT secondary boot code
    SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.14.0 revision: 2.0 size: 0x3B80
    Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
    eBB5ProtocolType: NEW
    Secondary boot loaded.
    Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
    Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
    Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
    Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
    Storage4: 00EC 0040 - 0000 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT
    Suggested algorithm: XSR 1.5
    Loading CMT update server data
    Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.14.0 revision: 2.0 size: 0x8798F
    Update server code loaded.
    FUR: Adding Asic CMT as client OK.
    CMT PAPUBKEYS is blank/erased.
    Storing certificate [NPC, CCC, HWC, R&D] ...OK
    Partitioning....
    Partitioning complete
    Erase size: 122.56 MB
    CMT FLASH,MuxOneNAND area [00040000-007FFFFF]
    CMT FLASH,MuxOneNAND area [00A00000-0759FFFF]
    CMT FLASH,MuxOneNAND area [0F1C0000-0F8BFFFF]
    Formating partition ...
    Flash programming ...
    CMT ADA block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT RAP3NAND block sent
    CMT PASUBTOC block sent
    Selecting first CMT PAPUB block with matching RootKey.
    CMT PAPUBKEYS: D9C25399 [RAP Certificate 137 v.1] sent
    CMT SOS*UPDAPP block sent
    CMT SOS*DSP0 block sent
    CMT SOS*ISASW block sent
    CMT SOS*CORE block sent
    CMT SOS+ROFS block sent
    Programming completed in 17 min 48.547 s
    Processing PPM file: rm437_510.21.010_prd.v29
    [BB5,XSR 1.5] size: 22.51 MB
    Erase size: 33.56 MB
    CMT FLASH,MuxOneNAND area [05420000-0759FFFF]
    CMT SOS+ROFX block sent
    Programming completed in 6 min 31.891 s
    Processing CNT file: RM437_ENO_008.07.45_100.71.952.a018.fpsx
    [BB5,XSR 1.5] size: 1.54 MB
    Erase size: 64 KB
    APE SOSENO
    CMT SOS*ENO block sent
    Programming completed in 26.813 s
    Total time for flashing process(boot+erase+write) was 25 min 16.563 s
    Waiting for USB device removal ...OK
    Waiting for USB device arrival ...
    Waiting for device boot up ...
    Phone not found, retrying ...
    Warning: Phone did not reboot to normal mode.
  2. 3/1/15 lúc 11:15
    truongtiendat
    truongtiendat
    bạn ko bít tiếng anh chuyểng sang google dịch . để bít gõ hơn
  3. 3/1/15 lúc 11:27
    Xuân Toàn
    Xuân Toàn
    máy bị sao vậy,log hình như ko đồng bộ đc, thử dùng cáp đa năng xem sao bác
