A830L repair emmc done
Thảo luận trong 'CÁC DÒNG ANDROID KHÁC' bắt đầu bởi SoDepHungYen, 21/10/15.
  1. 21/10/15 lúc 12:45
    SoDepHungYen
    SoDepHungYen
    Treo đỏ thôi mà nạp các kiểu , PDL ... không vào , đành phải tụt quàn chịch em nó mấy nhát :D mới chịu dậy
    Mã:
    Loading eMMC Addon Firmware... IO: 2800 mV
    Box S/N: 18xxxx, ,FW Ver.: 01.52
    CMD Pullup Level:1701 mV
    CMD Active Level:2237 mV
    eMMC Device Information
    EMMC CID : 1501004D4147324741061000176F4F8E
    EMMC CSD : D02701320F5903FFF6DBFFFF8A404006
    EMMC Manufacturer ID: 0015 , OEM ID: 0100
    EMMC Date: 04/2012 Rev.0x6
    EMMC NAME: MAG2GA , S/N: 268441455
    EMMC NAME (HEX): 4D414732474100
    EMMC ROM1 (Main User Data) Capacity: 14910 MB
    EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB
    EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB
    EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB
    EMMC Permanent Write Protection: No
    EMMC Temporary Write Protection: No
    Extended CSD rev 1.5 (MMC 4.41)
    Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured.
    Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00.
    H/W reset function [RST_N_FUNCTION]: 0x00
    Backup saved: MAG2GA_ 268441455_20150903_1117.extcsd
    Done.
    Running:SAMSUNG: MoviNAND Reset + Format...
    Z3X EasyJtag Software ver. 2.0.5.0
    Skip loading eMMC Addon Firmware
    EMMC ROM2/3 (Boot Partitions) Capacity: 2048 kB
    Sending Internal Reconfiguration Request...
    Waiting configuration Apply!
    Restoring configuration...
    Wiping Card... Please do not touch it!
    Please don't forget to repair extCSD from backup!
    Done.
    extCSD file...C:\Program Files\Z3X\EASYJTAG\Backups\MAG2GA_ 268441455_20150903_1117.extcsd
    Running:Repair extCSD...
    Writing...
    Done.
    Checking NAND Image : D:\MOBILE\FULL DUMP\SKY\A830L\A830L-512.bin
    File successefuly loaded!
    Processing file...D:\MOBILE\FULL DUMP\SKY\A830L\A830L-512.bin
    ROM2 Are not selected , skip writing ROM2
    Input file : D:\MOBILE\FULL DUMP\SKY\A830L\A830L-512.bin
    Writing 0020000000 bytes to 00000000 ...ROM1 (USER ROM)
    Done. Write Speed: 755 kB/s
  2. 21/10/15 lúc 12:52
    crackmobile
    crackmobile
    830l chỉ hay nhận treo logo vega mà phải nã em nguồn mới ok thôi
  3. 21/10/15 lúc 12:55
    SoDepHungYen
    SoDepHungYen
    con này treo đỏ , nạp PDL ko vào % , nạp các kiểu ko si nhê
