ae xem giúp lỗi j Connecting to the dead body...OK Detected dead body ID: 0x406B10E1 - CORRECT! Set I/O Voltage reads as 1.81V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0000 (MAG2GA, 0x0003A3E00000 Bytes = 14.56 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0000 (MAG2GA, 0x000000200000 Bytes = 2.00 MB) Flashing the dead body... ERROR: Timeout while waiting for DCC Loader response. Trying to recover...
Box nhận chip đầy đủ, nạp lỗi thì xác định emmc tèo, thử hạ tốc độ thấp xuống xem sao, không được thì làm HW.
làm tới làm lui giờ lỗi này mod ơi,ko thấy chip đâu hết trơn Connecting to the dead body...OK Detected dead body ID: 0x406B10E1 - CORRECT! Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box.
