3110c contacseve
Thảo luận trong 'SỬA CHỮA PHẦN CỨNG.' bắt đầu bởi thanh_ninhhoa, 6/3/15.
  1. 6/3/15 lúc 14:15
    thanh_ninhhoa
    thanh_ninhhoa
    a e xem long giúp e phát
    MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 1], SN: C0841345
    Using device: HTI, FW ver: 00.24, SN: 00010920
    Connection status: UHCI:HUB:USB 2.00 (Full-speed)
    Driver: WinUSB, ver: 3.5.1.0
    Module ver: 1.0.0.21762(03-12-2014), Library ver: 1.0.0.14473(03-12-2014)
    CMT Data :
    SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAP3G ver: PA 1.x]
    EM0 ID: 00000232
    EM1 ID: 00000353
    PUBLIC ID: 292001185E9B7B5665DE19347ACAD0E709EC9999
    ASIC MODE ID: 00
    ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
    ROM ID: 191EC665DFAAF68F
    SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00
    Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
    eBB5ProtocolType: OLD
    Storage0: 0089 8981 - 0000 6A21 [Intel NU48F256,256 Mbits] type: FLASH,NOR, asic:CMT
    Storage content: 0000 0000 0000 0000 0000 0000 0000 0000
    Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
    TransmissionMode: 16Bit
    Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010
    Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
    CMT PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D
    TransmissionMode: DDR&TX2
    Original Imei: 35681502292876
    Original Product code: 0552795
    Bluetooth ID: 0022FCFA65EB
    SIMLOCK PA identifier:
    [0] PA_SL
    Phone type: RM-237 (Nokia 3110c)
    SW version: V 07.30 07-05-09 RM-237 (c) Nokia.
    Imei plain: 35681502292876-7
    Product code: 0544304
    Battery voltage: 4611 mV, current: 65 mA
    Language Pack:
    - not available.
    SLPA ver[1]: PA_SL (15 digit NCK)
    SIMLOCK seems to be valid
    SUPERDONGLE_KEY[MX] seems to be valid
    SIMLOCK_TEST passed
    SECURITY_TEST failed!
    Imei net: 356815022928767
    Version: SIMLOCK SERVER VERSION 63
    Counter: 0/3, 0/10
    CONFIG_DATA: 2440700000000000
    PROFILE_BITS: 0000000000000000
    BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
    BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
    BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
    BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
    BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
    BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
    BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
    e write pm bỏ 308 củng vậy lâu quá không đụng tới nên ... xin a e giúp e phát
  2. 6/3/15 lúc 14:17
    CuDuy-VF
    Super Moderator
    CuDuy-VF
    Write pm1-309 đi .
  3. 6/3/15 lúc 14:18
    gadumobile
    gadumobile
    SIMLOCK_TEST passed
    có mx key không a hay atf viết pm file1 và 309 xong repai là ok
  4. 6/3/15 lúc 14:26
    thanh_ninhhoa
    thanh_ninhhoa
    e Write pm1-309 va Repair simlock rồi củng như vậy a ơi
  5. 6/3/15 lúc 14:34
    CuDuy-VF
    Super Moderator
    CuDuy-VF
    Write lại pm 1-309 song quăng cái log lên đây
  6. 6/3/15 lúc 14:37
    ThienTran_GSM
    ThienTran_GSM
    sx4 xong wite pm cái là ok mà :D
  7. 6/3/15 lúc 14:41
    CuDuy-VF
    Super Moderator
    CuDuy-VF
    Còn tuỳ em , nhiều cây nó cứng đầu lắm , phải táng cái rpl without_NPC_DATA nó mới chịu
  8. 6/3/15 lúc 14:43
    thanh_ninhhoa
    thanh_ninhhoa
    đúng cứng đầu thiệt a dần nó một hồi củng ok chạy lại và Write pm1-309 ok rồi cảm ơi a nhiều
