2700s flash bằng ATF chết
Thảo luận trong 'SỬA CHỮA PHẦN MỀM.' bắt đầu bởi sn0w, 8/3/16.
  1. 8/3/16 lúc 11:02
    sn0w
    sn0w
    em đang sử dụng ATF mỗi khi flash ok hôm nay update lên v12.67 lôi con 2700c ra test thì flash chết ngỏm ,lôi thêm con nữa ra flash nữa cũng ngỏm luôn , em lôi bestdongle ra nạp cũng not ok anh em xem lock giúp với
    lock này của ATF
    Number of Image Files: 3
    Processing Image File :
    rm561__09.97.mcusw
    CMT Type : BB5
    CMT Algorithm : BB5 ALGORITHM
    Secondary Sending Speed : 3250000Hz
    Algorithm Sending Speed : 6500000Hz
    Program Sending Speed : 6500000Hz
    Message Reading Speed : 98000Hz
    Number of Blocks : 1256
    Entry Point: 0x5047
    Page Format : -1
    MAX PAGE : 0x00004000
    rm561__09.97.ppm_v
    CMT Type : BB5
    Number of Blocks : 442
    Entry Point: 0x00B6
    Page Format : -1
    rm561__09.97.image_v_red
    CMT Type : BB5
    Number of Blocks : 872
    Entry Point: 0x00C8
    Page Format : -1
    AUTO SELECTED DEAD USB FLASHING...
    If Phone Booting does not Start in 5 Seconds,
    Then Perform Steps 1, 2, 3 and 4...
    1. Remove USB and Battery...
    2. Insert USB.
    3. Insert Battery. (Some phones boot automatically)
    4. Please Power on phone shortly...
    AdvanceFBox SendBootCodeEx
    InitialiseBootstrap_DCT5 DIR
    BootFlashMode_DCT5
    ERROR: BOOTROM NOT DETECTED
    BootFlashMode_DCT5
    BootFlashMode_DCT5
    READING BOOTROM
    BootFlashModeDCT5Ex Succeded After 3 Tries
    SYSTEM_ID_RESPONSE_BB5 (0xC0) - 96 (0x60) bytes returned
    Number of Sub Blocks 7 (0x07)
    1 SYSTEM_ASIC_ID 01
    Block Length : 21 (15)
    BB ASIC Index : 0 (00) CMT
    ID DWORD 0 : 00000001
    ID DWORD 1 : 00000226
    ID DWORD 2 : 00010006
    ID DWORD 3 : 030C1921
    ID DWORD 4 : 01033000
    2 EM_ASIC_ID 02
    Block Length : 5 (05)
    ID DWORD 0 : 00000296
    3 EM_ASIC_ID 02
    ID DWORD 0 : 00000B22
    4 PUBLIC_ID 12
    ID DWORD 0 : 1C40010C
    ID DWORD 1 : 87E18956
    ID DWORD 2 : D76701EF
    ID DWORD 3 : 66F09026
    ID DWORD 4 : E35712FE
    5 ASIC_MODE_ID 13
    Block Length : 2 (02)
    Mode Id : 00
    6 ROOT_KEY_HASH 14
    Block Length : 17 (11)
    Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23
    7 ROM_ID 15
    Block Length : 9 (09)
    CRC 0 : 273F6D55
    CRC 1 : DFAAF68F
    ADL_SERVER: PROCESSING rm561__09.97.mcusw
    ADL_SERVER: ROOT_KEY_HASH MATCH FOUND
    ADL_SERVER: CMT CERTIFICATE BLOCK FOUND
    ADL_SERVER: CMT DATA BLOCKS FOUND
    ADL_SERVER: CONSOLIDATING CMT BLOCKS
    ADL_SERVER: PASUBTOC BLOCK FOUND
    BB5 ADL Loader Start Up... (Please Wait...)
    Found Nokia BB5 ADL Loader USB Generic...
    Processing : rm561__09.97.mcusw
    Erase Block Found
    >> Erasing area 0x00000000 - 0x000006BF, Type: NOR , Subsystem: CMT
    >> Erasing area 0x000006C0 - 0x0001FFFF, Type: NOR , Subsystem: CMT
    >> Erasing area 0x00040000 - 0x000BFFFF, Type: NOR , Subsystem: CMT
    >> Erasing area 0x000C0000 - 0x0013FFFF, Type: NOR , Subsystem: CMT
    >> Erasing area 0x00140000 - 0x0137FFFF, Type: NOR , Subsystem: CMT
    >> Erasing area 0x01380000 - 0x0151FFFF, Type: NOR , Subsystem: CMT
    Erase Complete : No Error - 0 (0x00)
    Data Block Found : 1256 Blocks
    ERROR: Data Block Not Accepted (0x0000)
    Flashing FAILED
    Booting/Flashing Failed...
    Please Try Again...
  2. 8/3/16 lúc 11:09
    sn0w
    sn0w
    con 2700c đầu tiên update ATF lên v12.67 lôi con 2700c nhà ra test thì nó báo lock như trên con thứ 2 cũng lấy file đó lôi bestdongle ra nạp ok , xong lấy atf ra nạp lại chết ngỏm lock giống hệt con 2700c đầu rồi bỏ ngược vào bestdongle flash lại ngỏm luôn
  3. 8/3/16 lúc 11:10
    sn0w
    sn0w
    tổng thiệt hại chết 2 máy anh em nào đi ngang xem lock hộ em với xem có cách nào cứu lại không
  4. 8/3/16 lúc 11:16
    246_gms
    246_gms
    up .
  5. 8/3/16 lúc 11:16
    sn0w
    sn0w
    bỏ qua bestdongle thì báo vậy rồi đứng im ru[​IMG]
  6. 8/3/16 lúc 11:21
    phamthang86
    phamthang86
    phang thử phonenix chưa bạn, không chơi cấp ốp lưng, mà chạy bản tiếng anh nhé
  7. 8/3/16 lúc 11:21
    hai_long
    hai_long
    lấy file 9.8 mà flash , vẻ bạn mới 9.7 , có khi ver cũ là 9.8
  8. 8/3/16 lúc 11:58
    Lê Hưng_vfs
    Lê Hưng_vfs
    đập ver cao nhất đi a :D nếu 9.98 ko có tiếng việt thì chơi mcu 9.98 ppm 9.97 cnt 9.97 coi
  9. 8/3/16 lúc 11:59
    sn0w
    sn0w
    load 9.8 về ấn vô flash tới đoạnErase Block Found
    Flashing FAILED
    Please Try Again...
    là nó dừng lại em bỏ qua bestdongle vẫn vậy
  10. 8/3/16 lúc 12:01
    Bắc Ninh ISTORE
    Bắc Ninh ISTORE
    chắc có back lại ime rồi giờ kẹp chân fbus vào xóa trắng máy rồi nạp lại ver nào thì nạp. nếu nó lên thì táng lại iemi vào
  11. 8/3/16 lúc 12:12
    Lê Hưng_vfs
    Lê Hưng_vfs
    có cáp đa năng nạp lại coi a.ko được thử hạ ATF về 12.50 coi chứ đừng xóa full nếu chưa xóa bao giờ.back up được cả imei và simlock mới vô tư xóa full nhé :D chứ chỉ có imei mà xóa full dòng sl3 này là vứt :D
  12. 8/3/16 lúc 12:13
    sn0w
    sn0w
    để e hạ ver atf xuống lấy cáp đa năng nạp lại thử được không
  13. 8/3/16 lúc 12:50
    sn0w
    sn0w
    :eek::eek: em nó đã tỉnh lại
    ATF Software Version v11.40
    ATF Box FBUS Flash Started...
    Number of Image Files: 2
    C:\Program Files (x86)\Nokia\Phoenix\Products\RM-561\rm561__09.98.mcusw
    CMT Type : BB5
    Secondary Sending Speed : 3250000 Hz
    Algorithm Sending Speed : 6500000 Hz
    Program Sending Speed : 6500000 Hz
    Message Reading Speed : 98000 Hz
    Entry Point : 0x5047
    Page Format : 128K
    Maximum Page Size : 0x00004000
    Changing MODE : FLASH
    Booting Phone via FBUS...
    VBATT Powering Down <<<<
    VBATT Powering Up >>>>
    SET VCCIO Level Done
    SET BSI Load Done
    AdvanceBox SendBootCodeEx
    BootFlashMode_DCT5
    TIME STARTS HERE
    BootFlashModeDCT5Ex Succeeded after 3 Attempts
    SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned
    1 SYSTEM_ASIC_ID 01
    2 EM_ASIC_ID 02
    3 EM_ASIC_ID 02
    4 PUBLIC_ID 12
    5 ASIC_MODE_ID 13
    Mode Id : 00
    6 ROOT_KEY_HASH 14
    7 ROM_ID 15
    CRC 0 : 273F6D55
    CRC 1 : DFAAF68F
    Checksum 71
    SearchForBootstrap_DCT5..
    C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg
    Boot File - Version 010.042.00
    Boot File - Revision 0x0000 (0)
    eBB5ProtocolType == Original
    SearchForBootstrap_DCT5 : No Error - 0 (0x00)
    Secondary Loader Sent...
    ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)..
    MCU_CONFIGURATION_RESPONSE_BB5:
    MessageID : 03
    SubBlocks : 03
    1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    BB ASIC Index : CMT 00
    Device Type : NOR 00
    Device Index : 00
    Manufacturer Code : 0089 ->
    Device ID : 8982 -> NU48F512
    Extended/Fixed ID : 0000
    Revision ID : 8A31
    2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5
    Block Length : 13
    Device Index : 00
    Device Contents : FFFFFFFFFFFFFFFFFFFF
    3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Type : MMC 04
    Device Index : 00
    Manufacturer Code : FFFF -> Flash
    Device ID : 0000 -> BAD FLASH TYPE
    Revision ID : 0000
    Checksum : 61
    FLS1SendAlgoCodeEx..
    SendAlgoCode_DCT5..
    SearchForAlgorithm_DCT5..
    Looking for ALL Devices...
    Searching Algorithm Files NOR (00) ManID :0089 DevID :8982 ExtID :0000 RevID :8A31
    Flash Descriptor
    Device ID : 8982
    Revision ID : 0000
    Size : 04000000 (64 MB)
    VPP Info : 0009
    Erase10s : 28
    Block1s : 64
    BErase1s : 02
    Reserved0 : 00
    Reserved1 : 00
    Reserved2 : 00
    VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK
    C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg
    Algorithm File - Version 010.040.00
    Algorithm File - Revision 0x0000 (0)
    SearchForAlgorithm_DCT5 : No Error - 0 (0x00)
    TransmissionTypeRequest_DCT5...
    SuggestedType : 01 16BIT
    TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC
    ReturnedType : 01 16BIT
    TransmissionTypeRequest_DCT5 : No Error - 0 (0x00)
    Uploading ALGO File...
    SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
    PAPUB_KEYS_HASH_REQ_BB5
    No PAPUBKeysHash Returned
    Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
    Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
    Certificate 1
    ASIC Index : CMT 0
    Certificate 2
    ASIC Index : CMT 0
    Certificate 3
    ASIC Index : CMT 0
    Certificate 4
    ASIC Index : CMT 0
    Certificate 5
    ASIC Index : CMT 0
    STORE_CERTIFICATE_REQUEST_BB5 : 61 05 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 56 41 52 49 41 4E 54 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 85
    STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
    VPP Enabled by Software
    Using Internal VPP
    StartErase_DCT5...
    BlockLength : 0x36 (54)
    ERASE Blocks : 0x01 (1)
    0 ERASE_AREA_BB5 0x12
    Block Length : 0x33 (51)
    BB ASIC Index : 0x00 CMT
    Device Type : 0x00 NOR
    Device Index : 0x00
    0 : 00000000-000006BF
    1 : 000006C0-0001FFFF
    2 : 00040000-000BFFFF
    3 : 000C0000-0013FFFF
    4 : 00140000-0137FFFF
    5 : 01380000-0151FFFF
    Erase_SendEraseBlock_BB5_NOR
    Task in Progress... Please Wait...
    STATUS_REQUEST_BB5...
    1 Sub Block ID : 14 STATUS_NOR_OK_BB5
    Block Length : 01
    BB ASIC Index : 00
    Successfully erased..
    Time Taken to Erase : 00:00:11
    TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9
    ReturnedType : 04 DDR & 2TX
    Flashing Speed: 5.00 Mhz
    Processing : rm561__09.98.mcusw
    Total blocks to write : 1256
    FBUS Cable RX2 PIN Diagnostics
    Block Length : 01
    BB ASIC Index : 00
    INFO: RX2 PIN is OK
    >> CMT Rootkey Hash CERT : NOLO
    >> CMT Rootkey Hash CERT : KEYS
    >> CMT Rootkey Hash CERT : PRIMAPP
    >> CMT Rootkey Hash CERT : PASUBTOC
    >> CMT Rootkey Hash CERT : PAPUBKEYS [3EA22A1DDA660002E56108DB5072A10F8709443F]
    >> CMT Rootkey Hash CERT : UPDAPP
    >> CMT Rootkey Hash CERT : DSP0
    >> CMT Rootkey Hash CERT : MCUSW
    ContinueFlash_DCT5 Complete
    Block Length : 01
    BB ASIC Index : 00
    Continue Flash Complete : : No Error - 0 (0x00)
    Time Taken to Flash : 00:01:02
    C:\Program Files (x86)\Nokia\Phoenix\Products\RM-561\rm561__09.98.ppm_v
    CMT Type : BB5
    Entry Point : 0x00B6
    Page Format : 128K
    Using Internal VPP
    StartErase_DCT5...
    BlockLength : 0x0E (14)
    Block Length : 0x0B (11)
    Device Index : 0x00
    0 : 01520000-01DBFFFF
    Block Length : 01
    BB ASIC Index : 00
    Time Taken to Erase : 00:00:38
    Processing : rm561__09.98.ppm_v
    Total blocks to write : 442
    Block Length : 01
    BB ASIC Index : 00
    Time Taken to Flash : 00:00:17
    Total Flash Write Time (Flashing Only) : 00:01:20
    Total Flashing Time (Booting + Erase + Flashing) : 00:02:10
    Waiting for Phone to Go Online...
    Elapsed Time: 1s
    Elapsed Time: 2s
    Elapsed Time: 3s
    Elapsed Time: 4s
    Elapsed Time: 5s
    Elapsed Time: 6s
    Elapsed Time: 7s
    Elapsed Time: 8s
    Elapsed Time: 9s
    Elapsed Time: 10s
    Basic Phone Information
    MCU Version: V 09.98 06-09-10 RM-561 (c) Nokia
    IMEI Plain : 356912031995224
    IMEI Spare : A356912031995220
    IMEI SV : 33569120319952255F
    Phone Model: Nokia 2700 classic
    Category : Classic Phone
    Phone Type : RM-561
    Extended Phone Information
    Product Serial Number: DAR087050
    Product Code : 0579808
    Module Code : 0204245
    Basic Production Code: 0577212
    Long Production SN : 0
    PPM SW Version : V 09.98 06-09-10 RM-561 (c) Nokia V
    BT MCM Version : 2222-302
    MCU SW Version : V 09.98 06-09-10 RM-561 (c) Nokia
    HW Version : 1000
    RFIC Version : 06540601
    DSP Version : ICPR72_09w26
    LCD Version : SEIKO
    Content Pack Version : Content: v_red V 09.97 18-06-10 RM-561 (c) Nokia
    AHNE Version : 30
    RETU Version : 16
    TAHVO Version : 22
    Bluetooth ID : 00:26:69:92:B3:9F
    CS Type : GSM850, GSM900, GSM1800, GSM1900
    Simlock Information
    CONFIG KEY : 0000000000000000
    PROVIDER KEY : 2440700000000000
    NETWORK NAME : Nokia Default;Finland
    LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10
    SIMLOCK TABLE :
    Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
    SIMLOCK STATE : Not Locked
    SIMLOCK_TYPE : PA_SL3 (15-digit NCK)
    SIMLOCK_TEST : PASSED
    SECURITY_TEST : PASSED
    SECURITY_CODE : 12345
    PHONE_MODE : TEST
    Dynamic Camera Configuration
    DCC ID : NIMMIIIIRRFF00000000
    DCC Ver: XXXXXX
    ERROR: DCC File Mismatched!
    Required DCC File: NIMMIIIIRRFF00000000
    Write the correct DCC to Fix the Problem
    Phone Type : RM-561
    HW Version : 1000
    LCD Version : SEIKO
    AHNE Version : 30
    RETU Version : 16
    TAHVO Version : 22
    Simlock Information
    SIMLOCK TABLE :
    PHONE_MODE : TEST
    DCC Ver: XXXXXX
    Selected VPL File:
    RM561_0581057_09.98_032.vpl
    Variant Details : RM-561 SEAP_V_GRAY_STROKE_VIETNAM
    Software Version : 09.98
    Product Type : RM-561
    Product Code : 0581057
    Variant Version : 032
  14. 8/3/16 lúc 12:59
    sn0w
    sn0w
    em thứ 2 sống lại luôn :eek:
    CMT Type : BB5
    Page Format : 128K
    BootFlashMode_DCT5
    TIME STARTS HERE
    BootFlashModeDCT5Ex Succeeded First Time
    1 SYSTEM_ASIC_ID 01
    2 EM_ASIC_ID 02
    3 EM_ASIC_ID 02
    4 PUBLIC_ID 12
    ID DWORD 0 : 25F0010C
    ID DWORD 1 : 6AC10356
    ID DWORD 2 : BA074410
    ID DWORD 3 : 2059B2F8
    ID DWORD 4 : 99A7AA3B
    5 ASIC_MODE_ID 13
    Mode Id : 00
    6 ROOT_KEY_HASH 14
    7 ROM_ID 15
    CRC 0 : 273F6D55
    CRC 1 : DFAAF68F
    Checksum A2
    MessageID : 03
    SubBlocks : 03
    Block Length : 0B
    Device Index : 00
    Revision ID : 8A31
    Block Length : 13
    Device Index : 00
    Block Length : 0B
    Device Index : 00
    Revision ID : 0000
    Checksum : 61
    SendAlgoCode_DCT5..
    Flash Descriptor
    Device ID : 8982
    Revision ID : 0000
    VPP Info : 0009
    Erase10s : 28
    Block1s : 64
    BErase1s : 02
    Reserved0 : 00
    Reserved1 : 00
    Reserved2 : 00
    Certificate 1
    ASIC Index : CMT 0
    Certificate 2
    ASIC Index : CMT 0
    Certificate 3
    ASIC Index : CMT 0
    Certificate 4
    ASIC Index : CMT 0
    Certificate 5
    ASIC Index : CMT 0
    Using Internal VPP
    StartErase_DCT5...
    Device Index : 0x00
    Block Length : 01
    BB ASIC Index : 00
    Time Taken to Erase : 00:00:00
    Block Length : 01
    BB ASIC Index : 00
    INFO: RX2 PIN is OK
    Block Length : 01
    BB ASIC Index : 00
    CMT Type : BB5
    Page Format : 128K
    Using Internal VPP
    StartErase_DCT5...
    Device Index : 0x00
    Block Length : 01
    BB ASIC Index : 00
    Time Taken to Erase : 00:00:07
    Block Length : 01
    BB ASIC Index : 00
    Time Taken to Flash : 00:00:23
    Total Flash Write Time (Flashing Only) : 00:01:26
    Total Flashing Time (Booting + Erase + Flashing) : 00:01:36
    Elapsed Time: 1s
    Elapsed Time: 2s
    Elapsed Time: 3s
    Elapsed Time: 4s
    Elapsed Time: 5s
    Elapsed Time: 6s
    Elapsed Time: 7s
    Elapsed Time: 8s
    Elapsed Time: 9s
    Elapsed Time: 10s
    IMEI Plain : 356240041306400
    IMEI Spare : A356240041306400
    IMEI SV : 33562400413064055F
    Phone Type : RM-561
    Product Serial Number: DJY973018
    Product Code : 059D1B1
    HW Version : 1002
    LCD Version : SEIKO
    Content Pack Version : Content: v_black V 09.97 18-06-10 RM-561 (c) Nokia
    AHNE Version : 30
    RETU Version : 16
    TAHVO Version : 22
    Bluetooth ID : D8:2A:7E:3E:B3:E4
    Simlock Information
    SIMLOCK TABLE :
    PHONE_MODE : TEST
    DCC ID : NIMMIIIIRRFF094B2F01
    DCC Ver: 002014
    Status : OK
  15. 8/3/16 lúc 13:13
    Lê Hưng_vfs
    Lê Hưng_vfs
    hạ ver ATF và dùng cáp đa năng tỉnh ngủ luôn à :D :'''
  16. 8/3/16 lúc 13:34
    BomTấn_VFS
    BomTấn_VFS
    Đang sài ver 11.88 chưa die em nào ,chưa hiểu sao update ver cao lại die máy:D
  17. 8/3/16 lúc 13:36
    thuanmobile33
    thuanmobile33
    Chắc lúc đầu flash bằng usb chết nguồn.Mấy dòng bb5 flash nửa chừng chết hầu như toàn phải flash bằng cáp đa năng hoặc ốp lưng mới ok.
  18. 8/3/16 lúc 13:43
    LKĐT Bình Dương
    LKĐT Bình Dương
    Em thứ nhất lỗi Cam :D
  19. 8/3/16 lúc 13:45
    sn0w
    sn0w
    đúng rồi anh hạ ver xuoongs11.40 dùng cáp đa năng
  20. 8/3/16 lúc 13:46
    sn0w
    sn0w
    sống lại là mừng rồi :D, để em fix lại từ từ
  21. 8/3/16 lúc 13:46
    sn0w
    sn0w
    2700c flash bằng ATF bản update chết nguồn
    đúng rồi anh ban đầu flash qua usb
  22. 8/3/16 lúc 13:48
    sn0w
    sn0w
    em bị lần này nữa lần thứ 2 khi update ATF lên cao là flash bị lỗi không hiểu tại sao
  23. 8/3/16 lúc 13:51
    sn0w
    sn0w
    Anh có bản setup 11.88 full 4sheard không cho em luôn đi, tìm trên google toàn bản cao
  24. 8/3/16 lúc 14:03
    BomTấn_VFS
    BomTấn_VFS
    Cài bản thấp ra sau đó giải nén file 11.88 ,trong đó có 2 file ,mở thư mục => AdvanceBox Turbo FlasherNokia ,copy file Nokia quảng vào => C:\AdvanceBox Turbo Flasher\Nokia ,còn AdvanceBox thì quăng vào => C:\AdvanceBox Turbo Flasher là done .
    => http://www.4shared.com/rar/iEh0SwQpba/1188.html?
